Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-19-2008, 07:03 AM   #1
It's business time.
Progress's Avatar
Send a message via AIM to Progress
Clutch pedal engine vibration when completely depressed
I just had my slave cylinder replaced.
Now, when I have my foot on the clutch pedal fully depressed and I rev the engine I can feel the engine through the pedal and it sounds slightly different than when I'm not touching the pedal.
I read this thread and it matches matty's description.
clutch issue....can feel engine in clutch pedal!!!...
Should I be concerned? There are no symptoms other than this. It engages, as it always has, almost right off the floor and cleanly. The pressure is the same, consistent throughout the travel. There are no signs of slippage or anything.
It's just strange when I shift gear over 4k and rev the engine with it depressed feeling the motor through the pedal. It's not natural to me.
__________________
Quote:
Originally Posted by Donkey®
You guys win.
Progress is offline   Reply With Quote
Old 08-19-2008, 07:51 PM   #2
It's business time.
Progress's Avatar
Bump.
__________________
You guys win.
Old 08-20-2008, 12:22 AM   #3
sounds like you may have a rough throw out bearing!
CMax03 is offline   Reply With Quote
Old 08-20-2008, 06:01 AM   #4
It's business time.
Progress's Avatar
Wow, that sucks. I just put around $1,000 into the car to fix frozen calipers (entire rear brakes), front sway bar end links and slave cylinder.
How much is it going to cost to have this fixed? Is this something that I can live with and drive the car for a while or is it going to mess up the tranny?
__________________
You guys win.
Old 08-22-2008, 05:55 AM   #5
It's business time.
Progress's Avatar
Any other ideas?
__________________
You guys win.
Old 08-22-2008, 10:15 AM   #6
Quote:
Originally Posted by Progress View Post
... It engages, as it always has, almost right off the floor...
I am not so sure it should be engaging right off the floor. It sounds like it is not disengaging all the way when you depress the clutch pedal. Why... I have no idea. One simple thing to check is to make sure the mat is not stuck under the pedal.
__________________
2003 G35 sedan 6MT
Whiggy is offline   Reply With Quote
Old 08-22-2008, 10:39 AM   #7
It's business time.
Progress's Avatar
Quote:
I thought of that. The mat is no where near the pedal. It is going all the way into the floor.
In first, I can rev the motor and pull the pedal out an inch or so and the tach will stay where it is and the engine will not lug. If it weren't disengaging, wouldn't the engine be affected with the pedal on the floor and it in gear?
Thanks for the response.
__________________
You guys win.
Old 08-22-2008, 10:51 AM   #8
I may be completely wrong here but these are just my thoughts - one inch of pedal movement translates to very little movement of the clutch plate that may not be enough to stall a 200+ hp engine or move a 3000+ lbs. car. (Not the stock clutch at least). The clutch may be engaged just enough for you to feel the vibrations. Is there a way to adjust the clutch pedal to grab a little higher?
__________________
2003 G35 sedan 6MT
Old 08-22-2008, 11:25 AM   #9
Adjust it @ the top of your clutch peddle. The rod that connects to the clutch M/C should have a jam nut and a clevis style rod end! Back in the day( late 60's-mid 70's) even the slave cylinders had adjusts on certain japanese manuals trans.
__________________
Old 08-22-2008, 11:29 AM   #10
It's business time.
Progress's Avatar
Good point. So you think there's friction there even when the pedal is full depressed?
I know the shop that did the work (replaced the slace cylinder), said they did as much as they could to adjust the clutch to engage higher.
Should I be expected to set out at the same task and succeed?
Who's got a link to the FSM? I don't have one on this comp.
__________________
You guys win.
Old 08-22-2008, 11:30 AM   #11
It's business time.
Progress's Avatar
Quote:
How do I even access this stuff?
__________________
You guys win.
Old 08-22-2008, 11:33 AM   #12
lay on your back or side on the driver's side floor and with a bright flashlight you should see the linkage connected the clutch peddle!
__________________
Old 08-22-2008, 11:35 AM   #13
It's business time.
Progress's Avatar
Thanks. I'll definitely give this a shot soon.
FYI FSM: http://www.phatg20.net/component/opt...,select/id,28/
__________________
You guys win.
Old 08-22-2008, 12:07 PM   #14
It's business time.
Progress's Avatar
Okay, so if I follow this I will be able to adjust the clutch to possibly disengage when the pedal is down?
Can anyone verify this. I don't want to be doing this for naught.
http://i5.photobucket.com/albums/y15...g?t=1219431839
__________________
You guys win.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
