Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-26-2008, 06:48 PM   #1
How To Install the USA Spec iPod/iPhone Interface in a 2000 or 2001 Maxima
I spend enough time on this site looking for help that I thought I outta post a How To on the one thing I know how to do decently well:
How To Install the USA Spec iPod/iPhone Interface in a Maxima
A note: There are many ways to attach an iPod or iPhone to your car. I saw the USA Spec kit as the best option for several reasons: it lets you control your iPod/iPhone from the stereo and steering wheel (as well as still using the iPod click wheel), it charges your iPod/iPhone, and the sound quality is unparalleled.
This How To is written for someone who has very little experience working on their car. I wrote it this way on purpose. If you live in Austin or San Antonio, I would be happy to help you with this install for free.
These are the tools I used:
2 phillips screwdrivers, 2 flat head screwdrivers, 12mm socket wrench, drill, USA Spec iPod to Nissan Interface, Model PA11-NIS (139.99 from Crutchfield)
Steps: Most have pictures; some don't
1. Open USA Spec adapter kit and make sure all contents are present: interface brain, iPod/iPhone cord, radio/interface cord.
2. Set parking break. Disconnect negative (-) battery terminal. Remember, doing this will reset all trip mileage and radio stations.
3. Remove center A/C vent. If you're strong enough, it can be done without tools, like in the picture. Otherwise, use a flat head screwdriver wrapped in a towel.
4. Unscrew 2 phillips screws from top of radio. Place these on a mat together so you'll remember where they came from.
__________________
2001 Maxima SE
San Antonio, TX
evalyn is offline   Reply With Quote
Old 12-26-2008, 06:49 PM   #2
5. Remove coin tray. Unscrew single black screw with phillips head. In an automatic, it may help to move the gear shift level backwards. Since the battery is disconnected, you wont be able to do this. With a flat head, lift out the silver plastic tab that's in front of the gear shift lever. Insert Maxima key into slot, push down, and the gear lever should move.
6. Remove the trim piece by inserting a very thin flat head between trim piece and center console.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 06:49 PM   #3
7. Gently remove trim piece, and lift over gear shift. Hang trim piece on left side of center console.
8. Remove 2 black phillips screws from center console.
9. Open main box of center console. Remove 1 black phillips screw from under carpet. Put with other 2 black phillips screws.
10. From the back seat, remove 2 black phillips screws from sides of center console. Don't remove the small ones; just the big ones. If you're like me, you'll have to reconnect the battery to scoot the seats forward.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 06:50 PM   #4
11. From the back seat, pull center console up and unplug the clip that powers the rear cigarette lighter. Lift center console up and maneuver it over the gear shift lever and parking brake. Remove from car. This might be a good time for some Windex and a rag, if yours is anywhere near as dirty as mine was.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 06:51 PM   #5
12. Remove 2 phillips screw from bottom of climate control. Set aside with 2 identical screws from top of radio.
13. Pull radio out.
14. Connection time. This should be obvious, but I'll explain. From back of radio, remove larger wire clip by inserting flat head and pulling wire (hard!). Plug this male end into the only female connector from the USA Spec radio/interface cord.
15. Plug the larger of the USA Spec male clips into the large hole you just removed a clip from.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 06:51 PM   #6
16. Plug the last USA Spec male clip into the hole on the left side of the radio (you're looking at it backwards, so it'll be on your right).
17. Put the radio back in. Bring the USA Spec radio/interface cord behind radio and connect it to the interface brain. Plug the iPod/iPhone cord into the brain, and select which setting you want by flipping the switches. We went with 1 ON, 2 OFF, so we could control the iPod/iPhone from the car and also the iPod.
18. Stash the brain in front of the gear shift assembly.
19. Now it's time to decide where you want your iPod/iPhone cord to come out. On one of our cars, we decided to use the main center console box, and on the other we tried the cup holder. It's up to you.
20. It's a good idea to test that everything works before putting the car back together. Reconnect the negative battery terminal and plug in your iPod/iPhone. Turn the radio on and see if all the controls work.
21. Put the center console back in from the back seat. Reconnect the cigarette lighter plug.
22. Put all screws back where they came from.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 06:52 PM   #7
23. Re-insert the central A/C vent.
24. Jam out to your new tunes!
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 07:10 PM   #8
hey This Write Up is great, Im just wondering if you can utilize the 5.5 gen steering wheel controls with this unit.
__________________
Whered that VQ go??
1. 2003 titanium edit blacked out,Hks Exhaust, Jim wolf Pop Charger, 17Deg advance, Nex Coilovers, staggered 20" (yaya i know)
2. 2000 pearl white 5 spd all basic bolt ons g35 whls, it was good while it lasted.
3 87 stang Project 306ci built motor full susp. (in garage) its sloow .....
perkman87 is offline   Reply With Quote
Old 12-26-2008, 07:13 PM   #9
Quote:
As far as I know, the answer is yes. It works with my steering wheel controls, and I have a 2001 SE. Hope that helps.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 07:17 PM   #10
Send a message via AIM to Tippy Toes Send a message via Yahoo to Tippy Toes Send a message via Skype™ to Tippy Toes
pretty cool write up. I like how you can still control from the steering wheel.
I cant wait for the first car with a built in unit for the iphone.(or stations for for phones/interchangeable)
Do you know how to hard wire the garmin nuvi into the rear view mirror?
Tippy Toes is offline   Reply With Quote
Old 12-26-2008, 07:20 PM   #11
Quote:
Not a clue--sorry.
__________________
2001 Maxima SE
San Antonio, TX
Old 12-26-2008, 07:35 PM   #12
Very nice write-up. Bookmarked so I can do it in the summer.
Thanks for taking the time to post this!!
__________________
Bone stock.
03blackSE is offline   Reply With Quote
Old 12-26-2008, 08:17 PM   #13
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
this thing only works with the cd-changer in the trunk headunit, 5.5th with cd-changer in the front won't work.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 12-26-2008, 08:24 PM   #14
Very nice write up with plenty of self-explanatory pictures. I'm hoping that this interface charges the ipod at the same time.
I've been using a cassette adapter like the one below to connect my ipod, and any other mp3 player for that matter, ever since I had my 4th gen. The only drawback is that it does not charge the ipod while connected. However, the sound output is excellent.
__________________
Nelsito65 is offline   Reply With Quote
Old 12-26-2008, 11:05 PM   #15
won't work on 5.5 gen as jasonmax already stated.
__________________
Current: AE KT3 MT | 5.5 HIDs | Fog-Light Rewire
Old: 96 KH3 MT | Fog-Light Rewire (sold 11/9/09)
AEMAXIMA01 is offline   Reply With Quote
Old 12-26-2008, 11:07 PM   #16
Yes, this does charge the iPod. The sound quality does not even compare b/wn a tape adapter and the usa spec. wait until you hear the difference.
__________________
Old 12-26-2008, 11:30 PM   #17
Send a message via AIM to Andrew
Bravo!! Excellent write up!
Andrew
Andrew is online now   Reply With Quote
Old 12-27-2008, 12:34 AM   #18
wow! Very nice! Mad props to you sir!
__________________
IHATEMY2KMAXIMA
IHAVEA2KMAXIMA is offline   Reply With Quote
Old 12-27-2008, 12:36 AM   #19
Quote:
Shiet...
__________________
Bone stock.
Old 12-27-2008, 01:25 AM   #20
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
Awesome write up man....I got really excited when i saw this until i realized it will not work with the 5.5 gen head unit.
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Zack342 is offline   Reply With Quote
Old 12-27-2008, 03:41 AM   #21
good work, i already have my ipod hooked to my alpine hu but i still read the whole thing for some reason... haha
well done
__________________
00' SE 5 Speed/ Cattman Muffler/ Warpspeed Y/ 17º advance/ 5% tint all around/ 6000K HID's all around/ Hawk HPS's all around/ FSTB/ Alpine HU/ Alpine Type R speakers
Feldman is offline   Reply With Quote
Old 12-27-2008, 09:26 AM   #22
Quote:
Thank you.
__________________
Whered that VQ go??
Old 12-27-2008, 10:18 AM   #23
Send a message via AIM to mist max2000
10/10 write up
__________________
| 2002 6speed|Progress RSB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|HID fogs|eyelids|Hella Supertones|HD CatchCan|Berk Intake w/ Apexi filter|
Parts I own waiting to go on:| stillen classic kit|GenI cattman headers|Test Pipe|SAFCII
mist max2000 is offline   Reply With Quote
Old 12-27-2008, 01:32 PM   #24
Send a message via ICQ to 98_maxi Send a message via AIM to 98_maxi
very nice write up!
I had the same adapter, but it didn't work. Do you have CD changer in ur car?
__________________
- 2000 maxima se, 5spd, 10K HIDs, H&R springs with KYB GR2, GAB, ebay short shifter.
- 1998 maxima gxe (sold)
98_maxi is offline   Reply With Quote
Old 12-27-2008, 03:51 PM   #25
Quote:
Originally Posted by 98_maxi View Post
very nice write up!
Do you have a cd-changer in the trunk? If so, you will lose it. This takes the place of the trunk mounted cd-changer.
__________________
Old 12-27-2008, 07:07 PM   #26
overbo0st2k4's Avatar
Send a message via AIM to overbo0st2k4
Quote:
So sad =(
overbo0st2k4 is offline   Reply With Quote
Old 12-27-2008, 07:31 PM   #27
very nice write up!
I have a 5.5 gen and the stock bose unit does not work with the USA Spec. I had to swap out the unit for the older one just to have my ipod control. The old bose unit that the 5th gens have with the cd/chng button on it. I also lost the ability to control the radio from the steering wheel which sucks but the sound quality is awesome!!
mreman6 is offline   Reply With Quote
Old 12-27-2008, 09:56 PM   #28
Send a message via AIM to Kevin319
Great writeup man, time to upgrade from my Belkin cassette tape thingy to this.
Kevin319 is offline   Reply With Quote
Old 12-27-2008, 09:59 PM   #29
Quote:
make sure that you don't have the indash CD-changer thingy.
__________________
Old 12-27-2008, 11:08 PM   #30
In the last picture, see the CD/CHG button? I think your car has to have this in order for it to work. However, you do not actually have to have a CD changer in your trunk. My 2001 SE does, but my brother's 2000 GXE does not. The USA Spec interface was successfully installed in each of our cars.
I'm new to the Maxima crowd, so maybe someone can answer this question for me: About what percent of 5th gen Maximas have this CD/CHG button?
__________________
2001 Maxima SE
San Antonio, TX
Old 12-28-2008, 12:11 AM   #31
Quote:
correct. all you need is the cd/changer controls button. the 5.5 doesn't have the button b/c it has the in-dash cd6 controller.
only 5.0 gens will have it.
__________________
Old 12-29-2008, 02:01 AM   #32
I R The Law
The Law's Avatar
Send a message via AIM to The Law Send a message via MSN to The Law Send a message via Yahoo to The Law
Nice write-up
__________________
Progress Coilovers, Otto racing FTSB, Stillen RSTB, Progress RSB, Window tint 20%/5% All Around, Clear Side Markers, Berk w/ JWT Filter, SS brake lines, 350z Ray Rims, Maxxtuning front lip, Stillen sides and rear lip, 300z BBK, SSIM, Xtreme Eyelids, NWP Thermal Intake Manifold Spacer, Truax SFCs, E46 DDE's, Clear Corner, Rainbow speakers, Eclipse AVN 6610, Hifonics amp, Epic 160, HS Headers, Cattman 3" catback
The Law is offline   Reply With Quote
Old 12-29-2008, 05:32 AM   #33
nsnrider's Avatar
Send a message via Yahoo to nsnrider
why did you end up removing the center console, this could have been done without that extra step, would save you some time.
__________________
Sold my 2k3 Max.
nsnrider is offline   Reply With Quote
Old 12-29-2008, 07:18 AM   #34
Quote:
It depends on where you want to run the cable to the iPod. I removed mine bc i ran the cable under it and drilled a hole in the back of the cupholder. I don't have a picture during install, but here's a pic of where it comes out:
__________________
Old 12-29-2008, 07:54 AM   #35
excellent write up bro! VERY VERY DETAILED
__________________
Megan Racing exhaust | Tokico Illumina's 4F/5R | H&R Springs | ebay FSTB | | ES Bushings | Goodridge SS Lines | Berk Air Intake | Cleared 2K2 Headlights | 8k D2R & 50W H3 Fogs upgrade | Cleared Sidemarkers | White LED's all around (Interior & Exterior) | Chrome Gauge Rings | 15% Tint (all around) | RTP Zinc plated Slotted Rotors | Hawk HPS pads | RPM R-505 19x8.5 wrapped in General Exclaim UHP 245-35-R19 | Optima Yellow Top | Hella Supertones | (2) 12" Alpine Type R's
hi-tek22 is offline   Reply With Quote
Old 12-29-2008, 08:44 AM   #36
Where did you get the adapter and how much was it? Nice write up!
edit: d'oh brain fart. Should have read under tools.
__________________
2001 Nissan Maxima SE 5sp - Sherwood Green (daily driver)
2005 Ford F-350 PSD Crew Cab - White (tow vehicle and rotary owner)
1993 Ford Mustang LX 5.0 - Vermillion (for smokey Dairy Queen burnouts)
2008 Toyota Camry Hybrid - Barcelona Red (wife's ride...something has to get good milage )
goathead is offline   Reply With Quote
Old 12-29-2008, 08:46 AM   #37
Quote:
read the first post.
__________________
Old 12-31-2008, 11:59 AM   #38
Anyone know if this will work with the 5.5 Gen with navigation since it has the 6 disc changer in the trunk?
*EDIT*
Just read through the reviews on Crutchfield, and looks like I am in luck
__________________
spoink is offline   Reply With Quote
Old 12-31-2008, 12:06 PM   #39
Quote:
if you have the seperated changer, there is a possibility it might work.
__________________
Old 12-31-2008, 12:28 PM   #40
Also if anyone is interested I found it at Enfig Car Stereo's for $100
http://enfigcarstereo.com/shopsite_s..._PA11_NIS.html
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
