5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Replaced both O2 Sensors,and codes are back, Please advice.
Last week I got the ck engine light on, checked the codes, and the codes were the malfunction of the (2) O2 sensors (In front of the Cat), the car runs Normal. I did replace the O2 sensors today with Bosch Sensors, cleared the codes, I started the car, and the ck engine light came on after 25 Second, checked the codes,and guess what? same codes. Please advice , thanks.
__________________ Vortech V2 T-trim, 2.87" pulley, intercooled, Defi Gauges, RC 550cc, Walbro 255lph, Aeromotive AFPR, Cattman Headers and 3"catback, Emanage blue, B&M Short Shifter,Third PAR Synchromesh Racing Gear, Vortech Maxflow Race Bypass valve, Stillen Sport Drilled Rotors, w/ Hawk HPS Brake Pads,Eibach Pro-Kit on Tokico Illumina,Cattman FSTB,& RSB, Competition pressure plate on-ACT 6 Puck sprung disk.
i have seen this before, the one i had at work came from an o2 sensor grounding out on the exhaust (a hole rubbed through it), so check the other o2 sensors, cause it wasnt the ones that were pulling the codes that caused the problem, then check the fuses under the dash, one popped and pulled the codes.
__________________ 93' Sentra SE-R-SR20DE, The Project. 96' 200SX SE-R-SR20DE, Sittin Pretty. 02' Maxima SE-VQ35DE, 6 Speeds And Lovin' It. 04' I35-VQ35DE, Daily Driver/Baby Cruiser.
Just found a blown-up 15A fuse (Engine Control), Replaced it and as soon as I turn the key on it blows-up, I need to check the O2 sensor (Simulated)after the cat. Thanks for your help nsmo240 .
for sure, if you cant see any sign of it grounding externally to something, try unplugging it and turning the key on, maybe its possibly internally shorted.
When installing 02 sensors, make sure you use the copper grease that came with it. It's imperative for a proper ground.
So you're saying that our 02 sensors are grounded by copper antiseize and not the ground wire running from the o2 sensor to chassis ground?
__________________
SS Headers and Y-pipe, Random Tech Cat, Megan Racing Catback, Eibach Pro Kit (garbage with blown struts ), 2nd gen Altima SE 17" Wheels
I got the p0155 code. Replaced the 02 sensor Bank 2 sensor one. I still get check engine light. I'm stlii idling rough. I have anti seize on the sensor. Everting else looks fine. i haven't read the codes again but is there something else I should be lookng at?
