Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 10-27-2008, 09:37 AM   #1
Inner Tie Rod Spun? Problem?
While loosening up the outer tie rod lock nut, the inner tie rod spun, maybe 3/4 of turn. So in essence, it was broke loose. I put the outer tie rod end, but am now wondering if I need to tighten the inner tie rod? I thought it had some type of locking mechanism on it so I did not worry about it, but I have not pulled the boot off and now I am wondering. Any thoughts? Thanks guys
MaxManOhio is offline   Reply With Quote
Old 10-27-2008, 10:50 AM   #2
Well if it spun 3/4 of a turn i would spin it back, other than that the car will be misaligned if you dont
__________________
2002 Maxima (6-Speed) Charcoal, ADR 18" Black on Chrome Lip Wheels, Cattman High Flow Cat, Stillen Cat-Back, Polk Audio Door Speakers, Viper Alarm
jd885 is offline   Reply With Quote
Old 10-27-2008, 09:31 PM   #3
Send a message via AIM to xnyc
Quote:
the inner tie rod is a ball/socket joint. it will turn. dont worry about it
Quote:
^fail. if it was loose, misalignment would be the least of his concerns.
xnyc is offline   Reply With Quote
Old 10-28-2008, 08:10 AM   #4
Thanks for the responses. The inner tie rod is solid it just got loosened in fighting the lock nut on the outer tie rod end. It is back together and does not move a bit. I figured if it is locked at the outer tie rod end with the lock nut, it could not move. But since I have never messed with suspension work, I wanted to be sure.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
