Replacing LOW SIDE A/C hose
Old 03-11-2009, 09:21 PM
maximillien's Avatar
I went for a diagnostic and they told me I would need to replace the low side hose(hose you see right when you open the hood). Couple questions:
Where can I find online to buy this? They want to charge me 250 JUST for the hose CRAZZZZZZZZZZZY!
Also is there a how to for replacing? Has anyone replaced? How far to the bottom of the car does it go? What tools would I need to take out the rings. Thanks! Will take pictures tomorrow!
maximillien is offline
Old 03-11-2009, 09:32 PM
nsnrider's Avatar
which hose are you talking about? the flexible one that runs from the compressor to the A/C condenser? That one is secured by a 12mm bolt on each end. Make sure you have the A/C evacuated prior to disconnecting anything. If you don't know much about cars, leave the A/C system to the pros.
I might have the hose you need, used part of course.
P.S. make sure its the hose you need and not just the "O" rings at the ends, which are very cheap to buy.
nsnrider is offline
Old 03-11-2009, 09:34 PM
Demodded and Forgotten
rroderiques77's Avatar
As far as I know, it is a dealer item.
Get a hold of DAve B and tell him what you need. $250 alone for the hose sounds crazy. If you were in Vegas I would offer to do it for you on the house.
You will need to discharge the system.
Good luck man!!
rroderiques77 is offline
Old 03-11-2009, 10:44 PM
He did the UV dye test, and looking at the low pressure side hose alot of green is coming from near the O ring, but I wouldn't know if it's just the ring, he recommended to replace the WHOLE hose starting from the metal part all the way down to the bottom.
Who's Dave B, how can I contact him.
Old 03-11-2009, 11:06 PM
Feldman's Avatar
its probably just to o-ring. If you are handy you might just want to try replacing that.
On a side note it is a good idea to run your ac every once and a while durring the winter to lubricate all the seals and what not
Dave B is a nissan parts guy that takes care of all of us on the .org I dont have his # handy but you can PM him here: http://forums.maxima.org/members/daveb.html
Feldman is offline
Old 03-11-2009, 11:15 PM
Thanks I just PM'd him, I will keep you updated
Old 03-12-2009, 08:31 AM
1-888-254-6060
This should be alot quicker than the P/M. He doesn't check it every single day.
Old 03-12-2009, 10:46 AM
VQP0WER's Avatar
Also note, it is illegal to evacuate your refrigerant into the open air, and you will need a shop pull vacuum and recharge the system. Might as well have a shop do it all.
VQP0WER is offline
Old 03-12-2009, 11:30 AM
NisTech's Avatar
just do the o ring. Go to a shop to do an evac first, then do the o ring and make sure u don't strip it since it screws into aluminum, then go back to shop tell them to do vacum, then add dye for future leaks and then recharge it.
Do not use the stuff in the can!
NisTech is offline
Old 03-12-2009, 05:51 PM
No more Maximas...
pmohr's Avatar
You don't evacuate the system prior to work, you do so after it's all back together.
Minor point, but go into a shop asking a guy to evac your refrigerant so you can work on the AC system, and he'll think you're an idiot.
IMO if you aren't going to use the terminology correctly, then just don't use it.
Often times it leads to a lot of confusion or improper diagnoses. Try to evac a full system and you'll likely damage the pump (if you use a separate vacuum pump). That or they'll recover/discharge and evac the system...you'll go home and remove a hose, then after you hear the loud sucking sound, you'll realize that you wasted an ~hour of time + labor to have the system evac'ed for no reaosn.
pmohr is offline
Old 03-14-2009, 09:36 AM
NisTech's Avatar
good cath, my bad i ment recover (Just reading through posts and followed the herd) so u don't release any r134a HFCs to enviroment.
Actually on the machine there is no thing as an EVAC. Only recover, vacum, add dye and recharge right? that's why evac as in evacuate the building some ppl still use it and it is often understood as in recover.
Also if u just recover and then crack open the line u will not hear a sucking sound. That's how u repair the system. U recover first then repair the line then vacuum which after if u crack the line then it will make a noise. So u r not using correct terminology either.
BTW i have a an a/c repair licence as well.
I am sure wherever u go in they'll easily figure out what u want. Wouldn't u?
NisTech is offline
Old 03-14-2009, 11:12 AM
No more Maximas...
pmohr's Avatar
I never said that you'll have a vacuum after recovering, read my post again:
It's not 'understood' as recovery, it's understood as pulling a vacuum.
The definition of 'evacuate':
evacuate - create a vacuum in (a bulb, flask, reaction vessel)
evacuate - To remove, through the use of a vacuum pump, all moisture and noncondensables from a system.
The process of removing moisture and other gases from a refrigeration system.
...etc.
And yes, most machines have an 'Evacuation' setting, every single machine I've ever used does; and a quick search on google:
Robinair Cooltech 34788 R-134a A/C Recover, Recycle, Recharge And Evacuate Unit
CoolTech Recovery, Recycling, Recharging Unit Fully compliant with SAE J2788 standards! The Cool-Tech 34788 combines simple operation with superior accuracy. It recovers, recycles, evacuates, leak tests, and recharges R-134a quickly and accurately.
Automatic Recovery, Recycling, Evacuation, & Recharging Machine for R-134A
Automatic operation allows the technician to program the unit to recover, recycle, evacuate, recharge and then walk away
Clore Automotive VR6000 Semi-Automatic Recovery/Recycle/Evacuate/Recharge R134a A/C Service Center
It really does go on from there. Point being, evacuate means vacuum, and nothing else.
If someone came in and said they wanted their system evac'ed, that's what I'd do. If they explain to me what they're trying to do, then I'll do what needs to be done.
And I don't have an A/C repair license, I just have lots of hands on time working on automotive A/C equipment and passed A7
pmohr is offline
Old 03-14-2009, 10:53 PM
I found a shop to replace and recharge for 200 bucks, so yea i'm going to let him take care of it. I was going to change it myself but due to all your concerns, I make it easier on myself. OEM hose is 115 anyways. Thanks everyone for their comments!
Old 06-03-2011, 09:03 PM
rilla dope
releasedtruth's Avatar
Wow, I'm amazed you got it done for that price. The hose alone for the '01 looks like $250, incredible. I've had a very slowly warming AC for many years (car is 10 now) and I went to recharge today with r134 + dye/sealer and couldn't increase the pressure much after 1.5 cans. Any way I can use alumalloy or the like to seal it up instead of paying a pantload on a problem I've likely ignored for years?
Attached Thumbnails Replacing LOW SIDE A/C hose-img_0305-1-.jpg
releasedtruth is offline
vingodine
45
05-21-2016 12:46 PM
MaximaDrvr
08-19-2015 08:20 PM
scarletsosa
08-17-2015 09:09 PM
kirkhilles
08-08-2015 10:53 AM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Replacing LOW SIDE A/C hose
