Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-29-2008, 08:41 PM   #81
Send a message via AIM to Kevin319
Thanks ryant, will try out your method once it stops raining here.
Kevin319 is offline   Reply With Quote
Old 08-30-2008, 03:18 AM   #82
Need help asap. So i have everythin i need to clean the MAF and I was looking at ur pics and my bolts that hold the MAF are the same except one thing...theres small metal things in the middle of the bolt preventing the torx driver from mating with the bolt. Its almost as if u need a special drill bit or something to take off those bolts.
Its hard to show explain w/o pics, but does any1 else have this problem and where can i go to get this "special" tool to take off those 2 bolts?
~2000 Maxima GXE~
Japican is offline   Reply With Quote
Old 08-30-2008, 06:20 AM   #83
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
~2000 Maxima GXE~
is there a small pin thing in the middle of the screw? if there is, that's a Security TORX screw which looks like this.
you will need special screwdriver to screw it out, which should be looking like this one.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 08-30-2008, 08:53 AM   #84
Yes thats exactly it. Where would I be able to find this specific torx security driver?
Old 08-30-2008, 09:47 AM   #85
local autozone?
__________________
Old 08-30-2008, 09:57 AM   #86
I'm still not really noticing a difference. Maybe they put a brand new on in it when I got it
PhalC1 is offline   Reply With Quote
Old 08-30-2008, 10:02 AM   #87
Nope, they said its actually very difficult to find. I called the local Nissan dealership and they they had one, but wouldnt let me use it lol. They too said its very difficult to find. This is starting to aggravate me
Old 08-30-2008, 10:20 AM   #88
My next guess would be Home Depot then
Old 08-30-2008, 10:55 AM   #89
I found this at my local harbor freight for $9
http://www.harborfreight.com/cpi/cta...emnumber=91310
Quote:
__________________
2002 Maxima SE
GReddy Power Extreme, GAB, and a nice dent on my rear bumper.
theStig is offline   Reply With Quote
Old 08-30-2008, 12:57 PM   #90
I had the same problem. I ended up having to buy a little kit of heads from Autozone. I think it ran me like $7 for the heads kit. Aggravating to say the least.
Bradbmx1 is offline   Reply With Quote
Old 08-30-2008, 07:41 PM   #91
Pepboys should definitely have it. I got mines from their for $13, bought a little box with a few extra tools in it.
Old 08-30-2008, 08:40 PM   #92
Send a message via AIM to scarface4522 Send a message via Yahoo to scarface4522
im doin this tomorrow, hopefully i dont have a security torx screw like some of you guys
scarface4522 is offline   Reply With Quote
Old 08-30-2008, 11:42 PM   #93
If you can't find the security torx screw bit you can remote the entire air box and clean the MAF inside the tube through the screen. That's what I did since I didn't know I could remove the MAF itself.
__________________
Upgrade from 95 to 95 to 2000
ryant35 is offline   Reply With Quote
Old 08-31-2008, 01:25 AM   #94
Send a message via AIM to AznTran517
time to clean mines since i just replaced my MAF sensor with a used one. I know my man from firestone let me used the torx screw so i could replace my MAF the other day. Maybe if you ask someone nicely they'll let u used it lol
AznTran517 is offline   Reply With Quote
Old 08-31-2008, 10:04 AM   #95
Hey Ryant I have a question, I removed my connector today using the advice you gave me. Everything turned out great until taking out the MAF. It would not budge a bit and I tried using force to pull it up and even with a wrench it wouldn't move. I tried your "turn it 90 degrees" but it doesnt turn as well. Will I damage my MAF if I use too much force into taking the thing out? Also, is the "you can remote the entire air box and clean the MAF inside the tube through the screen" just as effective as cleaning the MAF itself? Since I am having a very hard time taking out my MAF, should I resort to cleaning the air box?
Old 08-31-2008, 10:27 AM   #96
Quote:
It worked great for me, the MAF cleaner as a lot of pressure, so spraying through the screen at between the MAF tube & air box isn't a problem. After removing the air box there are 4 bolts that hold on the MAF tube.
So may be able to remove these 4 bolts with out removing the air box, but I've never tried it.
__________________
Old 08-31-2008, 11:13 AM   #97
Thanks again Ryant, I got someone else to remove the MAF for me and it seems he can do it without putting any effort into it. After cleaning the MAF and reconnecting the connectors, my car would not start. So I guess I have to do the ECU reset/Idle relearn procedures?
Edit: I searched the sticky threads but they did not have a ECU reset procedures for a 2000 Maxima, is their an ECU reset procedures for 2000?
Old 08-31-2008, 11:58 AM   #98
ummm... I don't know, mine has started fine after the 2 times I've done this...
__________________
Old 08-31-2008, 12:15 PM   #99
yeah, 2000s are easy. just simply unplug the battery.
__________________
Old 08-31-2008, 02:39 PM   #100
Unplug and replug will reset the ECU? Thanks for the info.
Old 09-02-2008, 10:37 AM   #101
So did it work?
__________________
Old 09-04-2008, 09:19 AM   #102
I performed this procedure last night and it worked well. At the same time changed the oil and air filter and so far, 60 miles later and no SES light anymore.
Quick question though....after I re-installed the MAF when I plugged in the the wire harness there was no "click" and I could easily pull the connection back apart. Is this normal?
My car is a 2000 I30-t.
NOTE: You can buy the "security" Torx wrench in a set that looks like allen wrenches from Autozone for $10.
__________________
I am the warranty.
00gxe5sp is offline   Reply With Quote
Old 09-04-2008, 12:39 PM   #103
the socket should have locked when you pluged in.
__________________
Old 09-04-2008, 07:26 PM   #104
i did this on my 2003 se. certainly noticed things smoothed out a bit. Less bucking in 1st when it's cold (as in almost none), smoother start and idle, better low end but REALLY noticed a difference around 4k. I was like "oh hello there, mid range power" Now i wanna do a grounding kit and an o2 sim for my bad post y-pipe sensor. stupid 4 sensor setup.
Mattlikespeoples is offline   Reply With Quote
Old 09-04-2008, 10:25 PM   #105
prl wht '02
Yes! Finally. After doing this procedure I finally cured my inconsistant idle problem. I put a new '06 6spd tranny in my '02 and since then my idle was low and even stalling when putting in the clutch. It was like it just went too low then died. It got a little better over the summer but still idled around 200rpm. After cleaning the maf my idle is now around 800 and consistant!! Very happy!!
Brandon Anderson is offline   Reply With Quote
Old 09-04-2008, 10:48 PM   #106
wait, i thought only peple with 15 posts could post anywhere but the 'noob questions' thread. Glad that this fized your problems regardless
Old 09-04-2008, 10:57 PM   #107
Quote:
It's been a while since I've been a noob, but I thought it was no new threads for 15 posts... unless the rules changed.
__________________
Old 09-07-2008, 12:53 PM   #108
Im in Toronto, Canada, anyone know what store i can purchase it from? ( the CNC MAF cleaner)??
__________________
makaveli_13 is offline   Reply With Quote
Old 09-07-2008, 02:13 PM   #109
Quote:
What auto parts stores do you have up there?
I did a quick Google maps search and found Napa stores but I cannot find the MAF Cleaner on their website. You may have to order it online.
__________________
Old 09-07-2008, 04:19 PM   #110
I am going to try this tomorrow. My bog has gotten bad and my idle makes it feel like a diesel..
__________________
2002 Maxima SE - 6 speed
sc0tty8 is offline   Reply With Quote
Old 09-07-2008, 06:37 PM   #111
i have (that i know of/visited in the past) Candian Tire, which is a Huge auto store, napa, part source... those are the main three.
and btw thanks for looking.
__________________
Old 09-07-2008, 07:49 PM   #112
Send a message via AIM to Nicktard
My MAF had the security torx bolt too....i just used a vice grip and it came out easy
__________________
Car Domain:
http://cardomain.com/ride/3143303
Nicktard is offline   Reply With Quote
Old 09-10-2008, 08:18 AM   #113
So after a week of searching i finally found the security lock for those 2 stupid bolts @ Murrays, but it was def worth the search. After cleaning my friends MAF her car no longer stalls or stumbles. It still roughly idles at times, but cleaning the MAF def made a huge difference. She is extremely grateful that she didnt have to take her car into a shop and get it fixed for $xxx.xx
Old 09-10-2008, 08:25 AM   #114
can i use the CRC QD Electronics Parts Cleaner? Is that the same as CRC MAF cleaner?
fuctkeen is offline   Reply With Quote
Old 09-10-2008, 10:08 AM   #115
Send a message via AIM to Tippy Toes Send a message via Yahoo to Tippy Toes Send a message via Skype™ to Tippy Toes
If im hearing this right when you unplug the battery and replug it back in afterwards thats an ecu reset? Anyone have the reset or learn procedure. I dont have a problem with the MAF but maybe I'm missing some power because it hasnt been cleaned?
Tippy Toes is offline   Reply With Quote
Old 09-10-2008, 11:25 AM   #116
Quote:
As long as it says MAF cleaner you should be ok. I'm sure they wouldnt put any harmful things in the cleaners when it comes to a MAF cleaner
__________________
2001 SE
Debadged | Silvered Corner Lights | 2 Degree Timing Advance | Ghetto'd Short Ram | OSCAI
Old 09-10-2008, 09:29 PM   #117
ok, i think i need to do the relearn procedure. I'm getting worse (not terrible) MPG and it's not performing quite how it was right after i did this. Doesn't make too much sense but my SES light went off. Maybe I'm running rich or something.
Old 09-11-2008, 07:52 AM   #118
The MAF cleaner smells like electronics part cleaner, but I would just get the MAF cleaner. It's not worth saving a couple of bucks considering what a new MAF costs.
__________________
Old 09-11-2008, 08:54 AM   #119
it's the same price, but all they had was the "QD Electronics Part Cleaner" at Wal-Mart.
Old 09-11-2008, 10:18 AM   #120
did you resinstall the MAF correctly?
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
