Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-01-2009, 01:30 PM   #41
The Dirty Pearl
pmohr's Avatar
Also, why is your TPS reading 74% at rest?
And why would you take pictures of a computer, to load them into a computer to post them here? Learn the power of the 'print screen' button.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-01-2009, 01:51 PM   #42
If its not even turning over its a wiring issue man, re check the wiring once it turns you can go from there and in pin point what the car needs to fully turn over.
* Language barrier over the net for the loss.
__________________
" The pursuit of happiness, one horsepower at a time "
RacerX1320 is offline   Reply With Quote
Old 07-01-2009, 01:53 PM   #43
The Dirty Pearl
pmohr's Avatar
Turning over is generally interpreted as starting, not cranking.
90% of the time I see it as this meaning, but every so often someone calls cranking 'turning over'.
Indeed, incorrect terminology just makes things so much harder for everyone.
__________________
Old 07-01-2009, 02:11 PM   #44
Send a message via ICQ to N16_VQ_SWAP Send a message via MSN to N16_VQ_SWAP
I check tomorrow the spark, fuel and injectors WITH UTEC
w/o Utec runs the engine!
Yes... why is my TPS so high?
I have connect:
all 6 injectors
all 6 coils
TPS1
MAF
Intake temp
CKPOS
KS
Power
Ground
more not!
Its all Utec settings OK??
But my CKPOS is damage.
How can i change the TPS reading?
Is that the problem?
PLease help me
N16_VQ_SWAP is offline   Reply With Quote
Old 07-01-2009, 02:29 PM   #45
The Dirty Pearl
pmohr's Avatar
I have connect:
all 6 injectors
all 6 coils
TPS1
MAF
Intake temp
CKPOS
KS
Power
Ground
more not!
PLease help me
You probably connected to the wrong TPS wire. There are two, they have opposite readings. What wire color did you tap into for the TPS?
If your CKPS is damaged, why don't you replace it? It will cause a very hard start, and depending on what you've done to your wiring, very well might not start at all.
Which wires did you intercept, which did you tap?
__________________
Old 07-01-2009, 03:09 PM   #46
HandyMan
SurraTT's Avatar
Send a message via AIM to SurraTT
you NEED
TPS 1
TPS 2
APP1
APP2
if the utec is NOT getting these it will read 74% , like when the utec is given power out of the car, for updating or map editing etc...
__________________
336-338-3570
HAVE:
2002 SE 6Speed KH3
2002 SE Auto
HAD:
1985300ZX5Speed
1992SEAutoAztecRed
1992SE5SpeedKH3
1990SE5SpeedPartscar
1987SE5Speed Started it all!
SurraTT is offline   Reply With Quote
Old 07-01-2009, 03:17 PM   #47
The Dirty Pearl
pmohr's Avatar
Quote:
Originally Posted by SurraTT View Post
you NEED
TPS 1
TPS 2
APP1
APP2
Interesting.
__________________
Old 07-01-2009, 03:27 PM   #48
you NEED
TPS 1
TPS 2
APP1
APP2
Are you sure?
All tell me only TPS1....
Is that my Problem why the engine dont start?
now TPS1 white wiring (pin 50 at the 350Z ECM
TPS2 is blue and not connected
Supra TT which other wiring must connected
TPS1 + TPS2
APP1 + APP2
more??
thanks!
Old 07-02-2009, 02:30 PM   #49
so, i have installed TPS2 and APP1+2 and now is my TPS reading 0% and not 74% :-)
But the engine dont start! My injector dont work!
Its all correct connected, i have check it.
It is a wrong setup setting?
My coils work, i have spray break cleaner into the manifold ;-)
Fuel pump work!
Old 07-02-2009, 02:32 PM   #50
The Dirty Pearl
pmohr's Avatar
Fuel pump work!
One quick and easy check for the injectors is check the security light, it shouldn't be on when cranking or with the key on.
Does the tach show anything while cranking?
__________________
Old 07-02-2009, 04:05 PM   #51
hello
do you mean the MIL into the cluster? My tach dont go! I have a sentra tach ( 4cylinder) and the max tach have a other impuls.....
I dont understand what do you mean.
Sorry my englisch is not so good.
I think its a wrong setting???
SurraTT have you a pic from your Utec Dashboard?
Is my MAF Voltage to low (1,07V ) ?
Old 07-02-2009, 04:23 PM   #52
The Dirty Pearl
pmohr's Avatar
hello
SupraTT have you a pic from your Utec Dashboard?
No, not the CEL, the security light.
Why are you using a Sentra tach? That doesn't even make sense.
Nevermind, I see you swapped into a Sentra. Actually mentioning that in the first post, rather than a small 'by the way' would be helpful. You know, minor details.
So it runs without the UTEC? Has it ran since the last time you disconnected the battery?
__________________
Old 07-02-2009, 04:37 PM   #53
where is the light?
Yes i have a Nissan Almera N16 ( its the same as the Sentra B15 )
And i swap a VQ35DE into my Car. The engine run w/o Utec. I drive with it last week.
which details you are need?
Yes the battery was disconnected but not at the start. i have programm the TB but with UTEC it dont start.
Is all oem settings from utec OK for a start?
i dont change settings!!!its all from the turboxs Homepage.
must i connect the start wiring from the ignition key / max ecm?
Old 07-03-2009, 02:37 AM   #54
where is the mistake???
must i change any settings?
can anyone check my settings at my pics?
Old 07-03-2009, 03:02 PM   #55
Must i connect the HO2 sensors?
From the ESM:
On Board Diagnosis Logic
NFEC0912
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual
mixture ratio can be brought closely to the theoretical mixture ratio
based on the mixture ratio feedback signal from the heated oxygen
sensors 1. The ECM calculates the necessary compensation to
correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large
(The actual mixture ratio is too lean.), the ECM judges the condition
as the fuel injection system malfunction and light up the MIL
(2 trip detection logic).
PLEASE can anyone tell me which all terminals i need!?!? PLEASE....
And what is with the START SIGNAL ???
Old 07-04-2009, 10:08 AM   #56
PLEASE PLEASE PLEASE HELP ME
Old 07-05-2009, 04:06 PM   #57
why don't answered anyone of my question?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
