Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 06-12-2008, 09:28 PM   #1
Send a message via AIM to TurboS13Hatch
No spark...
Figured I would post in the 5th gen section.. I have a swapped vehicle, using A33B VQ35 ECU, harness and engine.. I have the key programmed, and no codes are present, but, I am getting no spark. I have fuel.. as all of the plugs have fuel on them after cranking.. but, no spark whatsoever.. The coils have power and ground, and I traced the signal wire back to the ECU for all 6.. everything appears in order on the wiring side.. No crank or cam sensor codes.. I'm thinking bad ECU..?
Travis
TurboS13Hatch is offline   Reply With Quote
Old 06-12-2008, 09:42 PM   #2
Let's build something!
oldngivout's Avatar
Isn't this the car that previously ran? What has happened?
oldngivout is offline   Reply With Quote
Old 06-13-2008, 08:25 AM   #3
Nah.. this one has never run.. I do 1-2 per month.. This one is fresh.. just trying to get it to crank up. I've never run into a fuel, but no spark situation..
Old 06-13-2008, 08:36 AM   #4
oldngivout's Avatar
So did you use Consult II with the NATS card to program the key?
You may still have immobilizer issues. I think that only using the NATS software will you be able to detect that code. I don't think it comes up using the regular Consult II menu.
Old 06-13-2008, 09:14 AM   #5
Yeah.. I have the diagnostics and NATS cards.. I programmed the key with NATS card, and cycled the key about 20 times, with no codes.. so we're good there.. The diagnostics check only shows a few misc. emissions codes (Evap, and such). Nothing critical that would keep the engine from starting.
Travis
Old 06-13-2008, 09:23 AM   #6
oldngivout's Avatar
Well, you do realize that the final step of the key initialization procedure is to start the car? So if the car did not ever start, then perhaps the procedure did not take. The cycling of the key has nothing to do with it.
Old 06-13-2008, 09:36 AM   #7
Whether or not the engine actually starts has no bearing on whether or not the IMMU/ECU accept the transponder key. Power cycling ECU/IMMU with the correct key is sufficient. If, after 5 attempts, the system doesn't lock down, then, you know that you've got it programmed correctly.
Travis
Old 06-13-2008, 09:48 AM   #8
oldngivout's Avatar
I guess I didn't know that.
The only way I have ever confirmed proper programming is when the engine starts.
Old 06-13-2008, 11:34 AM   #9
Nah.. you just have to cycle the key once (allowing the ECCS relay to fully turn off.. which takes about 3 seconds).
I got the car to start.. Turns out.. there's more than one hall effect sensor that will bolt in for the Crank position sensor.. I figured that they were all the same.. but, they're not. If you rotate the sensor.. it gives a different reading, or none at all. I had a cam position sensor installed, and it was sideways.. It didn't throw a code, but, it didn't give the correct signal to the ECU. I noticed that while cranking.. my timing was -7 degrees.. I went to Nissan and grabbed a maxima crank sensor, and installed it.. and it fired right up.
So.. long story made short.. a cam position sensor will bolt in, but, will not read properly. Also, it will not throw a code, for some reason..
Travis
Old 06-13-2008, 11:45 AM   #10
Send a message via MSN to Professor
cam sensor ugg
__________________
Eibach Springs|HIDs|20% Tint|Custom Stereo|Custom LED Interior|GAB|Brembo Sport Drilled Rotors|Hawk Hps pads |SE Tails|AE Headlight Coversion
SHIFT_auto rolling
Professor is offline   Reply With Quote
Old 06-13-2008, 04:18 PM   #11
So.. it runs.. but, it takes a good 4-5 seconds of cranking for it to start. I am throwing a crank position sensor circuit code. I have checked the harness back to the ECU, and can't find any fault. It turns out, the sensor that I have in there is turned a different direction than the one that's supposed to be in there. It's not reading the sensor for some reason.. but, My God.. how hard could it be?! It's just a hall effect sensor!
On the consult.. I don't see any RPM signal when I'm cranking.. after about 4-5 seconds.. both cam sensors show 63 degrees, and the the RPM starts reading. I'm thinking that after so many seconds of cranking.. the ECU looking at the cam sensors, and figures out where number 1 TDC is..
Travis
Old 06-13-2008, 05:39 PM   #12
yes it will show actually.
__________________
NisTech is offline   Reply With Quote
Old 06-14-2008, 12:44 PM   #13
Any other ideas as far as the crank sensor? I've tried a new one from Nissan.. It wasn't the exact part number.. (didn't have the right one in stock), but, it should work just the same...? It's just a magnetic pickup..
I still get a crank position sensor circuit code.. and no RPM shown on the consult when I crank. After 4-5 seconds of cranking.. the cam position sensors jump from zero to 63*, and then, the RPM starts to read. The engine fires up at this time.
I think that after so many seconds.. the cam sensors figure out where number 1 TDC is, and calculate a firing order. I talked to JWT, and they confirmed this.. So, I checked the harness, back to the ECU for the crank position sensor.. and all is good there..
I have another ECU on order.. but, I'm still thinking that maybe we have the wrong sensor installed..
Travis
Old 06-15-2008, 11:35 AM   #14
The Dirty Pearl
pmohr's Avatar
Send a message via AIM to pmohr
Travis
Does it run with no problems, or does it misfire and like to bog out?
pmohr is online now   Reply With Quote
Old 06-15-2008, 02:54 PM   #15
It runs fine.. It's a little slow, because the VTC isn't working (doesn't work when the ECU runs solely off of the cam sensors), but, it doesn't misfire or bog..
Travis
Old 06-15-2008, 03:18 PM   #16
The Dirty Pearl
pmohr's Avatar
Travis
Ah, okay. Was going to say, we had a customer come in recently (with a self installed APS ST kit...that should say enough) that somehow managed to get the flywheel fully bolted down 3 bolts clockwise of where it should've been (for that timing dowel). It ran, but not all too well, took forever to start up, showed ~-10 degrees of cam timing at idle.
Old 06-16-2008, 01:13 AM   #17
heh.. gotta love that.. JWT epoxies the hole that's not supposed to be used.. since one flywheel is made for the FWD and RWD VQ35.. I always make sure to double check, too.. I'm showing 63 degrees of cam timing while cranking.. but, no RPM signal from the crank position sensor.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
