Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 03-30-2009, 10:35 AM   #1
Car shuts off while driving? tps??
2001 maxima 5 speed, shuts off randomly while driving? whether it be highway 70+ or simply getting off a light. Not maf related im sure. Tried cleaning the Tb but still same thing. It's getting worse each time i drive it. Could this be the Throttle position sensor?
e-subliminal-2 is offline   Reply With Quote
Old 03-30-2009, 11:18 AM   #2
Points: 4,046, Level: 40
Points: 4,046, Level: 40 Points: 4,046, Level: 40 Points: 4,046, Level: 40
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
When it shuts off does it turn back on right away? if so it could be your battery. If it shuts off and you have to actually turn the key then im not sure what it could be
__________________
HPaddictionz
witeonblakmax is offline   Reply With Quote
Old 03-30-2009, 11:30 AM   #3
No, it shuts off and i manually haveto let off the cutch again or start it back up.
Old 03-30-2009, 02:31 PM   #4
Bump, anyone??
Old 03-30-2009, 04:11 PM   #5
Points: 6,615, Level: 53
Points: 6,615, Level: 53 Points: 6,615, Level: 53 Points: 6,615, Level: 53
Activity: 0%
do you have a CEL? To me it seems Power or sensor related. I would think something is loose and that would explain why it's getting worse. As time goes by whatever is getting looser. Check all your grounds on the car and clean off the studs on the battery. If it still seems to be an issue I would start checking sensors and making sure they are tight. I just recently had an issue with a loose Crank position sensor my car would loose all hp randomly and misfire like crazy. I tightend the sensor and now it runs like a champ.
__________________
Greddy Exhaust - OBX-R Headers - NWP Spacers - Full SSIM - UDP - Custom Intake
99Silvermist SE is offline   Reply With Quote
Old 03-30-2009, 05:08 PM   #6
It's fully random. I had a 91 prelude that did the exact same thing, randomly shut off and it was the tps. I'm assuming it's the same thing here but im not too sure, just wanted to grab some input. Anyone?
Btw i've checked all the sensors. Nothing i can notice. everything is good and grounds are also. Not maf related cause its reving fine and drives fine. Just randomly shuts off which could (god forbid) cause the car to wanna sleep when i need it to giddy up and go...
Old 03-30-2009, 05:33 PM   #7
BARF
Points: 7,490, Level: 57
Points: 7,490, Level: 57 Points: 7,490, Level: 57 Points: 7,490, Level: 57
Activity: 0%
It sounds like it could be the knock sensor, but I could be wrong.
__________________
PICS: THE CLIMAXIMA Sold for 3k with bad trans, DEALZ!
Revs2Hard is offline   Reply With Quote
Old 03-30-2009, 05:57 PM   #8
Points: 5,228, Level: 46
Points: 5,228, Level: 46 Points: 5,228, Level: 46 Points: 5,228, Level: 46
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Tighten your battery cables..
__________________
klemenz is offline   Reply With Quote
Old 03-30-2009, 07:29 PM   #9
Points: 4,482, Level: 42
Points: 4,482, Level: 42 Points: 4,482, Level: 42 Points: 4,482, Level: 42
Activity: 0%
check for any loose sensors and.try cleaning your tb again.. if not then try changing your tps.. hopefully that should do it by your description..
__________________
*2001 Maxima Anniversary Edition 5-Speed*
Sold
*2006 Mazda Mazdaspeed6 6-Speed*
Sold
*2003 Mazda Mazda6 5-Speed*
Sold
*2003 Nissan 350z 6-Speed*
Sold
*2004 Nissan Maxima 6-Speed*
Current
Jamhour is offline   Reply With Quote
Old 03-30-2009, 07:32 PM   #10
Points: 9,807, Level: 66
Points: 9,807, Level: 66 Points: 9,807, Level: 66 Points: 9,807, Level: 66
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
http://www.facebook.com/greg.richer anomaly117
Send a message via AIM to anomaly117
how is throttle response when the car is running?
__________________
anomaly117 is offline   Reply With Quote
Old 03-30-2009, 07:33 PM   #11
Quote:
Car doesn't knock or misfire though.
Drives perfectly fine.
Old 03-30-2009, 07:34 PM   #12
Quote:
It's perfect. Nothing out of the ordinary. It pulls exactly like it did wot before the sudden stops.
Old 03-30-2009, 07:34 PM   #13
Quote:
Ill give that a try. I think i skipped over that. But wouldnt the car start back up if its a faulty or loose cable? plus no trouble startin up..
Old 03-30-2009, 07:58 PM   #14
Activity: 0%
maybe you just cant drive.. jk but i have a problem similiar to yours right now.. not sure what it is exactly?
__________________
Sold
Sold
Sold
Sold
Current
Old 03-30-2009, 09:16 PM   #15
Activity: 0%
might be a sensor like someone posted above.. maybe camshaft position sensor? thats what was wrong with mine but i felt a huge loss of power..
__________________
2002 Maxima SE Auto - Totalled 9/27/09
2002 Maxima GLE Auto - Picked up 10/16/09 - Totalled 4/5/11
2007 350z 6spd - Picked up 4/21/11
tookrzy4u192 is offline   Reply With Quote
Old 03-30-2009, 09:27 PM   #16
That's Mr. Detail to you
Scottwax's Avatar
Points: 13,623, Level: 75
Points: 13,623, Level: 75 Points: 13,623, Level: 75 Points: 13,623, Level: 75
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Send a message via AIM to Scottwax
Quote:
My thoughts as well. Camshaft and the crankshaft position sensors is what I would suspect. Big problem on the 5.5 gens, included a recall. Not sure if it is a common problem on 5th gens though.
__________________
2004 Honda Accord EX V6 5AT, debadged, XLR8 J-pipe V2, AEM v2 intake, mid-muffler delete, factory resonator replaced with Dynomax resonator, TL-S 27 mm front and 20 mm rear anti-roll bars, DC Sport FSB, tinted windows, RSX wheels
2002 Maxima SE 6 speed, K&N panel filter, GAB-more gears, more fun! Now no more, RIP 9/01/11
2002 Maxima SE, NWP block plate, GAB, Warpspeed test pipe, Vibrant FSTB, grounding kit, smoked tails. RIP 1/16/2011 due to a pile of garbage drunk driver
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 03-30-2009, 09:36 PM   #17
Points: 4,133, Level: 40
Points: 4,133, Level: 40 Points: 4,133, Level: 40 Points: 4,133, Level: 40
Activity: 0%
Quote:
You beat me to it. My buddy had the same thing happen to his 2002. Turned out to be the sensors and it WAS covered under the recall. You can check, but I'm pretty sure it was only the 5.5's.
__________________
2001 Maxima SE AE MT
[SIGPIC][/SIGPIC]
****WTB: 1985-1988 NISSAN 200SX****
4DSCDriver is offline   Reply With Quote
Old 03-31-2009, 04:54 AM   #18
Wouldnt u notice a huge change in power loss though?
Old 03-31-2009, 07:00 AM   #19
Scottwax's Avatar
Activity: 2.3%
Quote:
Not if it is an intermittent signal loss problem. Everything is fine and then you just stall out, that is why there was a recall on the 5.5 gens, cars would just stall out at freeway speeds.
Old 03-31-2009, 10:20 AM   #20
Points: 6,947, Level: 54
Points: 6,947, Level: 54 Points: 6,947, Level: 54 Points: 6,947, Level: 54
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
I would think if it were a sensor, that a CEL light would come on?
U sure its not your alternator??
__________________
2002 SE 6spd.
shysmax is offline   Reply With Quote
Old 04-01-2009, 03:10 PM   #21
HELP !!!
yes... i'm a newbie here...but have read through ALOT of various threads to help diagnise my probs. that said...things have changed in the last 12 hours, lol>>> any and all help is welcome !!!
will layout the events in description as they have unfolded over last couple of days ...
2001 maxima se 144k miles... other than normal wear and tear replacements/maintenance over the years, nothing major to speak in regards to break-downs ...
2 days ago ... car operating fine, mid-aftrnoon-warm weather car died/stalled when idling at a stoplight, had to double pedal the brake and gas to keep running. 30 min. later problem gone.
1 day ago ... same thing again, but this time in the morning, cool weather ... BUT, this time it actually did while driving UP a highway on ramp at approx. 15 mph(i had to let off gas to merge into traffic) ... car died when i let off. problem went away... re-emerged later in same day, idling at light. went away again.
today ... car wouldnt start this morning, acted like battery dead, yet, lights/radio, and all auxilliary functions worked. would slowly turn over, after 3-4 attempts, dead...nothing. 7 minutes later it started and warmed right up, no probs. after a 20 mile drive, started stalling again at low idle, had to double pedal it home again.
here is where it gets really weird ... as soon as i got home and turned vehicle off, i decided to take it to autozone and get their free diag test. again ... car wouldnt start, every indication its battery oriented. 3 hours later it fired right up (still had to double pedal to keep it running, though)
drove to autozone... showed the IACV was out (as i expected somewhat after reading this thread)... had him check out battery, its fine, but a little loose on the positive side terminal. tightened it up, car started fine. went and got some gas, car started fine.... came home, turned it off, tried to restart..and NOTHING. cleaned the posts and terminals, even tried jump starting ... still NOTHING.
guy at garage said it sounds like the terminals on the positive side could be corroded down into the "multi-terminal" portion (3 cables into one, with a fuse).... also said i shoud take off the IACV and spray down with B12 chemtool since its already showing up as "bad", said it couldnt hurt, and in his experience has fixed the prob sometime.
the IACV stuff makes sense to me... but whats the deal with the "electrical" starting issues...and why did it start happening directly/indirectly with the idle issue??
sorry this was so long...just wanted to make sure you had all info.
btw...i have relative that has worked at GM for 30 years, said absolutely no reason for me to be using higher octane gas...he has used the lower with no probs. so...my gullable money saving a** decided to start running the regular lowest grade gas (after using premium since i bought this car new in 2001) about 3 weeks ago... could this be a prob too??? mechanic said if no pinging then no prob...but also said "there is a reason the manufacturer tells you to run premium in this car!!"
i switched back to premium today...albiet the car wont start....
PLEASE HELP !!!!!!
thanks !!!!
bcmfxtrader is offline   Reply With Quote
Old 04-01-2009, 07:57 PM   #22
Mind not stealing this thread? post 15-20 (w;/e it is) and start your own.
thanks.
Old 04-01-2009, 07:57 PM   #23
Cel is on, and im almost sure its not the alternator. It holds charge fine.
Old 04-01-2009, 08:35 PM   #24
Scottwax's Avatar
Activity: 2.3%
Alternator problem shows up as both brake light and battery light lit up.
Old 04-02-2009, 02:15 PM   #25
Points: 4,408, Level: 42
Points: 4,408, Level: 42 Points: 4,408, Level: 42 Points: 4,408, Level: 42
Activity: 0%
I had a very similar problem before with my old fourth gen. You should check you MAF sensor.
ckent512 is offline   Reply With Quote
Old 04-02-2009, 07:05 PM   #26
Activity: 0%
have you seen which code its running?
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
