5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Think I found why my front brakes were making a grinding sound
Driving me nuts hearing my brakes grind when I knew I had a lot of pad left. I went ahead and bought some new ProStop Ceramic pads (had them on my 626, great pads) at Pep Boys. Pulled off the old pads and this is what I found on the right front:
It appears whatever metallic material used was causing some very light grooving in the pad itself-you should be able to see it in the top part of the pad. Didn't seen any problems with the rotors.
No idea who made the pads on the car, they have an "AM" stamped on them. Anyway, I bedded in the new brakes and stopping is now grind free.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
I painted the hub area of all 8 of my rotors (yes, 8: 4 on the car, 4 spares ready to go) with black hi-temp spray paint. Cut out a template from cardboard, degreased and acetone'd the hub areas, and sprayed 'em.
One of my brakes is making that grind. Will check it out!
I just replaced all 4 of my rotors with Brembo blanks about a week ago, as well as replaced OEM pads with Hawk HPS. After only a couple days of rain, my new shiny rotors became bright orange around the hub with rust...WTF? Is there anything I can do to fix this before it gets worse, and to prevent it in the future? I might have to try what AJ~ did...any easier solutions?
yeah, i had the exact same issue when i got my brembo rotors.. i was pissed! i think i even posted a thread about it... but short of painting them, there's not much you can do... to prevent that in the future, get a set of zinc plated rotors.. they will not rust
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Custom 3" Magnaflow Cat-back Exhaust
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
Yes....drive your car around. When you apply the brakes a few times, the rust from the rain will go away.
I don't mean on the actual part where the pads touch, I mean on the hub part.
Quote:
Originally Posted by huffdaddy2008
Those are tokico blues
Quote:
Originally Posted by wyche89
thats why they call them tokico blues... cause they're blue.. get it!! ha!
alright, corny joke...
I was asking because I thought he had Illuminas.
Thanks, maybe I'll try painting them black or something...
thats why i used high temp paint on everything that the pads wouldnt touch
