Instrument Cluster Removal
Alright so I tried searching and searching on how to remove the instrument cluster from a 2002 Nissan Maxima but was only able to find 4th gen removal and partial 6th gen but no 5th gen. Can anyone point me in the right direction on how this can be done or where I can find my answer? Thanks.
P.S. Since we're on the topic is it possible to switch the lights behind the cluster or are they LED not bulbs?
The removal of the cluster is very easy!!! Take off the steering column cover off, then the 2 screws on the trip and there will be screws holding the cluster. After removing the screws it should come out with ease.
This how-to for adding chrome rings to the gauges has easy-to-follow directions on removing the cluster.
We are on the same page jocco, except that my maxima is a 03 but still is the 5th generation. We are on the same situation, let me help you out a little bit. First of all, these can be replaced with LED's I do have them already, and I bought them online from www.superbrightleds.com and you have to order the same ones I just order. 74-CWHP3 Mini Wedge Base 2 volts. You need 4 Cool White Hight power Led. ( That was description of the product you need ) Now I am working on my research as well as you. Email me if anything buddy. silver_dreamer08@hotmail.com.
Good luck.
Good luck.
Good luck.
Good luck.
my03maxima
04-29-2020 12:48 AM
RealityCheck
10-02-2015 06:34 PM
