is the SECU on the 20th AE different than the other models?
Old 12-02-2008, 01:08 PM
imported_D_Roc's Avatar
installing a starter on my 01 maxima the starter part is fine, but the keyless entry is where i'm really confused, i downloaded severl wiring diagrams and and the one at the A/V section, all the wiring diagrms are the same. but it doesn't match wiht my SECU 's harnesses.like in the diagram says that Power Lock is a brown and yellow on pin #35 but the pin number 35 is empty and but there is a brown and yellow wire at pin number 14. so the correct color wires are there but not in the place where it says should be on the wiring diagram. so is there any way to check the wire using a multi meter
i need to find the wires for
Power Lock
Power Unlock
Trunk Relese
Factory arm
Factory Disarm
Dome light supervision
all these at the SECU
imported_D_Roc is offline
Old 12-02-2008, 03:41 PM
VQP0WER's Avatar
Did you get the bypass module?
You can test for 12v with a probe. It will look like a sharp needle at the end with a little bulb and alligator clip. You pierce the wire insulation and if the light goes on, you have 12v.
VQP0WER is offline
Old 12-30-2008, 04:43 PM
loveofmylife00maxima's Avatar
i suggest bringing it in to a pro cos i just messed up my SECU trying to do that
loveofmylife00maxima is offline
Old 12-30-2008, 04:55 PM
perkman87's Avatar
Last Time I went probing around with a volt meter. I had to have it towed to the dealership. blew 12 fuses and did not think to check. just be careful.
perkman87 is offline
Old 12-30-2008, 05:20 PM
VQP0WER's Avatar
Some of you should not touch a tool then......haha
VQP0WER is offline
Old 12-30-2008, 05:29 PM
nsnrider's Avatar
this thread is almost a month old, i'm sure the OP found out his dillema by now.
nsnrider is offline
Old 12-30-2008, 05:37 PM
perkman87's Avatar
sorry I honestly just wanted to see my new sig lol.
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
doctorpullit
12-12-2015 09:39 AM
ivorton23
09-28-2015 09:08 PM
ik95
09-16-2015 08:11 PM
Quick Reply: is the SECU on the 20th AE different than the other models?
