Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-26-2008, 08:28 AM   #1
Send a message via AIM to CustomLowz
6th gen BBK related question to set something straight
I have been reading alot of threads about the 6th gen BBK setup, how its bolt on and everything. I was thinking about a set of Hawk Pads and Slotted Rotors, for an 04-05 max. I know I need the 6th gen calipers, but my main question is about the caliper bracket. I read in some threads I need the 6th gen bracket to work, and I read in some threads that I do not...
To the point... Will I need a 6th gen caliper bracket for the calipers to use on my 5.5 gen?
__________________
CustomLowz is offline   Reply With Quote
Old 11-26-2008, 08:33 AM   #2
大陆弟弟
n3985's Avatar
Yes you do.
/thread
__________________
n3985 is offline   Reply With Quote
Old 11-26-2008, 03:55 PM   #3
__________________
Old 11-26-2008, 07:34 PM   #4
Send a message via AIM to jeff5347
yes totally different than brackets. you need the 6th gen to make the 6th gen cal and rotor to work.
__________________
http://www.cardomain.com/ride/2547814
AND NO IM NOT A NEWB. BEEN HERE QUITE SOME TIME But thanks for asking
jeff5347 is offline   Reply With Quote
Old 11-26-2008, 07:40 PM   #5
Quote:
huh? so what you are saying is that I CANNOT put the 6th gen front brakes onto my 5.5? If thats the case, then how did all the other members do it?
__________________
Old 11-27-2008, 12:47 AM   #6
They are totaly different brackets in the fact that you cant use a 5.5 bracket with a 6 gen caliper and vice-versa. but the 6th gen bracket will bolt on to the 5.5 knuckle
MR.Large is offline   Reply With Quote
Old 11-27-2008, 05:34 AM   #7
no what i was saying to get the 6th gen to work you need to use all the parts. The 6th gen caliper rotor and bracket. they all bolt up to the 5th gen
__________________
Old 11-27-2008, 06:51 AM   #8
That is what I originaly asked. I know I need the 6th gen calipers, pads, and rotors, but I heard different about the brackets. I just wanted to verify that I needed the 6th gen brackets too.
__________________
Old 11-27-2008, 07:19 AM   #9
My axles cry for mercy...
essential1's Avatar
sorry for the hijack but would this be the same procedure for an a33a/5.0gen? I've only read about people doing the 6th gen BBK on the 5.5 gen if I recal correctly.
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
essential1 is offline   Reply With Quote
Old 11-27-2008, 08:00 AM   #10
what bracket are you talking about? i bought new 6th gen calipers and rotors, bolted right on..i dont recall any bracket....
__________________
2K2 SE 6 speed Grey Lustre SE Every option minus navi, black leather, HLSD, Hotshot headers, Cattman Catback, Frankencar WAI, HP autoworks STS, ES motor mount inserts, ES shifter bushings, FSTB, RSB. JIC FLA-1 coilovers, A34 Brakes Hawk HPS pads, TR Motorsports MT1's, Toyo 4s, 64,000 original owner miles.
HotshotVQ35 is offline   Reply With Quote
Old 11-27-2008, 09:25 AM   #11
Send a message via AIM to s1mply_v
To set this thread straight..
To do the 6th gen BBK, you need;
04+ Maxima:
Brake Rotors
Brake Calipers
Caliper Bracket
Preferably new brake pad shim kit while you have the caliper off
Brake Pads
5th gen brake line can be re-used.
4th gen im not so sure about.
For the 5th gen, you can reuse the caliper bracket bolts that go through your wheel hub no poblem.
For the 4th gen, you can also reuse the caliper bracket bolts BUT will have to drill the bolt holes on your wheel hub to 14mm.
Get it? Got it? Good ;D Happy Turkey Day.
__________________
'01 Merlot SE-SC
Vortech V2 11psi w/ PFTB, Exhaust headers + Megan OE-RS Catback, Apexi Neo, CF Hood, SE-R wheels slammed on D2's, and the list goes on..
'99 Silver SE-L
AE Headlights, AE Wheels, Smoked corner lights, Mini Luda lip, and everything else bone stock..
s1mply_v is offline   Reply With Quote
Old 11-27-2008, 09:28 AM   #12
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
04+ Maxima:
Brake Rotors
Brake Calipers
Caliper Bracket
Brake Pads
Good job setting it straight.
__________________
http://www.cardomain.com/ride/3135334______http://www.cardomain.com/ride/3171620
4th gen. items FS:
-2 sets of 9004 bulbs ($10/set).
-1157 red LED bulbs ($5).
-OEM bumper lights ($20).
-License plate light assembly ($10).
-PM me if interested.
-Shipping/PayPal fee not included..
ChrisMan287 is offline   Reply With Quote
Old 11-27-2008, 09:54 AM   #13
i didnt use a caliper bracket, i just bolted on the complete 6th gen caliper
__________________
Old 11-27-2008, 12:36 PM   #14
essential1's Avatar
Quote:
Chances are that yours came with the bracket already attached to the caliper if you bought it new. I work with auto parts and this is usually how it comes.
__________________
Old 10-05-2009, 10:20 AM   #15
Send a message via AIM to IFuXwiTuZ
lol the bracket is that piece that goes on the rotor before the caliper does...
(its U shaped then caliper goes between it)
__________________
2009 Maxima.....nothing special.....yet
-Mods
8000k HID
Stillen intake, Strut bar, stillen front lip and rear lips.
more mods to come.....
IFuXwiTuZ is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
