Have OBD Codes and now the car shakes!!
Old 05-26-2011, 02:39 PM
2010MaximaSV's Avatar
I have a 2003 Maxima SE 6 speed that I picked up recently. The codes that I got are P0300 P1448 and P0455. I did check the fuel cap and it looks to be new so it couldnt be that. The car has 128,000 miles and the owner said the spark plugs have never been changed. I checked all the hoses and did not see any leaks or anything. Today I was driving the car and anything under 2000rpm's the car would start shaking no matter what gear it was in. Should I start with the spark plugs? Then after that?
2010MaximaSV is offline
Old 05-26-2011, 04:26 PM
joeltender's Avatar
Change your plugs asap! avoid driving or you'll eff up your cats, injectors, etc.
Unfortunately, you'll need to replace your valve covers with 04 ones (gaskets too) test your coils-goodbye po300.
The others are evap/gas cap codes. Tons of us have these codes and just live with them-unless your super picky or live in cali. I've had those 2 codes for over 30000k and get great mileage and breeze through emissions. after your done, seafoaming is probably a good call.
joeltender is offline
Old 05-26-2011, 07:15 PM
Yes I wont be using the car so I will be replacing the spark plugs tomorrow. My coils would be gone now??? Is there a part number for the valve covers?
Old 06-02-2011, 06:32 PM
I just changed all my spark plugs and tested the front 3 coils. It still does the same thing feel like it even got even worse now.
Old 06-02-2011, 07:04 PM
CMax03's Avatar
Put a timimg light on those (6)coils to see if they're missing!
CMax03 is offline
Old 06-02-2011, 07:14 PM
How do I do that, would like a autozone or pepboys have that?
Old 06-02-2011, 07:21 PM
CMax03's Avatar
Sears, autozone, Advance, etc.....connect the inductive pick up around the coil harness and it will pickup the ignition signal and flash the strobe
CMax03 is offline
Old 06-03-2011, 08:21 PM
00Lightsout's Avatar
the VQ30DEK had all faulty coilpacks from NISSAN...did the VQ35 have the same problem?
00Lightsout is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
jhontelj
08-17-2015 04:07 AM
yat70458
08-03-2015 01:16 PM
maxima297
08-03-2015 12:50 PM
Quick Reply: Have OBD Codes and now the car shakes!!
