Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 09-07-2008, 12:50 PM   #1
tps on a 03 max
I have a 03 max and my ses light... i think it is my tps sensor.... i need the location of this sensor and how do i remove it...
maxs4life is offline   Reply With Quote
Old 09-07-2008, 04:49 PM   #2
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
TPS Sensor help!
What color is the TPS on the 2k2's; where is the ECU
Those ought to give you some help, not sure how much though.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 09-07-2008, 05:22 PM   #3
You "think" it's the sensor.......you better make damn sure......what codes have you? P0222 and P0223 are the associated fault codes. Unless you've gone into fail safe, then I doubt that this is your problem. The sensor is incorporated into the throttle actuator and if it's actually the "TPS", you're looking at a throttle actuator replacement. Checked for loose connectors, bare wires, corroded grounds etc.? Have you disconnected/reconnected the connector on the TB?
P. Samson is offline   Reply With Quote
Old 09-08-2008, 01:54 AM   #4
The Dirty Pearl
pmohr's Avatar
Send a message via AIM to pmohr
Quote:
Not just the throttle motor and electronics assembly itself (as you can't buy those from Nissan) but a whole new throttle chamber. Pricey from Nissan, cheap(er) from a junkyard.
OP could also have a faulty APPS or two, but who knows until he gets back with the code...
OP: PM me if you need a throttle chamber, I can help with that.
pmohr is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
