Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-05-2009, 08:44 AM   #1
Send a message via MSN to Professor Send a message via Yahoo to Professor
VSS
Whats the way you can test a speed sensor with a multimeter ?
I got a new cluster and it still dont work, also on the harness behind the cluster there seems to be a fuse in the harness but i dont think its a fuse or if it even has anything to do with the speedo.
the new cluster works but the odo dont move , the speedo dont move, the abs light stays on and the od light blinks, with the origanal cluster it dont do that, there is differences but iam not sure if it has anything to do with it, Speedo worked before i redid the faces, it just stopped working out of the blue afterwords, all wires behind the cluster are in good condition.
__________________
Eibach Springs|HIDs|20% Tint|Custom Stereo|Custom LED Interior|GAB|Brembo Sport Drilled Rotors|Hawk Hps pads |SE Tails|AE Headlight Coversion
SHIFT_auto rolling
Professor is offline   Reply With Quote
Old 01-05-2009, 08:58 AM   #2
Send a message via AIM to djfrestyl
VSS wire is pink/blue in the brown harness. It's meter testable, voltage should increase with revs.
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Old 01-05-2009, 09:48 AM   #3
Quote:
Wouldent that be rpms that increase with revs?
__________________
SHIFT_auto rolling
Old 01-05-2009, 09:55 AM   #4
SHIFT_om nom nom nom
Metal Maxima's Avatar
Cluster's shot, dude.
Metal Maxima is offline   Reply With Quote
Old 01-05-2009, 10:30 AM   #5
Quote:
erm????? its a newer cluster i just got. everything works but the speedo/
__________________
SHIFT_auto rolling
Old 01-05-2009, 11:09 AM   #6
Quote:
Now, did you just plug this straight in or did you mess with it at all?
I have tested a bevy of different clusters to date, all worked fine, so this is new news to me...
Old 01-05-2009, 11:28 AM   #7
Who needs the speedo anyway? Oh wait...
hoppers69 is offline   Reply With Quote
Old 01-05-2009, 11:31 AM   #8
And seriously, it should just work when you plug it in. I have changed a few clusters before in other cars and they all would work fine right when ya plug then in (except for that one ford cluster that was for a non 4x4 and mine was a 4x4).
As others said, I think something is wrong with this cluster. Is it def from the same year car? Does the cluster matter if it was from an automatic and yours is a manual or vice versa? I dont think that should matter, but just wondering.
Old 01-05-2009, 12:07 PM   #9
Both. RPM's increase with revs, but when you test the wire, the voltage reading also increases.
I'm with Metal, sounds like an issue.
__________________
Eclipse CD3000
Old 01-05-2009, 12:45 PM   #10
Cluster is from the same year car as mine but it was fully loaded unlike mine, when i plugged it in Without even opening it, the abs light stayed on, od light stayed on, all the gauges worked but the speedo also on the new one the odo did not count the miles it just stayed there, on the old one it everything works but the speedo, the odo works also, the VSS tests good, the cruise control works, I pulled every single possible fuse in the car, all good, also now it wont talk to the obdII scanners, before it did, unless the guy at autozone was a homo and did not know what he was doing, lean code btw, only other thing i can think of is that fuse looking thing on the wire harness tapped to it behind the cluster, it looks like a fuse but its not, i have no idea what it is.
"i did the test as you stated"
__________________
SHIFT_auto rolling
Old 01-05-2009, 12:49 PM   #11
Identical model, year, but diff options. and yes, its a auto cluster, same as mine, the part numbers are different and the arrangment of some components on the circut board are different.
__________________
SHIFT_auto rolling
Old 01-06-2009, 08:13 AM   #12
__________________
SHIFT_auto rolling
Old 01-06-2009, 10:48 AM   #13
Toolie
knight_yyz's Avatar
sounds like you may have damaged something when you "redid the faces"
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
knight_yyz is offline   Reply With Quote
Old 01-07-2009, 06:09 PM   #14
Quote:
__________________
SHIFT_auto rolling
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
