hole in the exhause or .........
lately my car's exhaust makes a deep sound. it sounds great but before it was wicked quiet, so i think there might be a hole in the exhaust, but the car is too low to get underneath and check and i have no money at the time so how long can i run like that, and what is a decent exhaust system i can get for cheap are the ebay ones any good?
Yeah sounds like you got a leak somewhere under there. When the car is on, cover the muffler tip with a rag to sort of clog it. If you hear air still escaping, then its definitely a leak. You can drive forever like that, but personally I wouldn't.
yup there's a leak. its between the muffler and the bit barall thing that is after the cat converter. i have to wait till end of summer to gather up some cash so will i be able to run that long and what can go wrong if i ran like that
thanks
thanks
So you have a leak in the b-pipe? The car will run until then, but your losing performance and probably MPG also. Those are the only things that can go wrong.
the leak is from one of the welded connectors by the rear axel. its between the b pipe and the muffle and its a big hod thing is rusted tot he core.
I'm on a budget so any one know of a decent catback system i need to replace the whole thing from the headers (the headers are fine so y pipe onwards), so far i looked at the megan catback they look nice and well i heard both good and bad about it, but is there any thing cheaper and good
I replaced mine with OEM because I have a connection at the stealership. If you are strapped for cash, i hear bosal is a decent replacement for the money.
If you can tell which side of the flange connection is leaking, you may only have to replace the b-pipe or the muffler. I would be willing to bet its the muffler side meaning you would just need a new muffler. Mine started leaking there last winter when I hit a pothole, then within a week or 2 the muffler was completely separated.
DC_Juggernaut
09-28-2015 04:07 PM
max ride 41
09-17-2015 06:17 PM
bbsitum
09-11-2015 04:55 PM
