Oil leak - am I in trouble based on these pics?
Old 08-21-2009, 07:24 AM
  #41
nzelinsky's Avatar
WOW that oil pan was seriously rusty... I thought mine was bad (no holes)...
Those damn stickers were a pain in the a... I left them on like that too, I figure they will probably just burn off or fall of when they get wet
nzelinsky is offline
Old 08-21-2009, 08:08 AM
  #42
Grand_hustle17's Avatar
couldnt it have been the rear main seal???
Grand_hustle17 is offline
Old 08-21-2009, 08:14 AM
  #43
Suspension Yoda
djfrestyl's Avatar
Rear main seal leaks to the bottom of the transmission housing, not over to the oil pan.
djfrestyl is offline
Old 08-21-2009, 08:27 AM
  #44
i guess... i got a leak at my rear main seal and i have oil over my oil pan... oil pan was replaced under warranty, but im not the one to listen to, im just throwing things out there
Old 08-21-2009, 08:39 AM
  #45
Suspension Yoda
djfrestyl's Avatar
Pan might have been replaced, but the oil pressure switch directly above it could be leaking. Mine was...
Old 08-21-2009, 08:42 AM
  #46
kool ill check that
Old 08-21-2009, 08:53 AM
  #47
ridinwitha35's Avatar
Yup, no one looks under my car anyway. I thought the same too - the hot oil will heat up the adhesive, then just splash through some puddles on a rainy day and it might come right off.
I think I'm good on the rear main seal...transmission remains clean. I'm gonna do the OPS and oil cooler o-ring soon just for good measure and since they're cheap, but that pan was probably the main culprit.
ridinwitha35 is offline
Old 08-22-2009, 02:06 PM
  #48
Originally Posted by ridinwitha35
The grayish bolts under the control arm has brown stuff that looks like oil. Not sure what other fluid that can be.
My pan is still in definite need of replacement (just gotta figure out a way to get the rounded bolt out without breaking it) but something tells me it won't fix the problem. There's oil all up in that area.
Below is a shot of the passenger control arm right by the link pin bushing. Hard to see in this pic but there is some torn rubber in this bushing...might even explain my horrible ride quality:
Old 08-24-2009, 04:45 PM
  #49
So far, so good. Haven't noticed any oil puddles on the ground under the car anymore, but haven't taken a close look at the actual undercarriage.
Old 09-09-2009, 08:44 AM
  #50
Three weeks later and the oil pan is still dry & glossy as a rug. I believe the oil pan was it. Didn't even do the o-ring & OPS (though I still bought the parts).
Old 12-14-2010, 06:18 PM
  #51
Rods03Max619's Avatar
Originally Posted by nissandrvr98
speak english-i just got a headache
@ridinwitha35:
if there's nothing around the drainplug you gotta keep lookin-agree on that oilpan(might wanna grab a replacement). Start it up, see where its comin from, go from there and good luck.
I was laughing at the speak english like Damn!!
Rods03Max619 is offline
Old 12-14-2010, 06:54 PM
  #52
Da Roller Coaster!
foodmanry's Avatar
Originally Posted by str8max
What do you mean lube up your gasket?
I am looking to do this soon if I use a gasket why would i lube it with silicone?
I believe he means silicone RTV gasket material. Just use a small bit of this to keep the gasket in place while installing. The gasket will likely move out of place when installing if you don't use some RTV to seat it to the pan.
foodmanry is offline
Old 12-15-2010, 06:40 AM
  #53
dot dot dot ...
NmexMAX's Avatar
Who's the grave digger?
NmexMAX is offline
9aj9
04-05-2020 12:11 AM
kjlouis
10-03-2015 05:29 AM
bryants95max
10-02-2015 12:52 PM
ag90fox
09-09-2015 12:22 PM
dcam0326
09-07-2015 07:26 AM
Quick Reply: Oil leak - am I in trouble based on these pics?
