Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-12-2008, 03:01 PM   #41
I'm planning on doing this later, but am confused by one step. What is the purpose of the pipe? You say to "Take you MAF cleaner and put the pipe on it, so you can reach small areas. When you clean the MAF, DO NOT touch anything in side the tunnel with the pipe because that can damage the sensor." ?? Do I spray the pipe and insert it into the tunnels? How do I apply the cleaner to the side of the tunnels without physically touching them? Do i just spray the entire thing down including the tunnels? Can someone please clarify this for me?
MikeyC1027 is offline   Reply With Quote
Old 06-12-2008, 04:46 PM   #42
Send a message via ICQ to jasonmax Send a message via MSN to jasonmax
Quote:
you put the red pipe/straw on the can.
the pipe makes the spary more focus and stronger and easier to point.
don't touch anything on the maf when you cleaning it.
don't spray the entire thing, just tunnels.
__________________
Life would be boring without the Maxima.
From Nebraska? Go here: http://forums.maxima.org/midwest-tex...ebraska-9.html
You wanna clean your MAF under 10 bucks? Go there:http://forums.maxima.org/5th-generat...10-w-pics.html
jasonmax is offline   Reply With Quote
Old 06-12-2008, 04:57 PM   #43
Oh OK gotcha...Tyvm for clearing that up as well as posting this How-To
Old 07-27-2008, 11:14 AM   #44
Send a message via AIM to Nicktard
How do you perform the ECU reset and Idle relearn procedures? I've also heard that some people use brake parts cleaner, it dosn't leave resin. They said that the MAF cleaner will leave that oil on it and it can mess up the sensor later on.
Nicktard is offline   Reply With Quote
Old 07-27-2008, 01:08 PM   #45
Quote:
there is no oil in the cleaner. where does that come from?
reset procedure, please search.
__________________
Old 07-27-2008, 02:45 PM   #46
Automagic Baby
johnnyd2k2's Avatar
Is the idle relearn procedure nessacary I read a few people say they didn't do it so what are the pros of doing this PIA procedure
johnnyd2k2 is offline   Reply With Quote
Old 07-27-2008, 04:57 PM   #47
I took it out....and noticed that I dont have the metal piece around the front. What kind of problem is this?
Old 07-27-2008, 06:23 PM   #48
00-01 maximas don't have this transitor IIRC.
__________________
Old 07-27-2008, 06:25 PM   #49
Quote:
infact, I believe the engine will get used to the cleaned MAF sooner or later, but doing the relearn and reset won't hurt, right?
__________________
Old 07-27-2008, 07:05 PM   #50
Thats good new about the resistor. idk about anyone else but whenever i work on my car...i finish the job and something else goes wrong in this case....cleaned my MAF, Put in a new dome light...and then I blew my ballast for my fog lights. great...no what
Old 07-27-2008, 07:22 PM   #51
Maxgig's Avatar
Man I don't believe it's that easy. I actually paid to have that done before I moved to AL.
__________________
03 SE Sterling Mist, 6 spd, T.E. 89,452 miles - Stillen FSB - Hawk pads - 350Z AE rims - Cosmo CAI - 35% tint - Redline MT90 - rear louver - track visors - 04 valve cover fix - 3&5mm wheel spacers - free STS mod...more 2 follow, 97 SE "SuperBlak," Max, 147,275 miles "SOLD": see the Mist www.cardomain.com/ride/831971 new toy "69 Mercury Cougar" blk tag, #'s matching, blueprinted, rebuilt 351W, blk on blk, super faaast, picked up 30 July
Maxgig is offline   Reply With Quote
Old 07-29-2008, 03:51 PM   #52
wish i would have saw this before i changed mine
BARBARIUS MAXIMUS is offline   Reply With Quote
Old 07-29-2008, 09:06 PM   #53
Send a message via Yahoo to damerbullet
Great pictures! Great write-up!
Two-thumbs up!
Thanks!!!
__________________
AMD - Atlanta Maxima Drivers
|18" Privat Reserv | Eibach Springs | KYB - GR2 | Akebono pads | Progress RSB | Megan Racing FSTB | 28% Tint |Super White Bulbs | Grounding Kit | Clear corners | Stillen Hi-Flow Intake |
damerbullet is offline   Reply With Quote
Old 08-20-2008, 12:38 AM   #54
2002 maxima se
OC guy's Avatar
Can we also spray on that little metal wire transitor IIRC in the middle or whatever it called? and what is the resistor thing?
OC guy is offline   Reply With Quote
Old 08-20-2008, 08:31 AM   #55
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Spray the hell out of everything.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 08-21-2008, 01:00 PM   #56
Quote:
that's the air temp sensor.
__________________
Old 08-24-2008, 02:06 PM   #57
Hey guys, New-B here though this is my 2nd maxima. I have a 2000 SE 5spd. Prior to cleaning the MAF using the steps above I had a CEL, intermittent stalling and a code P0430. I used my friends Snap-On Scanner to look at the O2 sensors and Bank 1 sensor 2 was "frozen" After cleaning my MAF and driving approx.20 miles, the CEL and the stalling are both gone. I haven't been able to get the scanner on the car yet to see if bank 1 sensor 2 is actually working or not. Is it possible that a dirty/contaminated MAF could have caused the code and the stalling. Thanks for entertaining a new-b question.
shiftyse is offline   Reply With Quote
Old 08-24-2008, 03:15 PM   #58
Quote:
I don't think the MAF will cause stalling, but it could be the problem although an engine will run w/o a MAF. did you let the cleaner dry before putting the MAF back?
__________________
Old 08-24-2008, 07:01 PM   #59
will be doing this coming weekend. Thanks!
tbonesteak is offline   Reply With Quote
Old 08-25-2008, 01:17 AM   #60
I just did this but before I saw this thread and I took out my entire air box... I guess it saved me having to buy a torx screwdriver.
__________________
Upgrade from 95 to 95 to 2000
ryant35 is offline   Reply With Quote
Old 08-25-2008, 01:18 AM   #61
My car was stalling at idle before I cleaned my MAF, now it's fine and more responsive.
__________________
Old 08-25-2008, 03:58 PM   #62
03 Maxima, 6spd
metalpiotr's Avatar
My car started stalling right after being started when warm, so I cleaned my MAF. It did not make the problem go away, but I honestly do feel like I got some power and responsiveness back.
__________________
2003 | 6spd HLSD | Eibach Pro Kit | Tokico Illuminas | FTSB | ES Motor Mounts | ES Shifter Bushings | Grounding Kit | Redline MT-90
metalpiotr is offline   Reply With Quote
Old 08-25-2008, 05:18 PM   #63
Hey New-B here, I did let the MAF dry completely before re-installing it. I have driven the car about 45 miles now and the CEL is still out however on the way home today, the car started stalling again as soon as I put the clutch in. The wierd thing is, if I shut the car off for about 1 minute or so and re-start it, the car idles fine. Any ideas before I resort to the dealer????
Old 08-25-2008, 06:52 PM   #64
codes?
I don't think it the cleaning that cause the stalling cuz mine is fine. should be a coinsidence.
__________________
Old 08-25-2008, 06:54 PM   #65
Quote:
maybe it's the O2 sensors?
__________________
Old 08-25-2008, 07:54 PM   #66
03 Maxima, 6spd
metalpiotr's Avatar
wouldn't those throw some codes?
I have a thread on it here:
03 maxima stalls right after startup when engine warm. Please help!
don't want hijack this one. btw, this is a great thread with good pictures, Jason. I'm definitely glad I cleaned the MAF sensor.
__________________
Old 08-26-2008, 01:41 PM   #67
on a 4th gen., wouldn't you spray everything in the in the short tubing with MAF cleaner, including the temp. sensor?
represent24 is offline   Reply With Quote
Old 08-26-2008, 02:32 PM   #68
Send a message via AIM to mist max2000
when i did my 2k maf i sprayed the hell out of everything.. even the screen lol
__________________
| 2002 6speed|Progress RSB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|HID fogs|eyelids|Hella Supertones|HD CatchCan|Berk Intake w/ Apexi filter|
Parts I own waiting to go on:| stillen classic kit|GenI cattman headers|Test Pipe|SAFCII
mist max2000 is offline   Reply With Quote
Old 08-26-2008, 07:01 PM   #69
wannabe max mechanic
adamgh81's Avatar
Send a message via AIM to adamgh81
jasonmax, any chance you can get those pics working again. I'm planning on doing this on my day off this week. Thanks, looks like a great write-up!
__________________
'03 RC51
'00 Maxima SE
'96 CBR600F3 (Sold)
'88-0151 F-16 (you paid for it, I work on it)
adamgh81 is offline   Reply With Quote
Old 08-26-2008, 08:17 PM   #70
Send a message via AIM to Kevin319
I have been getting 13-14 mpg on my 00 Max se auto, hopefully this will clear things up. Thanks alot!
Kevin319 is offline   Reply With Quote
Old 08-26-2008, 08:43 PM   #71
Quote:
aren't they working? they look working to me.
__________________
Old 08-27-2008, 01:49 AM   #72
I did this the other day, but I havent noticed any difference.
Does any one know if they do it at the dealership when you buy a certified used car?
PhalC1 is offline   Reply With Quote
Old 08-27-2008, 11:22 AM   #73
adamgh81's Avatar
Sorry man, it was probably my work blocking the pics.
__________________
'03 RC51
'00 Maxima SE
'96 CBR600F3 (Sold)
Old 08-27-2008, 10:03 PM   #74
nice write up!!!!
02_Maxima_6sd is offline   Reply With Quote
Old 08-28-2008, 04:40 PM   #75
I tried to disconnect the MAF today by pressing on the socket and pulling upwards. It wouldn't budge a bit. Did anyone else have a difficult time disconnecting it? Also, will my car start if I don't do the ecu reset?
Old 08-28-2008, 04:49 PM   #76
Quote:
you could wiggle while pulling, but that thing is weather proved, so it should be tight.
it will start.
__________________
Old 08-28-2008, 04:56 PM   #77
Thanks for your quick response, I was also a little hesistant of starting this clean up process because I did not know how do the ecu reset (kept failing) I will try again later.
Old 08-28-2008, 06:15 PM   #78
I hope you don't mind me posting a picture in your thread but this is what my thingy looks like ...
I can press the socket and push it down at the same time. I tried to pull it out in every way possible way but seems like its not going to let itself go. Any suggestion?
Old 08-28-2008, 09:38 PM   #79
Push a small flat head screw driver inside that space behind the tab, and push it towards the top of the picture and pull it up with your other hand. It's opposite of everything you would expect from a connector on this car.
__________________
Old 08-28-2008, 11:51 PM   #80
thanks for the write-up. I'm a firm believer in cleaning MAFs but I think i've been doing it wrong.. Last time i had the MAF out of the car, i just sprayed the little wire/resistor bit thinking that would do it.
If one runs the stock airbox/filter, what are the chances the MAF will even get dirty? My 2002 has been bogging for years now.. I would estimate its down a good 30-50hp, just haven't had time to investigate the issue since (until recently) it's been the wifes car. Now that it's my beater, I've got to de-woman-abuse the car one thing at a time.
__________________
2002 Maxima SE
GReddy Power Extreme, GAB, and a nice dent on my rear bumper.
theStig is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
