Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-21-2009, 07:52 AM   #41
Send a message via AIM to VqMoNsTeR Send a message via Yahoo to VqMoNsTeR
Quote:
Originally Posted by Scottwax View Post
I'd be leery of a $1600 rebuild. That seems about $500 or so lower than the going rate for a stock rebuild, let alone one with heavy duty clutch packs.
I will say that a properly built high performance automatic with heavy duty clutch packs and a properly programed valve body does give you really quick, tire chirping shifts. Had one built for my Chevelle and it stood up to a couple years of regular bracket racing as I went from the mid 14s to the high 12s as I continued to mod the engine and changed from 2.56 to 3.08 to finally 4.11 gears. Very consistant performance.
I've seen his work on a auto turbo supra. This is the only tranny guy I know that I've talked to on the phone with for about an hour discussing transmission problems for free..lol. He's a cool dude.
__________________
Dude, that pic is huge. You can't have pics that big in your sig. Sig pic deleted. Read the signature rules.
I Got Stagger Swagga
Maxus09 3.5L All Motor Champ
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
VqMoNsTeR is offline   Reply With Quote
Old 01-22-2009, 03:58 AM   #42
The HKS ALC II might solve the tranny problems.....
After reading this thread, I thought about the HKS ALC II or Auto Line Controller used in my 300ZX. It is suppose to increase and controller the automatic transmissions line pressure for firmer shifts and improved performance. It really works well. If the HKS's ALC II was available for the 5th Gen Max, the problem might be solved. If enough people approach them with this, they might see the demand is worth the R & D and production? See link: http://www.hksusa.com/categories/?id=1959
Click this link: www.hksusa.com/forms/optin.asp
This might get HKS to produce an ALC II for the Maxima. I'd like to see this happen before I start having any transmission problems.
Plug-in interface with factory A/T Control Unit of the computer controlled automatic transmission on the ‘90-’96 Nissan 300ZX. The ALC II is designed to maintain constant line pressure within the transmission for consistent, crisp high performance shifting. Should the pressure begin to drop within the transmission, the ALC II will signal the factory A/T Control Unit to increase line pressure and maintain it at that level.
http://www.hksusa.com/images_products/S_1258.jpg
Last edited by RLStrick756; 01-22-2009 at 10:58 AM. Reason: The HKS ALC II Photo is needed to be inserted
RLStrick756 is offline   Reply With Quote
Old 01-22-2009, 07:45 AM   #43
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Quote:
Originally Posted by RLStrick756 View Post
After reading this thread, I thought about the HKS ALC II or Auto Line Controller used in my 300ZX. It is suppose to increase and controller the automatic transmissions line pressure for firmer shifts and improved performance. It really works well. If the HKS's ALC II was available for the 5th Gen Max, the problem might be solved. If enough people approach them with this, they might see the demand is work the R & D and production? See link: http://www.hksusa.com/categories/?id=1959
Click this link: http://www.hksusa.com/forms/optin.asp
The HKS ALC II has been developed as a plug-in interface with factory A/T Control Unit of the computer controlled automatic transmission on the ‘90-’96 Nissan 300ZX. The ALC II is designed to maintain constant line pressure within the transmission for consistent, crisp high performance shifting. Should the pressure begin to drop within the transmission, the ALC II will signal the factory A/T Control Unit to increase line pressure and maintain it at that level.
I tried that page you linked and when I hit "submit" I got this message:
ADODB.Command error '800a0d5d'
Application uses a value of the wrong type for the current operation.
/forms/optin.asp, line 155
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 01-22-2009, 08:00 AM   #44
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
seeing as we can do the drop resistor mod...why not just make it variable...if all you want to do is change the line pressure.
Torgus is offline   Reply With Quote
Old 01-22-2009, 10:50 AM   #45
The Dirty Pearl
pmohr's Avatar
Quote:
Because you can't do variable resistance in place of the DR. There's a small tolerance of what it'll accept as far as resistance there, otherwise it'll just go for the harsh shifts.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 01-22-2009, 11:33 AM   #46
ahh so it's all or nothing huh?
Old 01-22-2009, 03:36 PM   #47
ALC II For 5th Gen Maxima
The ALC II would be the ideal because it interfaces with the main ECU.
Old 02-10-2009, 10:24 AM   #48
hmm search landed me here. Basically im having the same problem. I experience late 1st gear shifts all the time. Today was the first time i experienced jerky shifts from 2-3 and 3-4 gears. The rpm jumped a thousand revolutions.... i only have 62K miles on my 01 max....love this car but now regretting buying it...
Just curious, (and im a noob) why are manual tranny guys having late shift issues? I thought this problem was exclusive to ATs only....
On the other hand a lot of guys here have high millage and their car is still in good driving condition...just wondering if this problem is merely an inconvenience and doesn't really harm the tranny (provided that you don't floor it every time you step in the car)
denny_1986 is offline   Reply With Quote
Old 02-10-2009, 10:48 AM   #49
Scottwax's Avatar
I don't think anyone is this thread has a manual transmission since it is about shift kits.
Old 02-10-2009, 10:58 AM   #50
lol for some reason i though u did
anywayz u said u had 143K miles on your tranny....is this the original tranny? How long have u had this car and did u experience these late shifts when u got the car? 143K is pretty good if its the original tranny. If it goes another 30K or so then i believe it has done its job...
Old 02-10-2009, 11:51 AM   #51
Scottwax's Avatar
Original transmission as far as I know since I bought the car used with 113,897 miles on it. Just passed 145,000 this morning. The only shift problem is when the engine is cold and the 2-3 shift is really soft or slips 100-200 rpms. If I lift slightly before the upshift, no problems. Once the car is fully warmed up, it shifts fast.
Old 02-10-2009, 02:13 PM   #52
yea same here. I actually dont feel any 2nd or 3rd gear shocks if i stay around 2000RPMs. But when i accelrate a little faster, the car is slow to respond and just suddenly takes off as if i was flooring it....
Old 02-10-2009, 02:27 PM   #53
it's called an auto taking time before it downshifts. sucks. a shiftkit will drastically improve this tho.
Old 02-10-2009, 02:33 PM   #54
u mean upshifting?
Old 02-10-2009, 09:31 PM   #55
Scottwax's Avatar
u mean upshifting?
It will improve both up and down shifts.
Old 02-10-2009, 09:46 PM   #56
Reizy's Avatar
I concur.
Reizy is offline   Reply With Quote
Old 02-10-2009, 09:57 PM   #57
So if i were to get the HD2 kit from transgo, i could put it in myself having only minimal experience? i want to get this, but i dont wana pay some one to do it, i am pretty mechanically enclined, just unsure?
Nightrunner01 is offline   Reply With Quote
Old 02-11-2009, 07:44 AM   #58
Quote:
it's not hard to redo/rework a VB as much as you have to be very careful and precise. replacing a VB is easy.
Old 02-11-2009, 07:49 AM   #59
Scottwax's Avatar
From what I read on TransGo's site, the shift kit comes with both written instructions and a DVD that shows the installation.
Old 02-11-2009, 08:58 AM   #60
how much is it again? if anyone isn't confident doing it just ship it to me w/ you VB. i'll do it for a nominal fee.
Old 02-20-2009, 11:43 AM   #61
shift kit is going in leo's car tomorrow. will let u know how that turns out.
i see on the site it has..."no tools needed" <----lie..lol!!! u will need a drill to make the holes in the vb bigger.
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 02-20-2009, 04:22 PM   #62
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
waiting, if it works, I'm gonna do mine pretty soon.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 02-20-2009, 05:18 PM   #63
Scottwax's Avatar
Quote:
Same here. Not sure if I will do the installation myself or find a shop that specializes in high performance transmissions.
Old 02-20-2009, 09:22 PM   #64
Send a message via AIM to allblackmax96
i installed a transgo kit on my old 4th gen which is still running strong today. i took my time because i had never installed one before but it went smoothly. for the price its a great mod, no regrets on it.
__________________
2002 Sterling Mist 6MT - FOR SALE
allblackmax96 is offline   Reply With Quote
Old 02-22-2009, 04:26 PM   #65
transgo kit was installed. everything works great. every gear is firm but 1-2 is probably the firmest out of all of them. no more slow shifting, delayed shifting or failure to go into overdrive. havent driven it hard yet but will let u know how it goes when i do.
it took the tech about 4-5 hours to do.
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 02-22-2009, 04:28 PM   #66
i think u should find a shop that can do it. those 3 layers of the VB can be tough and if u drop one of those little balls on the ground.....ur tranny is screwed without it.
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 02-22-2009, 04:37 PM   #67
where did you have it done, what ATF did they use? cost?
I want my 1-2 to be firm, so I can floor it without concern.
__________________
Old 02-22-2009, 05:49 PM   #68
Scottwax's Avatar
When I put the shift kits in the TH350 in my Chevelle (twice because I got a new transmission) and my Cutlass, you only reused one of the four check balls. When I put the shift kit in the Cutlass, the tranmission was out of the car, so much easier to do it that way!
Old 02-22-2009, 06:01 PM   #69
it seems my 2-3 shift slip is a bit different then yours. When the engine is cold and I try to let it shift past 2k rpms as normal, it will slip, but not slightly. It will actually feel like the car was thrown into neutral for a second, the rpms flare up, then it shifts. I got pretty good at avoiding it(maybe it slips once every other month now), but im still concerned.
__________________
Blitzfist is offline   Reply With Quote
Old 02-22-2009, 06:44 PM   #70
Scottwax's Avatar
Quote:
Sounds like yours is worse than mine then. Mine will slip at the most about 200 rpms although it usually just feels mushy, but if I let off just before I know it is going to shift, no slip and the shift has decent firmness.
Old 02-23-2009, 11:36 AM   #71
Hill's Garage in Brooklyn, MD. They specialize in Nissans and Infinitis. He has done about 5 on the z's and g35. The max was the first FWD he's done and he did an excellent job.
the labor was $375 and fluid was about $45. They use Valvoline Synthetic ATF. I've always used Mobil 1 synthetic ATF but I let him try the valvoline and so far so good. He did point out that there was a tiny hint of copper flakes in the bottom of the pan. He said it coulda came from 2 places in the tranny, the bearings behind the planetary gears or inside the torque converter (i think). since it wasnt alot he said i may be in good shape.
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 02-23-2009, 11:43 AM   #72
the 1-2 shift was slow as hell. not like it was in neutral...but more like a loss in power....like it was struggling to shift. sometimes my 2-3 would slip about 200 rpm...but only when the 1-2 shift was really slow. at wot the 1-2 would be delayed and sometimes be hard, then 2-3 would bump redline....and 3 wouldnt shift into 4th until later. during heavy driving for long periods of time when fluid is hot, sometimes the car would not go into 4th at all, even if i manually shifted.
all those problems are GONE!!!!
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 02-23-2009, 11:45 AM   #73
why didnt u just take the VB out and put it on the new one???
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 02-23-2009, 03:23 PM   #74
Scottwax's Avatar
First transmission that went out was trashed, I didn't want to use anything that was on it-converter fried, lots of crap went through the whole transmission. Besides, shift kits for that transmission are $35.
Old 03-01-2009, 12:27 PM   #75
Send a message via AIM to vastmax
Seems Summit has the kit for a tad cheaper:
http://store.summitracing.com/partde...rsview=sku&Ns=
Looks like i'm gonna purchase it. I'm gonna review the DVD and instructions to see if it's something i can handle before I contract the job to someone else.
__________________
vastmax is offline   Reply With Quote
Old 03-01-2009, 02:09 PM   #76
Send a message via AIM to sublime258
Just wanted to post an update since I started this thread but didn't follow up. I never got the shift kit because I'm also having a timing chain issue . I have a feeling that the tensioners and timing chain are going to need replaced, and I know that will cost a lot of labor $. So basically I am going to put my transmission issue on hold until I can get this timing chain noise fixed. The timing chain noise is a lot more annoying to me than a slipping 2nd - 3rd shift right now...
sublime258 is offline   Reply With Quote
Old 03-01-2009, 03:44 PM   #77
Send a message via MSN to fishpony
Thanks for the link to summit racing, i think im going to get this done this summer. i just unplugged my drop resistor yesterday and it feels like a completely different car... from what i remember trying to drop my valve body a few years ago, there was a bolt that i couldn't get undone and it kept spinning. Does anyone know what i'm talking about?
__________________
Shift_This
Fiberglass boxes
www.fishercustoms.com
fishpony is offline   Reply With Quote
Old 03-01-2009, 04:07 PM   #78
so I was searching but I didn't find anything on it anymore. Don is not making his VB mods anymore and what about maximumtuning.net? Sry for kind of threadjacking, but it is relevant to VB mods so...
__________________
MODS:
Illuminas + Eibach | Stillen FSTB | Progress Rear Swaybar | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | Stillen Y-Pipe | HKS Rear Section | InJen WAI | Shinjinduo Grounding Kit | 300ZX BBK | Ionic Dynamics Bodykit | Ebay Projectors | Foglight HIDs |License Plate LEDs | Blacked out grills | Pioneer Avic-D3 | Interior LEDs
McSteve is offline   Reply With Quote
Old 03-01-2009, 05:30 PM   #79
Quote:
not timing .....u mean drive belt???
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Old 03-01-2009, 05:32 PM   #80
Quote:
seems like the bolt is stripped!
__________________
Quick 8 Contender
1 3 5
-l-l-l-
2 4 6
R
SHIFT_SEE ME
13.4@106.6
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
