Would i rub?
Would i rub?
I just picked up some g35c 18's with 225/45/18 all around. Do you any of you know if i would rub with H-techs? also what drop do you recommend with those wheels. I'm planning on using stock struts for a while and I've heard that progress is the lowest i can go on stocks. Thanks in advance
Originally Posted by Orgullo
Your sidewall on the tires are too big. Go with a different size. ie... 235/35/18 and you'll be good.
I'm running 245/45/18 , it raised my car quite a bit comparing to the stock wheels which are smaller in overall diameter ( im on progress springs and tokico blues ) I will go with 245/40/18 next time I buy tires. You learn something new everyday Either that or go with even shorter springs.
I don't think you will rub because you have 225 versus my 245, which does affect things alot, the tire will be further from the fender, and it will be a lil more than half an inch smaller in diameter.
If you do rub, the first spot will probably be passenger rear because of the shifted beam. ( once you lower the car ).
It's all in the offset! too bad I don't know mine
Serotta33
09-17-2015 12:14 PM
MikesChevelle
08-07-2015 05:57 PM
RealityCheck
08-05-2015 06:18 AM
