Cleaned Up The Burger on the Engine Cover
Old 01-03-2009, 07:42 PM
MIK3's Avatar
Was tired of looking at that warped chrome grossness, so I cleaned it up a bit. Eventually, the majority of my bay will be blacked out, so I figure this is a good start. Thinking about doing the "V6" and "3.5" the same color.
MIK3 is offline
Old 01-03-2009, 07:53 PM
Maximized2000's Avatar
looks good. Def. do the V6 3.5.
Maximized2000 is offline
Old 01-03-2009, 07:54 PM
MROTH's Avatar
ya im likin the black...
MROTH is offline
Old 01-03-2009, 07:59 PM
ChrisMan287 is offline
Old 01-03-2009, 08:04 PM
nismowolfe's Avatar
yeah I need to do something with mine too it looks like doo doo. I would like to do away with the whole cover I like the raw engine look. I dont like the way that vacum canister thingy looks though and would like to get rid of it.
nismowolfe is offline
Old 01-03-2009, 08:16 PM
That's Mr. Detail to you
Scottwax's Avatar
Looks much better. Mine has the warped chrome stuff too.
Scottwax is offline
Old 01-03-2009, 08:31 PM
MIK3's Avatar
Working on the V6 and 3.5 right now, pics soon.
MIK3 is offline
Old 01-03-2009, 08:51 PM
MIK3's Avatar
Actually just did that 15 mins ago! I have the NWP block plate, so there is no need for it or it's sensor. No CEL when censor is unplugged either. Here's what it looks like.
MIK3 is offline
Old 01-03-2009, 08:55 PM
nismowolfe's Avatar
where did you get your block off plate and how much. Now did you just remove the vias and canister and block it off or did you have the work done inside your intake manifold too.
Old 01-03-2009, 09:07 PM
MIK3's Avatar
http://www.nwpengineering.com/Phenol...rs.html#VQ35DE
At the time, I got it for $60 + shipping. The VIAS, canister, canister sensor and all hoses related to those objects are off. There is no work done inside my manifold (I'm assuming you're referring to the SSIM). No need to do that w/ the block plate, dyno's have proven it's actually worse off.
The block plate was a very easy install, just make sure to keep your stock gasket from your VIAS.
MIK3 is offline
Old 01-03-2009, 09:32 PM
MIK3's Avatar
Updated! Wow, I love how this looks. Thank god for masking tape, x-acto knives and patience. What do you guys think?
MIK3 is offline
Old 01-03-2009, 09:36 PM
nismowolfe's Avatar
looks great man thanks for the advice on the vias stuff I thinks I might just do this tomarrow. So you left your shelf in there just got rid of the vias junk right.
Old 01-03-2009, 09:44 PM
Damn that looks so good.
Old 01-03-2009, 09:48 PM
Turbo'd Saab
DrunkieTheBear's Avatar
I don't know why...I thought you had a 3.0 MIK3...hmmm guess not LOL
DrunkieTheBear is offline
Old 01-03-2009, 10:06 PM
MIK3's Avatar
Not so sure what shelf you're referring to? But everything related to the VIAS, vacuum canister and vacuum canister sensore is gone.
Thanks for the comments too guys. And Dave, no sir
MIK3 is offline
Old 01-03-2009, 10:24 PM
Demodded and Forgotten
rroderiques77's Avatar
Mine did too until I removed the cover.
rroderiques77 is offline
Old 01-03-2009, 10:25 PM
I got the answer for you on that. VIAS removal and block-off plate.
Old 01-03-2009, 10:29 PM
I disagree. One may gain from SSIM, block-off plate and phenolic spacers to cool down fuel.
Old 01-04-2009, 11:09 AM
Scottwax's Avatar
Can you take another picture with flash?
Scottwax is offline
Old 01-04-2009, 10:22 PM
MIK3's Avatar
No flash, but @ daytime.
And with the cover on
MIK3 is offline
Old 01-04-2009, 10:53 PM
Cover on looks much better. IMHO, you should polish only the top of the UIM and elbow. That would look sick!!!
Old 01-05-2009, 02:47 AM
nismowolfe's Avatar
yeah looks reall good I think I might work on my burger too it looks really bad.
Old 01-05-2009, 04:31 AM
nsnrider's Avatar
did you make sure you put clear coat on the parts you painted to prevent them from going dull and discoloration?
Good job on the project.
nsnrider is offline
Old 01-05-2009, 06:28 AM
02RIMax's Avatar
Looks good. I have the same problem on mine.
02RIMax is offline
Old 01-05-2009, 07:14 AM
Scottwax's Avatar
Thanks. Looks really good both ways.
What are you impressions of the VAIS block-off plate? I know there is some midrange loss, does the increase after 3800 rpm make up for it?
Scottwax is offline
Old 01-05-2009, 07:15 AM
Mauja He Mauja
ZIPPIN's Avatar
Nice
ZIPPIN is offline
Old 01-05-2009, 10:34 AM
hoppers69's Avatar
With the V6 and 3.5, it looks real nice and like it came from the factory like that.
Call me a noob, but what do you mean by the 'warped chrome' though? Mine doesnt look so bad, but do you mean when the plastic chrome is flaking off and has the weird darker spots on it? That is happening on my altima grill (also has the cheap plastic chrome finish).
hoppers69 is offline
Old 01-05-2009, 12:36 PM
MIK3's Avatar
Indeed I did. I did a bunch of paint projects on the car previous to this, so I've had some practice.
Indeed it does. I remember prior to the plate, the power almost seemed to drop off after 4k or so, however, the pull is now stronger and seems to be consistent if not, increasing as I reach peak RPM.
Here are some dyno's to show the differences between stock IM, SSIM and BP
http://www.nissanclub.com/forums/eng...-vs-stock.html
More or less, yeah, the coating on the nissan symbol is wavy and possibly discolored in certain areas due to heat the engine produces. I think the mixture of the adhesive and the metallic plastic chemically breaks down at certain heat temperatures. It's the first thing I saw in my bay when I opened my hood, so I figured it was time for a change.
Thanks all for the compliments.
MIK3 is offline
Old 01-06-2009, 05:36 PM
nismowolfe's Avatar
How did you get the chrome off and did you remove the emblem thanks.
Old 01-07-2009, 12:18 AM
MIK3's Avatar
The chrome came off by x-acto knifing and peeling. Took some patience too. And then, I just lifted it off with a flat head. Had to re-adhesive it to put it back on and it more than likely will not be coming off again.
MIK3 is offline
Old 08-11-2012, 03:40 PM
kevdelawaremax's Avatar
i like that. i may have to do that. what did u use to blacken it?
kevdelawaremax is offline
Old 08-11-2012, 08:37 PM
Get Off My Lawn
Chris Gregg's Avatar
Hmmm, wishing I had paint skills to pull that off.
Chris Gregg is offline
Old 08-12-2012, 12:11 PM
MIK3's Avatar
It was 3 years ago, but if my memory serves me correctly, it was high-temp engine enamel, flat-black.
MIK3 is offline
MAXSE5SPD
09-17-2022 04:00 AM
mvm062
11-30-2020 09:00 AM
sdotcarter
09-02-2015 09:53 PM
iflexsteel
09-02-2015 08:04 AM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: Cleaned Up The Burger on the Engine Cover
