i tried and tried
i tried and tried
as the title says i tried and tried to program my remote to my car. i tried both methods.
1)lock all doors-insert more than 6 times-aac-press any button.
2)lock all dors-open trunk with the door button-key in 6 times-manually unlock and lock driver door-press any button.
it still didnt work. what should i do? is there anything i can do other than going to the dealer? nearest infiniti dealer is far so you guys think a nissan dealer could help me?(BTW: its a 2k i30)
thanks in advance.
thanks in advance.
sounds like your remote is toast, I say order one off ebay. There is an fcc id on the back of your remote and on the control module in the car and i think they have to match (might want to check on this). If your remote worked then died you can just look on the remote, but if it never worked i bet it is the wrong code or it's toast.
I am almost 100% sure the i30 and maxima remotes are the same.
Nice quote in the sig by the way... LOL
i baught my car used and it didnt come with a remote so i baught this remote off of ebay. im pretty sure its the right remote and it also says infiniti on the remote.
the remote does work and i also put a brand new battery in it too. a local shop had a machine that checks the remote. and it worked.
so what are my options? there is a nissan dealer close by but the nearest infinti dealer is at least an half hour away.
i read somewhere they can also use some kind of computer or something to program a remote. is that true?
I'm having this same issue. The dealership tested it and said it's sending a signal. Followed the instructions. I get the blink from the flashers, but the remote doesn't work after completing the instructions.
