Door open light on, interior lights and keyless not working.
Old 01-22-2011, 02:13 PM
MAXclipse's Avatar
My 03 has about 150000 miles on it now. Was driving the other day and my door ajar light came on. I checked all doors and trunk and all were closed. Light stayed on. Keyless entry works when the ignition is on accessory or on, but not off. None of the interior lights work. My headlights when on auto will not stay on for the few seconds after cutting the car off. I've checked fuses under the steering wheel, and checked the fusible links under the hood but didn't see any problems. Any help is greatly appreciated.
MAXclipse is offline
Old 01-22-2011, 02:44 PM
96darkdemon's Avatar
Check your door switches. Sounds to me like one may have gone bad.
96darkdemon is offline
Old 01-22-2011, 04:10 PM
MAXclipse's Avatar
I checked them and none of them are stuck. I've been searching but can't find more info on this. Can I pull these out and ohm them?
Old 01-22-2011, 07:13 PM
DennisMik's Avatar
there are 3 fuses that feed the "Smart Entrance Control Unit", fuses 1, 10 and 13. All are 10 amp fuses. The door switches can be checked with an ohmeter, they are either closed (0 ohms) or open (infinity). In operation with the door closed, the switch is open. When the door is opened, the switch closes and grounds out a pin on the smart entrance control unit. Different doors, different pins.
When you say that the keyless entry works when the key is on ACC, are you referring to the keychain remote? If so (and if I remember correctly), this is completely backwards of normal. The keyfob remote should NOT work when the key is in the ignition switch in any position.
It almost sounds like the car is confused and doing things backwards. Why don't you try disconnecting the battery for a half hour to reset all the control modules. When you disconnect the battery, remember that the radio will loose all the station presets.
DennisMik is offline
Old 01-22-2011, 10:38 PM
Philbert579's Avatar
I agree with you that the door switches seem suspect, but my key fob works whether the key is in the ignition or not. It does, however, respond to the doors being open by not working so that's what I would check, for sure.
Philbert579 is offline
Old 12-10-2011, 12:01 PM
MAXclipse's Avatar
Was cleaning my car today and found the problem. The lamp fuse in the distribution block under the dash was blown. Replaced the 10a fuse and everything works great. Can't believe it's been a year without keyless. My interior lights, keyless, key in ignition chime, remote window down, and door ajar light on dash were all fixed with this one fuse. Figured I'd update in case anyone else runs into this.
Old 03-03-2012, 05:05 PM
PAMCAT1's Avatar
Can you please explain what the lamp fuse in the dist block is?i'm having the same problem but i can't find any infor anywhere. is it the big square blocks inside the fuse box under the hood?
thx!
PAMCAT1 is offline
Old 10-17-2013, 02:24 PM
jonny5's Avatar
I can't find the lamp fuse either. It's not marked as lamp. Need help.
jonny5 is offline
Old 10-17-2013, 02:27 PM
jonny5's Avatar
There is one marked Stop Lamp.
jonny5 is offline
Old 10-17-2013, 07:02 PM
DennisMik's Avatar
It is in the under dash fuse block. Top row of fuses, 2nd from the right end.
Old 01-21-2017, 05:22 PM
Nick Francis's Avatar
Fix
Your car's fuse box iditfier may not have the lamp fuse showing tht it even needs one like mine....it's number 2 right under room lamp....stick a 10a fuse in and your chime with interior lights and keyless entry should work like a charm.
Nick Francis is offline
Old 01-21-2017, 07:39 PM
cornholio's Avatar
thank goodness that was resolved
cornholio is offline
Old 01-21-2017, 08:14 PM
SubwayVQ's Avatar
Bahahahaha
SubwayVQ is offline
Old 11-11-2019, 10:41 AM
a33_skrilla's Avatar
sorry thread is old bit i just got this issie but ehen i put a fuse there it blows im guessing a short any suggestions??
a33_skrilla is offline
Old 09-05-2023, 03:45 PM
Spider6907's Avatar
I can not believe it was that easy. just wow
Spider6907 is offline
Old 09-06-2023, 09:38 AM
Prophecy99's Avatar
yeah, post this thread link in your same thread and say it helped resolve your issue.
the org is the best
Prophecy99 is offline
vingodine
45
05-21-2016 12:46 PM
Dennis Twohy
10-01-2015 06:01 PM
rbaker100
08-28-2015 08:11 PM
Jeffesernia11
08-23-2015 06:09 PM
Samedi
08-13-2015 04:05 PM
Quick Reply: Door open light on, interior lights and keyless not working.
