5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
can get them! But they normal have a book at NAPA for application which includes every single exhaust mount on our car! Getting that banging during hard right turn yet? Sound like a cv axle but it that exhaust swinging into that bpipe exhaust mount stub!
Yeah its hitting the underbody of the car right where the axle-back and bpipe meet. I'm going to try new mounts to see if that helps it or not.
__________________
Progress Coilovers, Otto racing FTSB, Stillen RSTB, Progress RSB, Window tint 20%/5% All Around, Clear Side Markers, Berk w/ JWT Filter, SS brake lines, 350z Ray Rims, Maxxtuning front lip, Stillen sides and rear lip, 300z BBK, SSIM, Xtreme Eyelids, NWP Thermal Intake Manifold Spacer, Truax SFCs, E46 DDE's, Clear Corner, Rainbow speakers, Eclipse AVN 6610, Hifonics amp, Epic 160, HS Headers, Cattman 3" catback
bpipe-exh35460
rear muffler- exh35725
These mount are stiff and tough! You might need to add one more mount and hangar on that side to help support it better since the tolerance is even less now! Or wrap your pipe with exhaust wrap and you won't hear it hitting anymore!
bpipe-exh35460
These mount are stiff and tough! You might need to add one more mount and hangar on that side to help support it better since the tolerance is even less now! Or wrap your pipe with exhaust wrap and you would hear it hitting anymore!
I just hope the store has it. I'll see once I get them installed.
__________________
Here are some thoughts about fitment that might be useful to some.
First, and most important, make sure the resonator section is right side up!!! It looks straight, but isn't quite, and if its wrong side up it will subtly throw off the alignment of the entire catback. Identifying the proper orientation is easy since we put a welding bead on the tube right behind the front flange (that bolts to the car). That bead should at 12 o'clock on the car side, not the ground side (6 o'clock).
Of course, there's less clearance with a 3" system, but keep in mind that if the resonator is in the proper position, a rattle can usually be solved by loosening the bolts at the flanges and slightly re-aligning the sections by using the play in the bolt holes.
A bit of exhaust expertise can come in handy when doing a realignment - customers often self-install and then take it in to their favorite exhaust expert to get it aligned just right.
Those NAPA mounts sound just great - the more solid the better!
Finally, I've tried the radiator clamp in the past and that approach can work real well. I put the clamp around the outside of the hanger, so it still has the rubber cushion but the clamp prevents excessive movement.
Brian
__________________
Brian C Catts, Cattman Performance
Tucson, Arizona
520.575.6195 for ?s and 800.759.9920 to order bcatts@cattman.com www.cattman.com
Cattmobile FOR SALE: [pics here] 02 6M Maxima SE w/ CP intake, headers/y-pipe, FastCat, Catback, short shift kit, coilovers, FSTB, Progress RSB, NEW 245.45.18 Toyo Proxes4 tires on perfect 18x8 ROH DriftRs, 243whp, only 59k miles and never abused (true). Price reduced to $9499!
Brian
I made sure that I read everything correctly and I even had help installing the exhaust. I'm going to try the new mounts to see if it solves the problem. Cause I know that everything was done correctly and everything lined up perfectly, I just think that the mounts are worn out and give TOO much play.
__________________
What were the corrected numbers? The correction logarithms in the dyno software that account for the three "weather" variables - temp, humidity and atmospheric pressure - aren't perfect and they vary between dyno machine companies, but better than dead reckoning. Temp is the #1 factor of the three, but unfortunately a lot of dyno shops don't measure or look up the humidity. Did the same technician do the run each time and were you on the same tank, or at least brand/grade, of gas? These factors are actually quite important.
Brian
Let's see:
Same Tech
Fuel - Same Grade/Station - New tank
Numbers are not corrected - I guess I should go ask about that.
The humidity is listed for both runs but I'm not sure if the computer calculated it or if it's old data. This was my first dyno run so I don't really know much about the machine.
the weather varies so drastically out here it's nearly impossible to get close to the same conditions. I miss CA so much
Same Tech
So I went to napa today, well the part exh35725 isn't a solid piece. It looks just like the oem mount.
Sorry I got my mounts mixed up with the Nismo in the same bag and some fell out of thier boxes. But the NAPA mount are just as stiff as the Nismo brand if not stiffer, it should help control that big pipe of yours! Try twisting that MOFO...they're way stiffer than Oem!
Dyno says not until you get around 5500-6000. But everything seems to respond so flawlessly I guess it may have something to do with vaccum/more airflow in and out. That although my horsepower gains were "minimal" by the computer. the butt dyno and the distance between me and the other guy says differently. I plan on adding a turbo; but even without one I don't think I'd change my mind on the 3" for a basically stock system. Especially once I get the other add-on's (headers, test pipe and of course the tune). that is probably my biggest mistake right now. Not having a tune.
Hi Guys: I went to the track last week w/ my son, and both of us did not get a good ET, his ET was in the 2.3 60' on MT street tires, and I did 2.35 & 2.48, and what ever I do I break loose 1st & 2nd w/ Nittos DR 20psi, and the Tockico Illumina adjusted @ fronts 3 rears 5. Last Summer I did 13.36mph @ 106.87. Now after installing the 3" catback, I'm sure I have gained between 15 & 20 Whp, and to prove my point I will get it on the same dyno, and let you know, also I will get the slicks, and show you another Video with a better E.T.
from looking online the solid exhaust hangers are EXH35460(same price as the ones you looked at). They look like they will not budge, which is good.
__________________ Formerly Rogertight
Other car 1986 maxima: 3rd gen suspension , HID projectors(phillips 85122+ D2S bulbs), other goodies--> http://www.cardomain.com/ride/520274STILL IN THE FAMILY
Those were found on the rear muffler right? Even the 375's are super stiff....
yeah, looks like it will work for all 3 of the muffler hangers( or exhaust insulators as napa calls them).
Go to the store and search thru thier exhaust manual...there are lot of parts that you can find from other cars for special projects for the cheap! Those Nismo are heavy duty but not totally bullet proof for the money spent ...the Napa's are just as durable if not more! Go to the store and do the twist test Napa's hangars are super stiff and the hole is super tight so it won't slide around on the hangar once installed. My Cattman 2.5" exhaust I noticed would contact something in extreme hard high speed, high G, right hand turns...My Nismo rubber hangar was allowing the exhaust hangar to slide thru the rubber hangar and contact the chassis hangar mount with the bpipe. So I shimmed them with old rubber shock mount rubbers and i haven't heard a dam thing since. I love taking thing these highway clovers turns as fast as I can so far 60-65 mph no tire squeal yet!
What's the verdict on this? Is there anyone still signing up for this catback? I'm on the list and need an exhaust. Would like to see more people in so I can hurry up and get this in.
According to Brian, production should resume in November. I think he said he needed two more to sign up.
__________________
94 F22B2 CD6 G77M 5MT- daily bucket
Will be one day modded 02 A33B KT3 6MT 241whp/227wtq ET...14.480
COMING SOON - SFR TURBO
Interested in owning/operating an automotive repair franchise?
P/M me for details.
Quote:
Threads on the Org are a lot like cable TV. When there isn't a lot of constructive things to read or write, we can always change the channel.
Good Deal!
Quote:
Originally Posted by mist max2000
oh man.. i would love to jump on the wagon for that.. but i wouldnt be able to come up with the funds till after the new year.. so..
It'll take a few weeks for them to produce them after the goal has been reached, and also Brian doesn't charge your card until they are shipped out. Jump on the Chariot!
If we get too late in the year, the production will shift to January - don't want to pay tax on year-end inventory, so we want to have bare shelves on 31 December. That said, we'd be happy to do a small batch of 3" catbacks before then, but I'd need at least 8 orders to do that before the end of the year.
Brian
__________________
Tucson, Arizona
Brian
Thanks Brian. Anything to get this moving faster for the few that are awaiting would be great. How many do we have at the moment, and how many more do we need?
to the people with banging problems, seriously try the hose clamps method. You can put the clamps on every hangar and use the adjustability in the clamps to move the exhaust quite a bit. Even if you only hit in one place, messing around with all the hangars will make it pretty easy to avoid that. An added bonus is that you can make the muffler sit really still, even during wheel hopping, which obviously will help you keep from ruining exhaust gaskets while your exhaust is hopping around (and you wont look like a huge ricer having your exhaust flail around)
Brian
sounds good to me sorry others who are waiting.. but after the new year.. i will be in
__________________
| 2002 6speed|Progress RSB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|HID fogs|eyelids|Hella Supertones|HD CatchCan|Berk Intake w/ Apexi filter|
Parts I own waiting to go on:| stillen classic kit|GenI cattman headers|Test Pipe|SAFCII
In regards to the "fitment issues" some of you are experiencing:
Listening to Brian is your best bet. I didn't want to listen because I thought there was no room for play in the exhaust and that the half inch adjusting it would give me was not enough.
I got under my car, loosened every bolt from the cat back had pmohr holding the muffler and different sections solid while I moved / aligned different parts.
i.e he held the b-pipe while I moved the straight pipe to see what clearance that gave me.
Before that I tried a ton of things to get the rattling to go away, after spending an hour on my back aligning the 3" I didn't hear another rattle...
__________________
1997 Volkswagen Jetta TDI
TDI = Turbocharged Direct Injection NOT Turbocharged Diesel Injection.
You could go this route... except with my limited expertise, there is a reason exhaust mounts have play in them, and that is because they are not suppose to be mounted in 1 location. Due to the motion of the engine... the exhaust needs to have play in it or else something could / will snap (a hanger, a flex section in your y-pipe, etc). Also by doing this there is no fluid motion to the exhaust anymore, no way for the mounts to cushion a jolt from another area... I would read my above post for a better solution.
just my 2 cents
__________________
Sorry to bring a dead thread back, but has anyone dynod yet? i see maxlife's dyno but its pretty much useless to have an uncorrected dyno that only states some peak numbers...I really want to see a real comparison here
This link was posted on the first page of this thread...
2.5 Inch Exhaust
4,500 RPM 191.88 HP 223.94 Torque
5,000 RPM 216.38 HP 227.29 Torque
5,500 RPM 231.13 HP 220.72 Torque
6,000 RPM 237.81 HP 208.17 Torque
6,500 RPM 221.92 HP 179.33 Torque
3.0 Inch Exhaust
4,500 RPM 209.32 HP 244.30 Torque
5,000 RPM 232.01 HP 243.71 Torque
5,500 RPM 244.90 HP 233.87 Torque
6,000 RPM 244.15 HP 213.72 Torque
6,500 RPM 239.31 HP 193.39 Torque
some numbers for you as well
and to quote my friend pmohr (don't take any of it personal as it was directed at someone else)
I was intending to say besides yours. Since your dyno seems to be the only one that is actually a fair comparison, I was hoping there would be a sort of confirmation dyno by someone else. Two dynos are always better than one, and I would think that with the number of systems that have gone out that there would be something by now
I'm bumping this thread to create more interest and orders to get this going. If I could buy one without you guys it would have been bought already. Need more peeps in on this deal!
Brian- What's our numbers look like now? How many do we have, and how many do we need to get this rolling.
Anyone out there with one already wanting to sell theirs, shoot me a message. New batch looks indefinite until we get more headcounts.
Wasn't there suppose to be a before and after dyno the OP was suppose to do???
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1' http://www.youtube.com/watch?v=jlvEqClE9R0
