Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-26-2008, 01:25 PM   #1
Bad o2 sensor =/
So i just bought a 2000 maxima se and life was good. Until 2 days ago i go to drop my friend off and i am coming home and whamm.. service engine light comes on. I was hoping it was either the gas cap or my cold air intake became lose again. Check them both and nothing. So i try disconnecting the battery and still came back. So i went to get it checked out and it came back with code p0139, which is a bad o2 sensor in bank 1 sensor 2. The guy there said he didnt know if it was after catalytic front or after catalytic converter back, and there is a huge price difference and honestly i cant afford to buy both. So does anybody know if it is front or back for code p0139. My car is a 5sp manual the mechanic said that made a difference.
ohitzme is offline   Reply With Quote
Old 12-26-2008, 04:23 PM   #2
start in this thread......its actually stickied
SES/Check Engine Codes, O2 Sensor Locations and Codes, and TSB's inside....
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
its the precat
, the one before the main cat....you have a 2000, so its the one in the actual Y pipe...and that is actually the rear precat
the front precat = THE precat directly in front of the radiator and inside the engine bay
the rear precat = THE precat directly below the firewall, typically what you would replace if you got a y pipe
my suggestion is to just replace the o2 sensors, CHECK OUT www.sparkplugs.com, and https://www.automedicsupply.com/inde...80&height=1050
__________________
Megan Racing exhaust | Tokico Illumina's 4F/5R | H&R Springs | ebay FSTB | | ES Bushings | Goodridge SS Lines | Berk Air Intake | Cleared 2K2 Headlights | 8k D2R & 50W H3 Fogs upgrade | Cleared Sidemarkers | White LED's all around (Interior & Exterior) | Chrome Gauge Rings | 15% Tint (all around) | RTP Zinc plated Slotted Rotors | Hawk HPS pads | RPM R-505 19x8.5 wrapped in General Exclaim UHP 245-35-R19 | Optima Yellow Top | Hella Supertones | (2) 12" Alpine Type R's
hi-tek22 is offline   Reply With Quote
Old 12-26-2008, 04:41 PM   #3
boris is offline   Reply With Quote
Old 12-26-2008, 04:54 PM   #4
It's the one after the rear pre-cat (if cali spec) or main cat (if federal spec). If replacing with OEM sensor (not universal) it's the one with the white wire.
Diagram below is for California spec vehicles.
__________________
Nelsito65 is offline   Reply With Quote
Old 12-26-2008, 08:34 PM   #5
I got a 2000 Maxima with CEL for about a month now and can not figure it out. I stopped by autozone and the code read, Po171 Bank 1 and Po174 Bank 2. Which o2 sensors are these? Thanks for any help! Could it be a bad MAF? Car seem to run fine.
KaToFLR is offline   Reply With Quote
Old 12-26-2008, 08:54 PM   #6
Quote:
For a lot of org members, replacing the MAF seemed to have cleared those codes and solved the problem.
__________________
Old 12-26-2008, 09:16 PM   #7
Quote:
But I dont have the MAF issues. Like stalling or hesitation.......
Old 12-26-2008, 10:14 PM   #8
I didn't go too deep while searching for those 2 codes and possible solutions. I did find out that it's fuel injector related. I would try one of those injector cleaners before starting replacing parts. Also, I would monitor the fuel efficiency very closely to see if there's any decrease in the mpg's, provided you have something to compare it to.
__________________
Old 12-27-2008, 06:41 AM   #9
I running some fuel injector cleaner now. Also going to change the filter, check for leaks, and clean the MAF. Hopefully that will do the trick.
Old 12-27-2008, 12:02 PM   #10
Do you know if the 2000 maxima has that U shaped wire? This pic was from a 2002 maxima. I took my sensor out to clean and did not see it....
http://farm4.static.flickr.com/3145/...633cc7ae_o.jpg
Old 12-27-2008, 10:12 PM   #11
Send a message via AIM to Kevin319
Last time I cleaned my MAF it did not have a "U shaped wire" on it too (2000), check the "clearn MAF for under $10" thread and there's more info on that.
Kevin319 is offline   Reply With Quote
Old 12-27-2008, 10:16 PM   #12
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
5th gens have seperated temperature sensors.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 12-28-2008, 05:54 PM   #13
How do i figure out if my car is federal spec or california specs?
Old 12-28-2008, 06:16 PM   #14
Quote:
Under the hood, there is an emission related label. Towards the buttom it reads "this vehicle conforms to US EPA NLEV regulations applicable....." . If that label has the word "california" in it, it's a California spec. Also, if the numbers of connectors right between the front of the engine and the radiator is 4, then it is a Cali Spec. Otherwise it is Federal.
__________________
Old 12-28-2008, 06:40 PM   #15
Thanks its federal specs
Old 01-02-2009, 10:09 AM   #16
Damn my CEL came back on.
Freaking same codes as before - Po171 Bank 1 and Po174 Bank 2
Dont know if it the o2 sensors, the MAF or fuel injectors? I ran some fuel injection cleaner, could not find any leaks and cleaned MAF.
What should I do?
Do I start with the MAF then the o2 sensors..........
Old 01-04-2009, 08:01 AM   #17
I have a 2000 SE with 90K miles and I just replaced this O2 sensor. There is a TSB for it here: http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
It is not too hard to replace, it is right in the middle so I jacked up the front end and crawled in from the driver's side. Mine was in tight and the exhaust system had too much flexibility to get a good torque on it so I had someone hold a long 2x2 against the bracket to provide some resistance while I reefed on it.
It helps to have an O2 socket so you can put an end wrench on the socket and get some extra leverage. I couldn't get a good bite with just an end wrench on the sensor.
The code has not come back so far. Hope that helps.
che_beaver is offline   Reply With Quote
Old 01-04-2009, 08:15 AM   #18
What should I do?
Since both are reading too lean I would expect it to be something that relates to both, like the MAF. They both came on at the same time it is unlikely that both failed at the same time. Unless it was your very first time driving at highway speeds after you bought the car.
To test the MAF get on the highway at about 50 MPH. Floor it and if the engine revs up (~4,000 RPM) but there is no power and/or it doesn't shift then it is probably the MAF. If it pulls fine then your MAF is probably okay.
Caveat - from what I have read MAFs fail in a myriad of ways and what I described above is just how mine failed and how I determined it failed. You can also just check the voltage at various RPMs, but that is a little more intrusive.
Old 01-06-2009, 11:19 PM   #19
I have 2002 6-speed. Got the check engine soon warning, changed the sensor at the gas tank and light went out. Now 3 weeks later the light is on again. Do ya think it is the O2 sensor?? Thanks Gary
gsimatos is offline   Reply With Quote
Old 01-07-2009, 12:17 AM   #20
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Quote:
No idea until you pull the codes.
Scottwax is offline   Reply With Quote
Old 01-07-2009, 01:01 AM   #21
Sorry but a dumb question. How do I get the codes?? I have had 2 of these cars (Maximas) and not like my old 76 honda civic which i serviced myself. Time to join the 21 century. Any advice would be appreciated, Thanks G
Old 01-07-2009, 01:49 AM   #22
The same way you got them (codes) in your first post LOL, just go to any auto zone in your area they check it for free,also if you just got the car I would change all fluids with the best brand in my opinion and dont beat on it everyday if you dont want more problems
BronxSleeperMax187 is offline   Reply With Quote
Old 01-07-2009, 03:31 AM   #23
Without reader:
Do not start the engine
Precise timing is very important!
Long blinks - 1st digit, short blinks - next three.
10 long blinks mean 0
Old 01-08-2009, 12:08 AM   #24
Send a message via AIM to Berto210 Send a message via MSN to Berto210
does anyone have the issue where the SES light comes on, then a few days later, it goes off..then a month or so later, it comes back on...few days later its off...anyone? I took it to Autozone and it's the O2 sensor bank 2 i think they said. But if its bad why does the SES light go on and off??
__________________
The one, the only...Berto
Berto210 is offline   Reply With Quote
Old 01-12-2009, 10:36 PM   #25
Quote:
The O2 sensor can come back in range. There are several codes associated with the O2 sensor (see here) and if they come back in range the code can reset. I don't know the exact mileage or duration for it to reset and if it is only for specific codes, but that could have been what happened.
For example, I had P0138 and P0139 for the rear O2 sensor. After about a week the SES light went off, presumably because there was nothing wrong in the first place (my MAF was on the fritz).
Best thing you can do is when the SES light comes back on pull the code. It is not bad if it goes on and off (caveat, it is bad if you reset it without diagnosing and fixing the problem). How many miles are on your max?
Old 01-14-2009, 03:46 PM   #26
87 Octane SES Light
Just bought a 1999 Maxima SE. The wife put about 10 gallons of 87 octane when the low fuel light came on. I filled the tank with 93 octane and checked the fuel cap, but the SES light stays on. Had the OBD scanned and came up with O2 sensor and Knock Sensor codes. I authorized the shop to clean the fuel system--they did not say this would clear the SES light--but I went ahead and had it done. There are no drivabilty issues. Could the lower octane trigger the SES light?
eutecticpt is offline   Reply With Quote
Old 01-14-2009, 08:43 PM   #27
Quote:
The low octane gas caused your engine to knock. Your engine detected the knocking and set the SES light. I am surprised it would happen with only one tank of gas, but these engines (at least mine) knocks badly with anything less than premium.
I am not sure why the O2 sensor was on, but my guess is that it didn't have anything to do with using regular gas. Do you know what the code was for the O2 sensor?
Cleaning the fuel system has no affect on the knocking. Unfortunately that was probably a waste of money. Or should I say an investment in your local auto shop
Either get the actual codes, or run through a couple tankfuls of premium.
Old 01-15-2009, 09:16 AM   #28
I did not get the code for the o2 sensor. Is it OK to drive the car with the SES light on?
Old 01-15-2009, 11:27 AM   #29
Yes, you can drive the car with the SES light on if you have no other issues, but at some point you may have to deal with it. Give it some time with a different (premium) gas and see if the SES light goes out. The O2 sensor code and the SES light may have been triggered by a higher amount of ethanol (puts more O2 into the exhaust) in that particular gasoline that your wife bought, particularly if you have a marginal O2 sensor or cat. BUT, the pinging by itself will not set a code, or put on the SES light. A "failed" knock sensor will also NOT put on the SES light, but as you do supposedly have the code for the knock sensor it may actually have failed. But run for a bit with the premium gas and see if that stops the pinging no.1, and see how the performance is (lots of "snap", and reasonable fuel mileage), and also see if the SES light goes out. Some members on this forum in the past have reported poor performance (probably from retarded timing) and then later on discovered the failed knock sensor.
P. Samson is offline   Reply With Quote
Old 01-16-2009, 06:29 AM   #30
Thanks for the info. I will run a few tanks of premium and go from there.
Old 01-16-2009, 07:32 AM   #31
Ive sneaking up on 118,000... I changed out the O2 sensor with a Bosch one I got @ autozone, but it came back on last night... DAMNIT
__________________
Old 01-16-2009, 07:37 AM   #32
its acutally not very good to be switching up gas like that. Once you start with one, stick with it. I would recommend trying a fuel additive before changing fuel types. I've personally stuck with mid grade and every 4 months use the BG 44K fuel additive.. Works great! Look into that...
__________________
Old 01-16-2009, 10:51 AM   #33
Berto210.......I don't know where you got that idea from, but it's incorrect. The Maxi's recommended fuel is a minimum rating (US/Canada) of 91 octane to start with and changing immediately to the recommended fuel is an advantage and not what you suggested (and don't get me going on additives!!). Limiting the use of fuel with ethanol (I know that's difficult in the states) if you can, may be helpful if you encounter what happened to eutecticpt.
Old 01-16-2009, 06:56 PM   #34
When did you change the O2 sensor? If it is less than 20K miles (assuming you changed it around 100K) it is probably not the O2 sensor. Has your MAF been replaced?
Old 01-16-2009, 06:59 PM   #35
Quote:
I stand corrected. Thanks for the clarification. Just goes to show you that you should never trust a noob.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
