Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-30-2009, 09:05 PM   #41
Send a message via AIM to kcxd35 Send a message via Skype™ to kcxd35
The Nissan tech said that sludge is causing a rattle only at 1900-2200rpm? lol....And that the fix is to change everything timing related?...lmao......ok, I so wish I went to mechanic's school cause they get paid like $70/hr to say crap like that to people...Best laugh i've had all night...thx...
__________________
03SE 6SPD T.E. w/ Meridian Package & HLSD, Short Ram Intake, JVC Touch Screen DVD Player, 2 10" AudioBahn Subs, Timing Advanced(16), ES Shift Bushings & Mounts, STS Mod, H&R Spacers, Big Brake Kit, VAIS Block Plate, Borla ProXS.
http://www.cardomain.com/ride/3173853
kcxd35 is offline   Reply With Quote
Old 04-02-2009, 05:46 PM   #42
Rattle, not pinging
I've got a similar sound coming around the same RPM. It sounds more like a rattle/buzzing. Like a piece of sheet metal vibrating at resonance. It never happens while in park or nuetral, only onder load. I checked my cat heatshield, and could not find anything wrong there. I have had the P0133 code come on 9 times over the last 20K miles. Maybe i should change it, and see if that eliminates the rattle.
KWAK is offline   Reply With Quote
Old 04-02-2009, 05:59 PM   #43
It is not the cat because i have a test pipe and the noise is still there. It only happens when the weather is warm.
SpooledVQ35 is offline   Reply With Quote
Old 04-03-2009, 01:41 PM   #44
Not a wear issue
My Maxima has been making this sound since a couple of weeks off the lot after purchasing new in October 2001. I have never had the problem properly diagnosed, but I know that it is not related to sludge, low oil, or any other wear issue. The earlier post regarding multi-pot fuel injection is the most plausible explanation that I have heard.
RichBFL is offline   Reply With Quote
Old 04-07-2009, 04:51 PM   #45
Send a message via AIM to sublime258
Does anyone else get this rattle at higher RPMs? Like 2000-2500?
sublime258 is offline   Reply With Quote
Old 04-07-2009, 05:21 PM   #46
Quote:
1700-2300 read the previous posts...
__________________
Old 05-14-2009, 06:26 AM   #47
2003 Ping (Pre-Ignition)
I have 2003 Max SE with engine ping between 1800 and 2200 RPM. Of all the posts I think there are three that are possibilities for the problem.
1. MAF replacement
2. Inefficient cylinder head cooling
3. MPFI vs SFI
Has anyone investigated these possible causes more in depth? If so what was the result? How did you arrive at diagnosing the final solution?
Steve
Palmyra_Pet is offline   Reply With Quote
Old 05-14-2009, 09:41 AM   #48
Lift your hood and vsually inspect your heat shields from the manifold to the rear muffler! Does it sound like it's coming from the engine compartment or from under the car?
__________________
CMax03 is offline   Reply With Quote
Old 05-14-2009, 11:22 AM   #49
Quote:
Originally Posted by Scottwax View Post
Interesting. I had my TB cleaned (rather pay someone $40 than mess it up and have to buy a new DBW TB) and my idle went from around 600 to what appears to be around 725-750 or so. The FSM states that a 700 rpm idle +/- 50 rpm is normal. I haven't noticed that pinging sound since and that is with much quieter tires and doing the rear window wind noise fix so my car is quieter.
Maybe I am not listening hard enough but it has always been quite faint even when I do hear it.
I have an annoying driver side rear window wind noise too. Is there a way to fix it besides replacing all of the weather stripping? I figure its just one little piece that's causing a problem.
__________________
2002 I35 | Cattman RSB | 235/45 R17 Yokohama YK520 | GAB K&N drop in
d-schist is offline   Reply With Quote
Old 05-14-2009, 03:20 PM   #50
Send a message via AIM to dineth00i30
i have this on my 2k i30 too. i happens little pass 2k around 2.1k. its not coming from the engine its coming from under the car near the driver area. Also one of my heat shields fell off one time and i think after a while this sound started to happen.
__________________
| Tint | Grounding Kit | 8k Heads & 3k Fogs | Clear Corners with L.E.D's | Hyper White L.E.D License Plate | Half Roof Spoiler | Black Roof Vinyl | 12" Sub with 400w AMP | Smoked Tails | S-tech (F) H-tech (R) with Illuminas |
dineth00i30 is offline   Reply With Quote
Old 06-04-2009, 01:37 PM   #51
i have the same problem it gets really annoying and makes the car seem like a piece of ****. i think its coming from some part of the exhaust. idk i cant pin point it myself. it cant be the oil, the car performs fine.
imaking133 is offline   Reply With Quote
Old 06-07-2009, 12:03 AM   #52
i think its the MPFI vs SFI
rqgray@comcast.net is offline   Reply With Quote
Old 06-07-2009, 10:49 AM   #53
boondoxmax's Avatar
I have it but just deal with it. It's not that bad. 6 year old car not worth tearing apart to figure out what is causing it. My car runs awesome except for the rattling at low rpms
boondoxmax is offline   Reply With Quote
Old 06-07-2009, 11:34 AM   #54
You can eliminate the "flooded"? valves & MPI theory. The system normally does operate with SFI. For engine starting and if it ever goes into "limp-home" mode, it operates in MPI mode. Right out of the FSM.
P. Samson is offline   Reply With Quote
Old 08-23-2009, 07:34 PM   #55
Send a message via AIM to infinitiblast
I just want to confirm with everyone else, that its not oil related. Wifes car has been doing this for a few weeks now...Oil level was low, needed an oil change anyways.
Drove it today after the oil change, and still the same issue. And its right around 1900rpms in 4th gear for me. I'm going to try a few things over the next month or so...if anything fixes it I will let everyone know.
__________________
I miss my Sterling Mist Maxima.
infinitiblast is offline   Reply With Quote
Old 08-24-2009, 03:18 AM   #56
I eliminated that rattle sound I was getting around 1800 to 2000 rpm. It turns out that it was a heatshield. The heatshield in question is just forward of the cat, above the flex hose connecting the headers to the cat. Once the mechanic put a clamp on it I have never heard the rattling again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
