Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-21-2008, 03:41 PM   #1
A/C cycling and engine temp going up
Last weekend during the blasting heat, my ACs cold air died. I turned it off for a few minutes and turned it back on. It lasted about 10 min and died again. Did the same thing a few times. What I noticed is that my engine temp shot up to the line while the AC was on, and came back to normal when the AC shut down. I looked at the Haynes manual over the weekend (no dice), and searched here, but the similar threads went unanswered (2000, 2003). Any suggestions?
Thanks,
g
geenowalker is offline   Reply With Quote
Old 07-21-2008, 04:20 PM   #2
Check to see if your radiator fans are turning on when AC is selected. They both need to be running.
Might as well change out the thermostat and engine temp sensor while your in there.
VQP0WER is offline   Reply With Quote
Old 07-21-2008, 04:25 PM   #3
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
your cooling system isnt working properly....coolant isnt moving....clogged radiator
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 07-21-2008, 04:54 PM   #4
Puerto Rico-Maxima Lover
Lontar1's Avatar
as soonerfan said... clogged readiatgor.. flush it or replace it. Also look at the fans...
__________________
AT TRANNY FLUSH
http://www.cardomain.com/ride/335521/3
Lontar1 is offline   Reply With Quote
Old 07-21-2008, 05:27 PM   #5
Just check that your fans are both on when the A/c is on! If not check your fuses and relays!
CMax03 is offline   Reply With Quote
Old 07-22-2008, 07:08 AM   #6
Thanks for the responses. I will check the fans first as that is free. If the radiator was clogged, wouldn't the engine run hotter than normal while the AC was off? I just had the radiator flushed last summer, would they have found the clog then? How hard is it to change the thermostat nad engine temp sensor. I am sure I can probably find a "How to" here somewhere?
Old 07-23-2008, 05:43 PM   #7
Quote:
remove the thermostat and run your vehicle, see where the temp is now... be sure to boil a pot of water and visually see if the thermostat is fully opening...
Old 07-23-2008, 07:54 PM   #8
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
I can almost guarantee you have a fan or a fan relay issue. If the temperature only goes up when the a/c is on, then odds are the a/c fan isn't coming on. Every single time I've had the same exact issue in my old Accord or 626, it was either a dead fan or a bad fan relay.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 07-23-2008, 11:37 PM   #9
Send a message via AIM to Pearltt
Quote:
My car was doing the same thing last year....the middle part of the radiator was clogged...the temp only went up when I had the A/C on...
__________________
Pearltt is offline   Reply With Quote
Old 07-24-2008, 03:36 PM   #10
how do I check a clogged radiator?
Old 07-24-2008, 04:13 PM   #11
Scottwax's Avatar
Have you checked to make sure both fans are running when the a/c is on yet? I'd eliminate the fans as the cause first because that is by far the easiest to check. Either they are both on or not.
Old 07-25-2008, 07:42 PM   #12
check that you have no debris in between radiator and condenser. Also if you want get a powerwasher and clean the fins up.
__________________
LTB stage II, Progress RSB, FSTB, Poly bushings, Progress/illumina, 6th gen brakes, Motegi and T1R,
NisTech is offline   Reply With Quote
Old 07-25-2008, 08:27 PM   #13
The originator still has neither confirmed fan operation with the AC selected ON, or when the temp gauge went into the "hot" area. Normally the fans should kick on long before the temp gauge gets into the "hot" area. Especially in the heat of the summer if the car is sitting and idling (AC Off) the fans should eventually come on (cycling on and off) and the temp gauge will still not have moved. With the AC selected ON and actually operating, the fans should come on below about 5 MPH, I think it is. With the Maxi's "smoothed" temp gauge it only moves into the "hot" zone when the actual engine coolant temp is "really up there". It does not normally respond to engine loads like in the "old" days. Until fan operation is confirmed it's premature to blame anything else.
P. Samson is offline   Reply With Quote
Old 07-28-2008, 06:02 PM   #14
guys Im having the same problem.. whenever Im sitting still with the air on the engine gets hot pretty quick but cools down as soon as I turn the air off.. Im sure the 100 degree weather doesnt help and it only seems to do it when Im sitting in traffic, not getting clean air.. Ive checked the fans and both are running, coolant was at MIN last week after it happened the first time, I topped it off but it happened again yesterday.. Im thinking it may be a clogged radiator, is it worth doing myself??
d4ster3 is offline   Reply With Quote
Old 07-28-2008, 10:25 PM   #15
Scottwax's Avatar
You should be able to pick up a radiator for $135-150 (and I think there is one in the 5th gen classifieds for $90) and install it in under 2 hours.
Old 07-29-2008, 11:53 AM   #16
should I not try flushing the radiator?
Old 07-29-2008, 11:59 AM   #17
all teh single ladiez
this happened to me last week. my AC compressor ended up seizing up, and cracking the alternator.
__________________
hybridioN is offline   Reply With Quote
Old 07-29-2008, 02:44 PM   #18
Scottwax's Avatar
Quote:
You can try that first but often when you already have overheating issues, flushing the radiator only makes a marginal improvement. My son's old Cavalier would run hot, especially with the a/c on. The fan was working properly, there was just poor flow through the radiator. He had it flushed out professionally (full power flush and all new coolant) and there was very little improvement and the car continued to run hot. Before he could replace the radiator, the car was rear-ended and totaled so problem solved.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
