Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-05-2009, 07:15 AM   #241
Quote:
Originally Posted by mandyfig View Post
When you purchase the MAF it shows the entire assembly comes with it. Not only the sensor. Is this accurate?
I have checked this item on the courtesyparts...it shows the whole assembly.
Yes the whole assembly (MAF screen, outer plastic tube, & the actual sensor). The note I got in mine says it requires special programming though....
__________________
137k miles
To-do: Belts, Fix suspension problem
Major probs fixed: L
ower oil pan | Radiator | EVAP canister/valve| VIAS Control Valve | Rear VC | Exhaust hole near axle
ridinwitha35 is offline   Reply With Quote
Old 11-05-2009, 07:37 AM   #242
I checked my MAF, it does have the security torx in it so I need to get the special tool. HF has it for $7.99 for a 100 pc set. Now that's a deal.
mandyfig is offline   Reply With Quote
Old 11-05-2009, 07:38 AM   #243
Will definitely do this this weekend. Will also disconnect battery for the re-learn. Keeping fingers crossed that no CEL shows up after.
Old 11-05-2009, 07:39 AM   #244
Where is the OBDII connector for the 2000 MAX?
Old 11-05-2009, 01:23 PM   #245
Under the steering column, slightly left off it
sontakke is offline   Reply With Quote
Old 11-05-2009, 02:14 PM   #246
Thanks. How much is a CRC MAF Cleaner?
Old 11-05-2009, 02:45 PM   #247
Checked it out, $7 tops. Lots of reviews on the net. Good stuff.
Old 11-08-2009, 05:58 PM   #248
I just received new MAF but has the Thermister. My old one did not have this, so can I use this one with the Thermister or do I need to remove it? I have read through this topic several times and did many searched and the only thing I have found is when using a 2k or 2k1 with a 2k2 or 2k3. Mine is a 2k '00 5th not a 5.5 model. Thanks in advanced.
scapi is offline   Reply With Quote
Old 11-08-2009, 06:28 PM   #249
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
Quote:
why would you buy the expensive one when you can just use a cheaper one?
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 11-08-2009, 06:36 PM   #250
Great write. I was seeking that performance me 2k maxima had on my 2k2 maxima and this seems to have given my 2k2 maxima that performance I was looking for.
asma123 is offline   Reply With Quote
Old 11-09-2009, 04:09 PM   #251
Ordered off eBay ($64.00) said it was for 2k and was not aware at the time that there were different ones for 2k until I received it. I went ahead and installed it and the power is back but now it will die every now and while idling.our
Thanks for your original post wish I would have found this first.
Old 11-18-2009, 05:54 AM   #252
Nice job. I ended up having to replace the MAF because the cleaning did not work. I wish I would have had a thorough procedure like the one you posted. Thanks!
maximadude3 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
