clicking noise when i turn right what is it?????
Old 05-02-2009, 03:34 PM
Jordan22's Avatar
01 SE with clicking noise in wheel area??? Any Ideas???
ok so basically when i make a right turn you can hear a clicking noise in my driver side wheel area. i took the tire off thinking it was a retainer clip for the brake pad that popped out i fixed that it wasn't the problem. i checked the inside of the rim for some kind of wear do to rubbing...nothin seems be worn or showning signs of rubbing so ANYONE GOT ANY IDEAS ON WHAT COULD BE THE PROBLEM??????? only happens when i make right turns
Jordan22 is offline
Old 05-02-2009, 07:54 PM
No more Maximas...
pmohr's Avatar
How do the axles look?
pmohr is offline
Old 05-03-2009, 01:21 PM
Jordan22's Avatar
old and rusty im thinking that because i do my own oil changes that i never grease any of the places that the oil change palces do when they do there check. i dont know where the lub points are to grease or if that could be the problem
Jordan22 is offline
Old 05-03-2009, 01:23 PM
No more Maximas...
pmohr's Avatar
Lube joints tend to not grease anything, regardless if it needs it or not.
There's not a zerk fitting on the A33, there's nothing to grease.
pmohr is offline
Old 05-03-2009, 04:29 PM
orovillemax's Avatar
CV joints? check rubber boot on the axle. make sure it's not torn.
orovillemax is offline
Old 05-03-2009, 04:57 PM
williamgd2's Avatar
I second that bad cv joints will click around corners.
williamgd2 is offline
Old 05-03-2009, 05:53 PM
cleindian44's Avatar
3rd opinion voting for CV joints.
cleindian44 is offline
Old 05-03-2009, 06:45 PM
e-subliminal-2's Avatar
Cv, however there was a previous post similar and it was his Bump stops or something similar. Correct me if wrong.
e-subliminal-2 is offline
Old 05-03-2009, 07:39 PM
tooreckless00's Avatar
Its not the CV because I have the same problem and the noise was there before and after I replaced a torn boot and I still have yet to figure out what it is.
tooreckless00 is offline
Old 05-03-2009, 07:40 PM
No more Maximas...
pmohr's Avatar
You are aware that replacing a boot does nothing to repair a damaged CV joint, correct?
pmohr is offline
Old 05-03-2009, 07:47 PM
NiteCrawler's Avatar
oops..but also theres a ring thats sets inside the mount that allows it to spin also back and forth..
NiteCrawler is offline
Old 05-03-2009, 07:48 PM
Its the strunt mount bro i had both of mine replaced....and make them grease them after there replaced
Old 05-03-2009, 08:31 PM
Yes i'm quite aware, but having a damaged boot could harm the CV joint, correct?
While replacing the boot, I made sure everything else was in shape, therefore i came to the conclusion that it wasnt anything in that area, but thanks for asking
Old 05-03-2009, 08:33 PM
No more Maximas...
pmohr's Avatar
Not directly, but by letting in debris, yes.
pmohr is offline
Old 05-03-2009, 08:45 PM
Thats what I meant lol
Old 05-05-2009, 01:47 PM
Jordan22's Avatar
ok so look at the boot of the cv joint see if torn (replace) or strut mount both sound expensive which one is easier to do
Jordan22 is offline
Old 05-05-2009, 01:49 PM
No more Maximas...
pmohr's Avatar
The first is obviously the cheapest. Taking a look doesn't cost a thing...
Neither of them are either hard or expensive. The axle would be more expensive than the strut mount, but the strut mount (IMO) would be a 'harder' job.
pmohr is offline
Old 05-05-2009, 01:50 PM
Jordan22's Avatar
how much is it to replace the cv joints
Jordan22 is offline
Old 05-05-2009, 01:52 PM
Jordan22's Avatar
what does (IMO) mean
Jordan22 is offline
Old 05-05-2009, 01:53 PM
No more Maximas...
pmohr's Avatar
Are you determined to not do any of your own research?
Price out axles wherever you're going to buy them from.
Then call shops (assuming you're not doing this yourself, which is what it sounds like) asking them how much an axle replacement would be.
Prices change by area, for both parts and labor. We have no way of knowing what your shop will charge for hourly, how many hours they'll charge, what they'll put on there for shop supplies, diagnostics, etc.
Call around, find out for yourself. Those are the only true prices you'll get off of here.
pmohr is offline
Old 05-05-2009, 01:54 PM
No more Maximas...
pmohr's Avatar
Originally Posted by http://en.wiktionary.org/wiki/IMO
IMO
In My Opinion (especially on the Internet)
pmohr is offline
Old 05-21-2009, 10:46 AM
RaikkaF1's Avatar
I think i have the same clicking noise but not on turns. If i turn left/right there isn't any clicking, but, if i drop the clutch in first at 2 grand, and floor the car, it sometimes makes this clicking noise that's really deep. anybody know what it might be?
RaikkaF1 is offline
alahjahwan09
18
09-21-2015 09:12 PM
pears
09-18-2015 05:25 AM
lrb6805
09-17-2015 04:49 PM
LtLeary
09-14-2015 12:33 PM
bennuss
09-11-2015 05:55 AM
Quick Reply: clicking noise when i turn right what is it?????
