Fog Light Relay Problem?
Old 09-08-2008, 10:40 AM
pyroz's Avatar
I have a 2k Max. I got HID's in my fogs but they both just went out at the same time yesterday during a storm. I tested both the fogs and ballasts indivually and they all work but it just won't work when i turn on the fog switch.
I know there is a fuse under the steering wheel, which I checked and is still good. Is there any other fuses? Also, I got a relay for the HID in the fogs. Can that be the problem?
Last question, How much does a relay cost if I don't want to make one? Thanks in advance.
pyroz is offline
Old 09-08-2008, 10:47 AM
Nicktard's Avatar
need help too...mine all went out and when i turn them on my relay box buzzes
Nicktard is offline
Old 09-08-2008, 10:51 AM
pyroz's Avatar
yea, my box buzzes too when i flick the fog switch on and off. also, I did the fog rewire if that could be the problem as well. Thanks.
pyroz is offline
Old 09-08-2008, 06:12 PM
Nicktard's Avatar
ok well...it really help you to know but...with how my setup is, its very ghetto, I realized I had my high beam on (which dosnt work) so i turned them off...changed the fuses and now everything works.
its a miracle. lol
Nicktard is offline
Old 09-08-2008, 06:14 PM
jasonmax's Avatar
for my car, fogs only work with low beams. if I turn high beams on, fogs will off.
jasonmax is offline
Old 09-09-2008, 06:37 AM
pyroz's Avatar
is there a way to check the relay in the relay box on the passenger side near the window washing fluid? I've narrowed it down to that relay and the relay harness I used.
pyroz is offline
Old 09-09-2008, 06:54 AM
hi-tek22's Avatar
what do you mean relay harness you used?
if there is another relay in the equation OTHER than the original nissan relay, then that aftermarket relay may have gotten wet
hi-tek22 is offline
Old 09-09-2008, 07:05 AM
大陆弟弟
n3985's Avatar
Have you checked the relay harness fuse and the relay itself? That relay you can buy a replacement at any auto store.
n3985 is offline
Old 09-09-2008, 07:45 AM
pyroz's Avatar
Yea, I used another relay because everytime i turned on the fogs, it blew the 15a fuse, so i had to put an AFTERMARKET relay in place to draw power directly from the battery. You're right, it may have gotten wet because I went through a big puddle this weekend.
pyroz is offline
Old 09-09-2008, 07:46 AM
pyroz's Avatar
where is the relay harness fuse?
pyroz is offline
Old 09-09-2008, 08:28 AM
大陆弟弟
n3985's Avatar
The wire going to the + on the battery will contain the fuse holder.
n3985 is offline
Old 09-09-2008, 08:54 AM
hi-tek22's Avatar
yea that happened to my fogs also and my relay went because it got hit by water
what i did was put it in a small baggie, the food baggies.....and put a zip tie around it with a new relay....buy the exact type of relay on ebay...thats what i did...i purchased a box of them on ebay
just make sure u secure the relay in such a way that it does NOT get wet
hi-tek22 is offline
Old 09-09-2008, 09:11 AM
pyroz's Avatar
yea, i'll do the bag thing too if it does happen to be the relay. anyway, i think i'll be buying a whole new relay harness anyway for $15. funny thing is i put silicone on all the holes and nookies so water can't get in, but apparently, that didn't work.
If I was to replace the whole thing, will this work?
http://cgi.ebay.com/H3-HID-Fuse-Rela...QQcmdZViewItem
pyroz is offline
Old 09-09-2008, 09:24 AM
大陆弟弟
n3985's Avatar
So you confirmed that the fuse is OK? Wiring itself don't usually go bad, fuses and relays do. If fuse was OK, next step is to swap the relay with a new one from ANY auto store for $5.
n3985 is offline
Old 09-09-2008, 09:33 AM
pyroz's Avatar
I will confirm when I get home, but what type of fuses are usually in these harnesses? Are they the same as the ones that I use for the car, 10a, 15a, etc?
pyroz is offline
Old 09-09-2008, 09:45 AM
大陆弟弟
n3985's Avatar
Yes same style, and usually 10A.
n3985 is offline
Old 09-09-2008, 09:50 AM
pyroz's Avatar
thanks a bunch man. will definitely check it out when i get home.
pyroz is offline
Old 09-09-2008, 10:55 AM
pyroz's Avatar
In the auction/picture, where do i connect the blue and black wire to? thanks.
pyroz is offline
Old 05-08-2009, 08:34 AM
大陆弟弟
n3985's Avatar
bump to this thread, my fogs have also mysteriously went out with all fuses and relays working, did you ever get this fixed?
n3985 is offline
Old 05-29-2009, 09:24 PM
sublime258's Avatar
re-bump...I just noticed that my fogs aren't working...stock except for the bulbs...about to try replacing the relay...
sublime258 is offline
vingodine
45
05-21-2016 12:46 PM
EuroDriver
09-14-2015 06:08 PM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
98nismomax
08-13-2015 12:44 PM
Quick Reply: Fog Light Relay Problem?
