Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-11-2008, 07:49 PM   #1
Points: 11,624, Level: 70
Points: 11,624, Level: 70 Points: 11,624, Level: 70 Points: 11,624, Level: 70
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Can't remove O2 sensor...help!
Well, I finally got around to installing my new O2 sensor (P0138/P0139), but I can not get the old freakin' one off! I tried letting the cat get warm and sprayed some PB blaster on, but still no go! I'm afraid of with the cat being so rusted, I do not want to ruin it by trying to get this O2 sensor loose. Any suggestions of how to get this sensor loose? I changed O2 sensors before, but this is the worst difficulty I had trying to change this one. Thanks, any help or suggestions greatly appreciated.
MIXXMAX is offline   Reply With Quote
Old 08-11-2008, 10:52 PM   #2
Points: 14,243, Level: 77
Points: 14,243, Level: 77 Points: 14,243, Level: 77 Points: 14,243, Level: 77
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Send a message via AIM to wyche89
what kind of tools are you using? my suggestion is spraying some more PB blaster, let it sit for a little bit.. rent a 02 sensor kit from auto zone... attach that little device to the biggest breaker bar you can fit in there and just force that b*tch out
of course i didn't need tools when i did mine... i twisted my 02 sensor out with my teeth!
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Short Ram Intake, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Cattman Y-Pipe, Custom 3" Magnaflow Cat-back Exhaust, Tune
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
"I feel the need... the need for speed!"
wyche89 is offline   Reply With Quote
Old 08-12-2008, 06:44 AM   #3
when i did mine, they were fairly easy to get out.....
__________________
Megan Racing exhaust | Tokico Illumina's 4F/5R | H&R Springs | ebay FSTB | | ES Bushings | Goodridge SS Lines | Berk Air Intake | Cleared 2K2 Headlights | 8k D2R & 50W H3 Fogs upgrade | Cleared Sidemarkers | White LED's all around (Interior & Exterior) | Chrome Gauge Rings | 15% Tint (all around) | RTP Zinc plated Slotted Rotors | Hawk HPS pads | RPM R-505 19x8.5 wrapped in General Exclaim UHP 245-35-R19 | Optima Yellow Top | Hella Supertones | (2) 12" Alpine Type R's
hi-tek22 is offline   Reply With Quote
Old 08-12-2008, 09:07 AM   #4
Curb Rash Repair 100 a wheel
Maxima112's Avatar
Points: 12,178, Level: 72
Points: 12,178, Level: 72 Points: 12,178, Level: 72 Points: 12,178, Level: 72
Activity: 0%
Send a message via AIM to Maxima112
Liquid wrench worked for me. I tighten it just a little (one good push) then went started at it, took a while but breaker bar helps ( i used the second half of the bar on the lift)
__________________
Maxima112 is offline   Reply With Quote
Old 08-12-2008, 09:22 AM   #5
FU, FU, FU, You're Cool..
miksen's Avatar
Send a message via AIM to miksen
Mine was stuck too....
I used a hand held torch...the kind you use to sweat household copper plumbing.
Sprayed the thread area w/ WD40 and then heated the sensor for 30-45 seconds. Used a cresent wrench, of all things, no effort involved to remove, came right out.
__________________
02 6spd, Cattman genIII w-megan Bpipe and stock axel back/OTTO Fstb/Progress RSB/Progress-Illumina/32%Tint
miksen is offline   Reply With Quote
Old 08-12-2008, 09:22 AM   #6
Points: 6,831, Level: 54
Points: 6,831, Level: 54 Points: 6,831, Level: 54 Points: 6,831, Level: 54
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
As previously said use a penetrating oil and an oxygen sensor tool. let it sit over night once you soak it down. Make sure you give it a few good taps once you soak it down. Work the sensor back and forth until it comes free.
Teddie18 is offline   Reply With Quote
Old 08-12-2008, 07:10 PM   #7
ummm if it really that hard to take it off .. i say try it with fire .. make it really hot and then use the tool to take it off !
sheabny is offline   Reply With Quote
Old 08-13-2008, 05:24 PM   #8
Activity: 0%
Thanks for all your replies. I'll give it a shot by heating it up with a torch.
Old 08-13-2008, 05:46 PM   #9
Points: 16,176, Level: 81
Points: 16,176, Level: 81 Points: 16,176, Level: 81 Points: 16,176, Level: 81
Activity: 43.4%
Activity: 43.4% Activity: 43.4% Activity: 43.4%
I'm curious as to what kind of wrench (tool) you're using? 1/2" drive ratchet, 3/8" or 1/4"?
CMax03 is offline   Reply With Quote
Old 08-14-2008, 04:26 PM   #10
Activity: 0%
Quote:
O2 sensor socket with 3/8" drive ratchet with long extension bars to get more torque in front of car (clearing the bottom of car and ground while the car is jacked up on stands).
Old 08-15-2008, 12:00 PM   #11
Activity: 43.4%
Is your O2 socket slipping (expanding apart), if the O2 sensor is defective already, cut the wires off and use a 6 pt 1/2" drive deep impact socket with at least a 3ft breaker bar, tighten it a little then loosen it...Good luck!
Old 08-17-2008, 02:51 PM   #12
Points: 12,261, Level: 72
Points: 12,261, Level: 72 Points: 12,261, Level: 72 Points: 12,261, Level: 72
Activity: 0.0%
Activity: 0.0% Activity: 0.0% Activity: 0.0%
Send a message via MSN to 96blkonblkse
Ive used a 22mm wrench (IIRC). But now i have a Snap on o2 sesnor socket and it works much better.
To the OP try using a 1/2 ratchet..you'll need all the torque you can get. Use as few extensions going to the socket. Get a pipe and put it on the end of the ratchet.
__________________
03 E55 AMG - Obsidian Black/Black
Eurocharged Tune, Eurocharged 172mm Pulley, CM30 IC Pump, PLM HE, secondary cat delete, Lowering links
02 Maxima SE - Daily
Bolt ons
00 Durango - Winter
5.9, 3.92lsd, 33's, 3" lift, intake, exhaust, upgraded vb
96blkonblkse is offline   Reply With Quote
Old 08-17-2008, 06:57 PM   #13
retired moderator
irish44j's Avatar
Points: 71,037, Level: 100
Points: 71,037, Level: 100 Points: 71,037, Level: 100 Points: 71,037, Level: 100
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
that's what I had to do. No sense in using the "special 02 sensor socket" if you're getting rid of the sensor. Cut the wires and do what CMax03 said...
and just use an impact gun. Screw all this breaker bar nonsense
__________________
Quote:
Originally Posted by Jeff92se
Again Irish the voice of reason in this coversation.
2000 Maxima SE (sold)
2009 Subaru WRX 280awhp/280awtq
1985 BMW 318i MR Rallycrosser
1970 Triumph GT6+
2008 4Runner SportEdition
The final "mod list" for the maxima (or at least most of it) LINK
The current mod list for the WRXLINK
irish44j is offline   Reply With Quote
Old 08-18-2008, 08:06 PM   #14
Activity: 0%
I finally got it off. I used a blow torch and heated that sucker super hot. Broke loose like a charm. Looking at the threads on the sensor, it was really seized on there. The next hardest part was threading the sensor in the same route as the old one. How do you even get to those clips to hold the sensor to the chassis of the car? Man, you talk about tight, cramped spaces! What I did was just zip-tied the wire to certain places so that the wire did not lean against any hot spots. Cleared code, and all is good now. Thanks guys for all the help.
Old 08-18-2008, 08:34 PM   #15
Activity: 43.4%
You might try to chase the threads and reassemble the new O2 sensor with anti-seize ( it's the 11th commandment) Thou shall not use naked fasteners, threads, nor bungs in high temp areas without anti-seize please!!
Old 08-19-2008, 06:17 PM   #16
Activity: 0%
Done that. In fact, I always use anti-seize on everything I replace that deals with any threads.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
