Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 07-29-2008, 10:27 AM   #1
Send a message via AIM to mist max2000
broken sunroof - gets stuck
So the sunroof will tilt up and down no problem,..but, when I try to fully open it, it drops like normal begins to slide back and after maybe a few inches it just freezes like one of the rails is out of line... anyone have this and/or have a fix besides replacing the entire hardware.. thanks in advance (5.5gen btw)
mist max2000 is offline   Reply With Quote
Old 07-29-2008, 10:45 AM   #2
Send a message via AIM to Prophecy99
Search and you shall succeed
I have to guess and say you disconnected your battery in the last few days and this is why your sunroof is stuck.
Quote:
Originally Posted by gtbigup View Post
page 2-29
RESTARTING THE SUNROOF SLIDING SWITCH:
The sliding switch will become inoperable after the battery terminal is disconnected,the electrical supply interrupted and/or some abnormality detected. Use the following reset proceedures to return sunroof to normal:
1. If the sunroof is open, push the tilting switch repeatedly towards tilt DOWN to fully close the lid.
2. After the lid has closed all the way, keep pushing the tilting switchtowards tilt downfor more than 1 second.
i had the same problem, next time search
__________________
Imagination reveals truths that reality obscures.
02 VQ35DE GLE__-_\:._.:/_-___sold_91 VG30E GXE
[FSTB /H&R /Illuminas /LTB Stage II /20mm Spacers /Hayden 404 ATC /Blehmco Grounding Kit /Stillen F/R Lips /18" Exel RH-5 Gunmetal /Smoked Sides /30% /Taillight Vinyls /Eyelids /PIAA ]
(MY CARDOMAIN) Bleed GREEN
Prophecy99 is offline   Reply With Quote
Old 07-29-2008, 01:06 PM   #3
lol ^^ thanks but no, thats not the case..... the problem is.. it seems as if one of the rails/tracks are bent/broken/out of line.. the sunroof tilts fine.. but when opening.. it starts to open then goes ERR and stops moving, like its getting stuck or it is forcing against something causing it not to open..
Old 07-29-2008, 03:33 PM   #4
Can you see any narrowing of the "groove" ? Have you greased up the assembly?
__________________
03 I35: Transgo Shift kit, H&R front drop with Illuminas 2F-2R, Stage 2 LTB, Progress RSB, FSTB, Front Sway ES Poly Bushings, Spark advance, Hyperground kit, Clear front corners, G35 wheelies, Black n Tan Interior, LED rear conversion.
Norkoastal is offline   Reply With Quote
Old 07-29-2008, 03:47 PM   #5
my roof will somtimes open and sometime not...i guess its depending on its mood or the switch is just bad...
BARBARIUS MAXIMUS is offline   Reply With Quote
Old 07-29-2008, 03:53 PM   #6
03 Maxima, 6spd
Wow... I just had this happen to me after replacing the battery. I kept pressing the buttons and eventually it started to work.... had no idea it was related to the battery being disconnected.
__________________
2003 | 6spd | Eibach Pro Kit | Tokico Illuminas | FTSB | K&N Filter | Redline MT-90
metalpiotr is offline   Reply With Quote
Old 07-29-2008, 04:10 PM   #7
Quote:
i'll look in depth into it tomorrow about the groove so if the groove is narrow u htink i can bend it back? .. no i havnt tried to grease it up but it seems to be full of grease..thanks for the response
__________________
| 2002 6speed|Otto FSTB|Stillen RSTB|Progress RSB|Blhemco LTB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|3K fogs|Hella Supertones|HD CatchCan|Voltage Stabalizer|Shinjiduo Grounding Kitl Berk Intake w/ Apexi filter|Waiting to go on after winter: stillen classic kit/eyelids/custom emblem delete grill l WTB:altima SE-R wheels-PM me
Old 08-01-2008, 08:27 AM   #8
My sunroof just opens whenever it feels like it, scares the crap out of me. So far it's never done while raining!! I just slide the switch to open and then close, and the sunroof shuts again. It's done this about 3 times in about a year. Anyone elses sunroof posessed?
Joe.
The Hulio is offline   Reply With Quote
Old 08-01-2008, 11:24 AM   #9
It's happened to me a few times. I think there may be something in the owners manual.
How I fixed it.
1) open the roof all the way, even if it takes several presses of the button.
2) remove the key from the ignition for a few seconds.
3) close the roof.
4) remove the key from the ignition for a few seconds.
5) Tilt the roof all the way up.
6) remove the key from the ignition for a few seconds.
7) close the roof.
You may have to repeat the process.
__________________
Speed kills. Save Lives. Drive a Honda!
2000 SE manual, Icelandic Pearl.
Montreal, Canada
bert is offline   Reply With Quote
Old 08-01-2008, 03:17 PM   #10
thanks^^ but i cant even get it to open all the way.. it starts to open and then !@#$#$^$%&%^* as if there is something blocking it not allowing it to open IE bent rail .. or ect..any more advice?
Old 08-02-2008, 12:22 AM   #11
On occasion,my sunroof will tilt open on its own....Luckily it never rained when it did this.
__________________
T.TURTLES MAXNOUT: RIP 95 Maxi...Gone but never forgotten.
95 Maxnout is offline   Reply With Quote
Old 08-04-2008, 06:20 PM   #12
Mine opens by itself too, and it happened while raining on the expressway. Yah that was fun.
__________________
PulsarGTS is online now   Reply With Quote
Old 10-25-2008, 07:52 PM   #13
Sunroom still stuck
My 2006 Maxima still does not work. I have tried the reset everyone mentions to no avail. What mine does is just click. I can hear it click about where the motor is. I am not sure if this is a relay or what. Any other suggestions?
iwall8023 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
