Help with Umnitza HID fog install
The Whistle go WOOOOO
Anybody know a good way to seal the rear of the fog housing after installing the umnitza HID fogs? I am lost on this one and can't find a thing when I search. Any help would be great. Thanks guys
Josh
Josh
ever get this sorted out? Im going to be installing these HIDs on my 01 tomorrow...Im assuming silicone would seal up the drilled hole? Or is the problem that the H3 bulb is too long
My issue was the grommet. You need to cut a circle in the back of the housing. If you cut the right size then there is no need for silicone. The regular bulbs are too long, that's why you should order the H3c bulbs. They are smaller and fit. If you order the regular H3 bulbs then you just bend down the light reflector in the housing. Just stick a screw driver in there and bend it down.
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
