Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 02-18-2009, 06:18 AM   #1
Send a message via ICQ to N16_VQ_SWAP Send a message via MSN to N16_VQ_SWAP
Utec
hello
which wiring /terminals are important to install the Utec into a 5.5 maxima?
thanks
N16_VQ_SWAP is offline   Reply With Quote
Old 02-18-2009, 06:38 AM   #2
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
IIRC, it'll just be similar to the Emanage Ultimate... basic ones would be:
Injector signal (for all cylinders)
Ignition signal (for all cylinders)
MAF
TPS
Knock
Power (probably ECM power)
Ground (probably ECM ground)
I'm sure there are more.... I'll see if I can find a good thread.
And because the UTEC is set up for a 350Z/G35 type ECM harness, you'll need to do some remapping using the Z33 wiring diagrams.
PM SurraTT, I know he's worked on this before.
Puppetmaster is offline   Reply With Quote
Old 02-18-2009, 06:41 AM   #3
Super Moderator
Okay, here you go:
UTEC is in..........
Old 02-18-2009, 06:48 AM   #4
yes i read this post but what is with cam senor 1 +2 ?
Intake Temperatur? and the rest?
i have pm'd supra tt.. but he is not online......
thats my wiring
but not go
Old 02-19-2009, 12:55 PM   #5
which terminals must i connect?
Old 02-20-2009, 02:24 AM   #6
I have make a list, can you check it?
Injectors:
1, 3, 12
2, 11, 13
Ignition:
5, 7, 16
6, 15, 17
Crank Sen:
95
Cam Sen. 1: ???
65
Cam Sen. 2: ???
85
Knock Sen. :
71
MAF:
62
Intake Temp. : ???
66, 80
TPS1:
83
TPS2:
84
Power ECM: ???
110 or 43 or 42
Ground ECM: ???
106, 107, 108
IVT 1: ???
IVT 2: ???
O2 ?? ???
APS1: ???
73
APS2: ???
74
Throttle Control Motor: ???
101, 103
Is all correct ??? anything forget?
Old 02-21-2009, 11:31 AM   #7
hello???
Old 02-21-2009, 03:32 PM   #8
HandyMan
SurraTT's Avatar
Send a message via AIM to SurraTT
dude its a lot more complicated than that.
if u have a 02 max ECU u have to compare the max pinout to the 350 pinout and figure out what is what. obviously the wires arent in the same order/layout........
one of those measure twice and cut once deals here...
so do you have anything hooked up, or what are you doing??
is ALL you need is what wires to hook up?? if so then its just the basic tunning stuff,
ECU Pinout cheat-sheets (large images, 1000+px wide)
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
1990SE5SpeedPartscar
1987SE5Speed Started it all!
SurraTT is offline   Reply With Quote
Old 02-21-2009, 03:39 PM   #9
HandyMan
SurraTT's Avatar
ok so i looked at the pic, and i see u put the max connector on the utec..
soo now ur trying to put the 350 plug on the engine harness????
if so. then it does not matter what wires the utec uses if all are going to it ne way
sooo umm did u hook the right utec wires into the max plug??????
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 02-22-2009, 01:48 AM   #10
noo the pic is old. i cut all.
and now i need only the the right pins to connect the utec. NOT fully plug and play! I need only the once wires.....
is the list correct?
which pins are important for the Utec?
Old 03-12-2009, 08:17 AM   #11
hello
i have connect all important pins but whats with the pin 34 ? RPM.. need the Utec this?
thanks
Old 03-12-2009, 09:01 AM   #12
The Dirty Pearl
pmohr's Avatar
Quote:
Originally Posted by N16_VQ_SWAP View Post
hello
thanks
The Z33 DE doesn't have an RPM output at the ECU, the UTEC uses other means to determine RPM.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 03-12-2009, 02:08 PM   #13
Ok... but why dont start my car with the Utec? without runs good.....
Old 03-12-2009, 02:11 PM   #14
The Dirty Pearl
pmohr's Avatar
Well have you checked why it's not starting? Fuel, spark?
What map are you on?
__________________
Old 03-13-2009, 07:54 AM   #15
hello
i have connect all cable new, complete new wiring and i think its all correct connect....
spark, injectors Walbro pump runs before and not with the utec now....
I have install the 2.8 software on the Utec... map? i switch it on position 0, the utec use the original specification from max ecu or?
I dont can connect the utec with my laptop... i have windows vista installed and dont works... Windows vista dont have hyper terminal... which program can i use for perfect work/connection under windows vista?
do you have the utec in your car?
I ahve a 02 max engine with following mods:
- 350z complete intake manifold
- 350z injectors
- 350z thermostat
- iridium sparks
- 350z fidanza flywheel
- exedy stage 1 clutch
thanks for your help
Old 03-13-2009, 08:21 AM   #16
The Dirty Pearl
pmohr's Avatar
So no spark and no fuel now?
Have you triple checked all of your connections, and pinouts?
__________________
Old 03-13-2009, 08:27 AM   #17
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
hello
- 350z injectors
- 350z thermostat
- iridium sparks
Just found out that with Vista, you have to make hyperterminal active. You might have to go into the control panel or windows settings and turn that feature on. I didn't think that it had it either, but my roommate found it. Probably want to google search that one.
__________________
GI: 19" x 8.5" +33 Offset Rare Millie Miglia Evo5
In One's Own Tune, Balance Is Found In The "Area Under The Curve".....
Deckdout2 is offline   Reply With Quote
Old 03-13-2009, 08:37 AM   #18
just by a cheap lap top with xp, or 98.......
tonedef is offline   Reply With Quote
Old 03-13-2009, 11:15 AM   #19
no no fuel is going... spark i dont no.....
into the utec software download is hyper terminal 6.3 but i dont come into the utec main menu.. i think its dont connect to the utec.....
when i switch the utec of MAP 0, used the utec the original max configuration?
i have patched the new version ( 2.8) on the utec.... so the old maps of the utec its delete or??
S H I T utec i hate it now.... i will start my engine....
its run without utec! here is a movie from it....
http://www.youtube.com/watch?v=oUXpSliXvJM
But i have a Nissan Almera N16 ( Sentra XE B15 ) an swap a 3.5 V6 into....
Old 03-13-2009, 12:03 PM   #20
sparks03max's Avatar
Sounds like your pinouts are wrong. Remember you need to get a wiring diagram of the 350z ECU and one of the maxima and match up the pinouts. The way I did this was to make a chart with the things I needed IE what puppetmaster listed:
"Injector signal (for all cylinders)
MAF
TPS
Knock
Ground (probably ECM ground)"
then put a column for 350z pins and another for maxima pins, then write down which ones go to each. From there you can isolate the 350z pins/wires that are on the UTEC and connect those to the correct wires on the maxima harness/ECU.
__________________
2003 SE 6MT Titanium Edition - Sterling Mist
Power mods: SRI, VIAS Delete, NWP spacers, Cattman Headers, Custom exhaust, TurboXS UTEC + Tuner
12-second 5.5 gen track vid: http://www.youtube.com/watch?v=HDz_fIHZgig
sparks03max is offline   Reply With Quote
Old 03-13-2009, 01:29 PM   #21
i use this page for the correct connection
i drive tomorrow to my garage and make pics for you..... iam sure my wiring is correct...
The 350z and max have the same cranks sensor?
its windows not combatible with the utec? i install hyper terminal 6.3 ( its into the 2.8d software package) put i dont open me the utec menu.....
i dont have a old pc or laptop with windows xp /98se......
and a other program for the utec?
when i connect the utec with the hyper terminal then i have a whit screen into the window....
Old 03-17-2009, 01:42 PM   #22
i have a new pic
But the engine dont start ....... wiring its all checked and OK
whats wrong?
My OBD Tool tell me mistake 335 Crank posi sensor.... i have installed the 02max sensor... must i need the 350z now???
chris
Old 03-19-2009, 01:58 PM   #23
Old 03-19-2009, 02:39 PM   #24
The Dirty Pearl
pmohr's Avatar
You mean P0335?
The Z33/A33B CKPS' are identical.
More than likely you damaged the CKPS wire, or tapped into it incorrectly.
__________________
Old 03-19-2009, 03:37 PM   #25
HandyMan
SurraTT's Avatar
+1
if your getting crank pos sensor code. then check that pin, and the wire..
and my 02 max actually ran with out a crank pos one time. so idk if utec will allow that. but some how my car did. it just took 20 seconds or so of cranking.
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 03-19-2009, 03:43 PM   #26
The Dirty Pearl
pmohr's Avatar
Quote:
Originally Posted by SurraTT View Post
+1
Yep, they'll run just fine without a CKPS on there, but IME it'll take forever to start up (reverting to getting timing info from the CPS', my best guess), you'll have no tach, and it'll be down on a bit of power (disables CVTC and reduces engine power on purpose, I believe).
__________________
Old 03-20-2009, 03:50 AM   #27
without ckps runs the engine? why my not? ok i check the wiring
again, but i think the wiring must be ok.......
S H I T VQ swap .....
hey SurraTT please come to my to germany and help me ;-)
i think the 350Z becomes the tach over canbus.....
Old 03-21-2009, 11:15 AM   #28
hello
please look at my picture from utec... the TPS is at 72% is that OK ?? The engine is NOT running!!!
Its to high, or???
I have check the POWER and Mass from ign coil, injectors, Crank pos, cam posi MAF... its all ok.....
Have one of the Utec user here a pic from his utec? ( engine dont run! )
edit:
I have found a pic at the 2.8d download file
and here is my file
PLEASE LOOK AT TPS
Old 03-24-2009, 02:05 PM   #29
hello
i have deinstall the Utec... now runs only my maxima ECU and the engine runs good....
So what is the problem??? Whats wrong?
thats all connected:
MAF
TPS
Knock
But TPS, all TPS wiring or only TPS 1 signal ??
And MAF only signal or all from MAF ???
Is one guy here, it have
successfully run into max???
Old 03-24-2009, 02:21 PM   #30
HandyMan
SurraTT's Avatar
so whats the problem????
when the utec is in the motor dont run. ok
does it crank???
getting Fuel?
spark?
there is no "hook this up" and it will work just fine answer......
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 03-25-2009, 07:12 AM   #31
hello
yes when the UTEC is out, the engine runs..... Utec is in engine not run.....
Fuel OK
CKPOS is brocken,but the engine runs without Utec
spark all 6 signal connected
Can you tell me which pins exactly for the right connection?
SPARK:
Pin: 62 , 61 , 60 , 81 , 80 , 79
INJECTOR:
Pin: 23 , 22 , 21 , 42 , 41 , 40
KNOCK SENSOR:
Pin: 15
CKPOS:
Pin: 13
MAF:
Pin: 51
No Intake temp, ground or power?
TPS:
Pin: 50
Only TPS 1? whats are with TPS2, throttle actuator, throttle relay?
Ground:
Pin: 1 , 115 , 116
Power:
Pin: 109 , 119 , 120 , 121
And whats are with the rest?
IVT , cam posi 1 + 2 ?
Have you successfully connect the Utec into max and runs the car?
here a movie w/o Utec and the engine run
http://www.youtube.com/watch?v=bYOFBuVikcU
Old 03-25-2009, 07:21 AM   #32
HandyMan
SurraTT's Avatar
if you are hooking those wires up, it should def run
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 03-25-2009, 07:27 AM   #33
hmm... but it dont start.
I have download the base map and parameters from TurboXS
And install the 2.8d version....
must i modify any settings into the base map or is the base map so ok?
Old 03-25-2009, 08:49 AM   #34
Play with my balls
Deckdout2's Avatar
Can you provide a picture or 2 of what exactly you have going on there? With the wires spliced from the UTEC and 1 of where it's actually connected to the ECU.
__________________
Old 03-25-2009, 11:03 AM   #35
HandyMan
SurraTT's Avatar
that dont matter, if the utec is on 0 which is stock ECU,
if the car dont start/run on map 0 then its a wiring problem
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Old 03-25-2009, 11:33 AM   #36
Play with my balls
Deckdout2's Avatar
+1
Old 07-01-2009, 08:39 AM   #37
hello
i have the Utec new installed but the engine dont start with the utec.
PLEASE PLEASE help me!
Here are pics from all
Old 07-01-2009, 08:46 AM   #38
more pics
whats the mistake?
Old 07-01-2009, 10:51 AM   #39
The Dirty Pearl
pmohr's Avatar
So again, why won't it start? Fuel? Spark? Have you checked anything?
__________________
Old 07-01-2009, 12:10 PM   #40
HandyMan
SurraTT's Avatar
Holey Wiring Batman!!!
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
