Just resurfaced the brakes
Old 02-28-2009, 05:07 PM
a33i30's Avatar
They were squiqing, so I resurfaced the the Pads(they still had alot of life in them) and the rotors(it was a PITA since it was 90 degrees outside and the car's fan was on). Now my problem is that it feels like the car doesn't stop as well as it used to, even tho its quite. Will it get better or is it going to stay bad like this
a33i30 is offline
Old 02-28-2009, 05:17 PM
RLW001's Avatar
You should follow the "bed-in" procedures for your pads.
Here several recommendations by manufacturer.
http://www.tirerack.com/brakes/tech/....jsp?techid=85
RLW001 is offline
Old 02-28-2009, 05:30 PM
a33i30's Avatar
Yea I did that, it says you have to drive 400 miles for best performance, I guess I have to wait.
a33i30 is offline
Old 02-28-2009, 05:33 PM
sublime258's Avatar
I'm pretty sure the pads had a certain coating on them when they were new, that is transferred to the rotor during the bed-in procedure, which creates an ideal surface on the rotor for the pads. How exactly did you "resurface" the brake pads?
sublime258 is offline
Old 02-28-2009, 06:08 PM
I'm watching you, boy...
SilverGLE's Avatar
He probably lightly sanded them with sandpaper... I'm getting RTP blanks to replace my Napa blanks up front (damn uneven pad transfer) and will be lightly sanding my Hawk HPS before I attempt to bed them in.
SilverGLE is offline
Old 02-28-2009, 06:51 PM
Demodded and Forgotten
rroderiques77's Avatar
"Resurfacing" pads
Once the resin from the new pads gets bedded into the rotors, resurfacing them will decrease stopping power. That is why the burnishing procedure is so important. The noise you were experiencing will most likely return.
http://www.bendixbrakes.com/techCorner/faq.php
rroderiques77 is offline
Old 02-28-2009, 10:27 PM
a33i30's Avatar
Yup lightly sanded them with wet sandpaper, it actoully did the trick, they started working real nice and the surface looks brand new.
a33i30 is offline
Old 03-01-2009, 07:09 AM
nsnrider's Avatar
did you grease everything up before you put it back together?
The moving parts NOT the friction surface, of course.
nsnrider is offline
Old 03-06-2009, 12:06 PM
a33i30's Avatar
I used CRC Brakleen brake cleaner to clean the moving parts, works good but finishes fast.
a33i30 is offline
04-16-2020 05:15 AM
06-06-2017 02:01 PM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Just resurfaced the brakes
