1st gear is sluggish when engine is cold
Old 12-06-2008, 05:20 PM
evalyn's Avatar
I searched for an hour on this, and found nothing.
My 01' SE Auto is very sluggish in 1st gear on days when the air temp is below 45° and the engine is cold. Other gears seem fine, and once the engine heats up, 1st gear returns to normal as well.
I have cleaned the MAF using CRC MAF cleaner, but other than that I don't really know what to do. A mechanic at the auto parts store overheard me talking to the clerk today, and he suggested my transmission fluid filter might need to be changed.
This is probably a simple fix, so I'll thank you in advance for your patience and kindness with a newbie.
Evalyn
evalyn is offline
Old 12-06-2008, 05:25 PM
jasonmax's Avatar
AT? how's the condition of the ATF?
jasonmax is offline
Old 12-07-2008, 09:04 PM
evalyn's Avatar
I'm not sure. I just did some reading about how to check on the ATF, and I will do it and post again.
For what it's worth, here's another question: I bought the car 3 months ago. It has 80,000 miles on it, and I have no records that the ATF has ever been changed. Would it be a good idea to just do this anyways?
evalyn is offline
Old 12-07-2008, 09:35 PM
2002 maxima se
OC guy's Avatar
get the transmission oil flush.
OC guy is offline
Old 12-07-2008, 09:49 PM
AznTran517's Avatar
I think i have the same problem over here. I live in PA and the weather has been under 40 degrees lately.
AznTran517 is offline
Old 12-21-2008, 12:10 AM
evalyn's Avatar
I drained 4 qts. today and refilled. Wish I had taken a pic of what color fluid came out--it was epic. Darker than used motor oil, for sure! Tomorrow is forecasted to be cold, so we'll see how she does.
evalyn is offline
Old 12-21-2008, 01:03 AM
alxdagreat1's Avatar
I had similar problems with my 2000 I flushed the whole system and replaced my filter also. Replaced fluid but can't remember if I went synthetic after that car ran fine.
alxdagreat1 is offline
Old 12-21-2008, 07:23 AM
That's Mr. Detail to you
Scottwax's Avatar
Same here when I drained mine the first time. And the second time! Now that I have done the drain and fill 5 times in the last year I've owned the car, the ATF is nice and pink.
The 2-3 cold weather upshift (until the transmission is fully warmed up) soft or slight slip seems to have improved along with the ATF changes.
Scottwax is offline
Old 12-22-2008, 02:58 PM
jasonmax's Avatar
mine feels like it's not engaging when cold.
the rpm stays there, but the gear is not engaging.
then 1s later, it engages.
jasonmax is offline
Old 12-22-2008, 04:24 PM
wi-steve's Avatar
Anyone having manual trans cold weather problems?
I'm having an issue with my 02 SE now that temps are into single digits and below... The clutch pedal is really light at first, then lots of resistance near the floor. All the "action" so to speak is within an inch of movement by the floor, which is not normal for this car.
Today when releasing, it stuck to the floor momentarily then kind of snapped funny as it engaged.
If I let the car warm up to operating temp it is better, but if I drive it a while it gets worse again, almost like driving makes the transmission cold again. It works fine above 20 degrees. It was a little funky last year but nothing like this. 98,000 miles. No engine mods.
This can't be good. Anyone have ideas?
wi-steve is offline
Old 12-22-2008, 04:57 PM
jasonmax's Avatar
when was the last time the tranny oil been changed?
jasonmax is offline
Old 12-22-2008, 05:06 PM
sascuderi's Avatar
When the AT is cold it will not go into overdrive until the tranny is warmed up. That will give you the feeling that it is staying in lower gear longer than usual. Thats how mine has been from day one in the cold weather.
sascuderi is offline
Old 12-22-2008, 05:09 PM
jasonmax's Avatar
but it should be the same from 1st to 2nd and 2nd to 3rd.
jasonmax is offline
hi-tek22's Avatar
now with a transmission FLUSH
how do we know which places get the most amount of A/T fluid out??
Is the dealership the best place for this...because ive owned my car for two years, and have had the tranny flushed once
hi-tek22 is offline
Old 12-22-2008, 05:58 PM
dineth00i30's Avatar
yeah and i hate that about our cars! it sucks soo much and my car even after driving it for a while, if i go to a store to get some coffee come back, and jump is put in drive right away it holds the overdrive again and then it just throws it there after a min or two. its soo annoying.
during days below 55f, if i let the car sit for a minute or two and get on the highway it still doesnt go to overdive even after few minutes on the highway! im starting think i might have the wrong kind of ATF or something wrong with torque convertor. any ideas?
dineth00i30 is offline
Old 12-22-2008, 06:05 PM
sascuderi's Avatar
Mine will go into overdrive when cold after ~3 minutes of driving
Old 12-22-2008, 06:54 PM
I love lamp.
maximase86's Avatar
Is this only when it's cold? That's wierd. How is your clutch fluid level? I would check operation of the the clutch slave cylinder. Inspect the clutch lines (espeically the rubber ones for cracks and bulging).
S
maximase86 is offline
Old 12-22-2008, 07:12 PM
raymax00's Avatar
no reverse
Im having similar problems only thing I get nothing when I put it in reverse, it only sputters to 2k rpms and then drops.
raymax00 is offline
Old 12-22-2008, 08:56 PM
Scottwax's Avatar
I don't know any transmission that allows the torque converter to lock up in top gear until the engine reaches normal operating temperature. Absolutely normal.
Scottwax is offline
Old 12-23-2008, 04:55 PM
wi-steve's Avatar
Good call. I checked it out this morning and it was low on hydraulic fluid. We've been alternating between sub zero temps and blizzard conditions here, but I gotta get this thing on a lift and figure out if there's a leak. Amazing what a difference a 1/4 cup of fluid makes. Probably time for the gear oil change too, but that will wait until spring. I gotta get some snows on this thing too. The Potenza Pole Positions aren't so good in the fluffy stuff.
wi-steve is offline
Old 12-24-2008, 08:07 AM
evalyn's Avatar
OK, so here's today's quiz: Look at the attached picture. Which liquid is used motor oil, and which one is the ATF I just drained?
evalyn is offline
Old 12-24-2008, 10:41 AM
I'm guessing left is motor oil......
Old 12-24-2008, 11:50 AM
sixteenXnine's Avatar
With my 00 gxe I had the same problems with 1st and reverse. Then 1st got worse, then I lost reverse. Now even in neutral the tranny tries to inch the car forward. This all happened in the last month, only 1k after I changed fluid and filter. I didn't do a whole system flush though.
The tranny shop says my tranny is screwed, it's all bound up and he doesn't know what the problem is.
So I'm getting a new tranny.
sixteenXnine is offline
Old 12-25-2008, 12:18 AM
crazy97's Avatar
ATF is on the left
crazy97 is offline
Old 12-26-2008, 11:20 AM
evalyn's Avatar
So I made my point: my ATF came out so dark that it gets confused with used motor oil. Half the guessers were wrong, and it was even hard for me to remember which was which. The ATF is on the left.
I guess I'm going to look at the dipstick and drain it again if it looks dark still. Question: if it comes out nice and light colored from the pan, can I pour it back in, or is that a big no-no?
evalyn is offline
Old 12-28-2008, 12:31 AM
sublime258's Avatar
Shouldn't hurt anything as long as the container you are putting it in is clean.
sublime258 is offline
Old 12-30-2008, 12:28 AM
evalyn's Avatar
Alright, I drained and refilled the transmission again today. This time I was able to get 6 qts. out, because I drove the car up on higher jack stands and let it sit for about 3 hours. Since I replaced 33% of the fluid last time, and 50% this time, I estimate that I have approximately 66% new fluid in the transmission.
Let's hope this solves that problem of 1st gear being sluggish in the cold. I have spent $50 on fluid at this point, so I'd sure like to think it'll work!
Last question: I over filled just a bit. The ATF fluid comes .5" past the full line on the dipstick. After searching online, I concluded that problems can arise from overfilling, but usually only in extreme cases (+2 qts. extra). Any Maxima-specific issues I ought to know about?
evalyn is offline
Old 01-08-2009, 11:04 AM
bluebriscoe's Avatar
so did the flush wrk for the problem?
bluebriscoe is offline
Old 01-08-2009, 11:34 AM
Bassbreaker's Avatar
I have never seen such dirty ATF fluid before..wow...
Bassbreaker is offline
Old 01-08-2009, 01:02 PM
evalyn's Avatar
It didn't.
The car is still sluggish when I first start it up. I almost hit another car in our driveway this morning pulling out, because the throttle is so unpredictable in 1st gear with cold ATF.
I'm pretty frustrated. I spent $50 on ATF, and approximately 10 hours of time on this problem so far. I like doing things myself, but I feel like I am falling victim to the law of diminishing returns at this point.
The only other thing I feel qualified to do by myself is drain the fluid again, drop the pan, and check the filter. Do you think I should spend the time and $$ to do this, or is it time to take it to a shop?
evalyn is offline
Old 01-08-2009, 01:32 PM
njmaxseltd's Avatar
It didn't......
The car is still sluggish when I first start it up.....
No, I don't think the transmission is your problem. Have a shop look at it, not a tranny shop, but a general mechanic. I think you have a cold engine issue, not a cold tranny issue. Possible ECT issue???
njmaxseltd is offline
Old 01-08-2009, 02:17 PM
ECT?
Old 06-13-2011, 08:42 PM
novasource's Avatar
Sorry to join an old thread, but I am having the same problem with my '02 Maxima. When the engine is cold, sometimes it can take a couple to several seconds for 1st gear or R to engage. Other times, it'll just engage immediately.
After the car is driven for only a few seconds, it is fine. No transmission problems at all. I can shift in and out of a gear with no problems. Also, when at speed, there's zero noticeable slip when I shift from D-3-2-1, and I never notice weird shifts in normal driving.
This car sees a mix of side street and freeway driving.
This has been going on for over a year, and I haven't noticed it changing much. I have the automatic transmission.
novasource is offline
sctludwig
09-01-2022 01:32 PM
6spd4dsc
03-04-2016 05:19 PM
jfl330
09-04-2015 01:44 PM
dcardello
09-03-2015 11:44 PM
Quick Reply: 1st gear is sluggish when engine is cold
