Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 05-07-2008, 05:09 PM   #1
Unsuccesful STL Coordinator
Send a message via AIM to Epacy Send a message via Yahoo to Epacy
Sunroof Leaking?
Alright, haven't been in here in ages, but has anyone experienced their sunroof leaking on the driver's side or just inside the driver's door on the headliner? Both those areas will get wet when the car is sitting in rain for awhile and will saturate the headliner and then drip onto the driver's seat.
I pulled the headliner off about a month ago and it seems there is a drainiage system around the bottom of the sunroof and the water exits through a plastic tube and runs down the pillar on the front of the driver's door. Perhaps that is leaking? I tried to tape it up once but I noticed today I still have some leaks.
__________________
Epacy is offline   Reply With Quote
Old 05-07-2008, 06:04 PM   #2
All Nissan Sunroofs are covered thru the life of the vehicle with or without warranty! Same as the seatbelts!
CMax03 is offline   Reply With Quote
Old 05-07-2008, 06:12 PM   #3
Quote:
Really?
I've never heard that.
__________________
Old 05-07-2008, 06:13 PM   #4
Quote:
Originally Posted by Epacy View Post
Really?
I know... that is surprising... is it only in the states?
vaudeville is offline   Reply With Quote
Old 05-07-2008, 06:23 PM   #5
Do you have access to a compressed air tank? There are drain holes in the four corners of the sunroof. The front left one is more than likely clogged. Find the hole on the drivers side and blow the compressed air in it. Should unclog it. FYI, I had this exact problem last summer. While you're at it, might as well blow some air in all of the holes to unclog them too.
AEMAXIMA01 is offline   Reply With Quote
Old 05-07-2008, 07:44 PM   #6
Quote:
You had the same problem as in a wet headliner near the front of the driver's side that leaked down onto your seat?
The compressed air fixed your problem?
__________________
Old 05-07-2008, 08:05 PM   #7
Yes, exact same problem. I actually took it to the dealer b/c I didn't know that was what the problem was. They head service tech told me about the drains, shot some compressed air through the holes, and voila!! He didn't charge me, but I can't guarantee anything for you. Good luck!
Old 05-07-2008, 08:39 PM   #8
Thanks for the info!
I will try that. Saw the drains earlier tonight. Realistically, you could block off that one drain that is giving you problems cause the water could drain out the other holes.
__________________
Old 05-08-2008, 06:25 PM   #9
Haha havent had any problems with leaks, just the one time i opened my sunroof right after taking it through the car wash (cause i was not thinking straight) and water gushed onto my leather...needless to say i was pretty upset
__________________
2000 Nissan Maxima GLE
Engine-VQ30DE-K
Audio-Kenwood 1000 watt Class D Amp (KAC-8104D), 2x12" Kenwood 4-Ohm Single Voice Coil Subs (KFC-W3011), Alpine Headunit (CDA-9884)
Exterior-Silverstar 4000K Headlights, 4DSC Decals
Performance-Bosch Fusion (Platinum/Iridium) Spark Plugs, K&N Filter,Set of Bridgestone Potenza Pole Postitions
maxdriver10 is offline   Reply With Quote
Old 05-09-2008, 02:26 AM   #10
I had a seatbelt retraction reel fail a few years back on my 86.5 Hardbody! that's when one of our many Nissan informed me that thier seatbelts and sunroofs are lifetime warranted, the only thing you pay for is labor cost!
Old 11-09-2008, 10:40 PM   #11
Send a message via AIM to PadawanKnight Send a message via Yahoo to PadawanKnight
I'm thinking that I have a sunroof draining issue as well...
Took the car to a car wash today (can't wash them at the apartment) and my son pointed out a leak coming out of the handle at the headliner. It was a pretty steady stream of water. After we got home, I took a look and could see a bit of a water stain around that area. Apparently, it hadn't been bad enough for me to notice before then.
Is it possible this leak is related to the sunroof? If not, where else should I look?
__________________
Independent research has determined that the leading cause of traffic jams is "people driving slow".
PadawanKnight is offline   Reply With Quote
Old 11-11-2008, 11:15 PM   #12
Sunroof air leak
The rubber edges of my sunroof have a definite sealing problem because I hear the wind when driving at highway speeds. Will Nisan's lifetime warranty of the sunroof cover replacing the seals or the entire sunroof?
RLStrick756 is offline   Reply With Quote
Old 11-12-2008, 05:38 AM   #13
Reizy's Avatar
You can probably adjust the sunroof by adding or removing shims. Search, its on here somewhere.
Can someone please post a reference to Nissan's sunroof warranty. I think that one may be a stretch. I tried google and came up with nothing.
Reizy is offline   Reply With Quote
Old 11-12-2008, 06:05 AM   #14
Quote:
Are you just worried about sealing for wind noise, or just air? I'm not familiar w/ the sunroof warranty, but you can buy shims from Nissan. http://www.shiftice.com/sunroof_wind_noise_fix.html
__________________
Old 11-12-2008, 08:22 AM   #15
Sunroof air leak
Thanks for the link to a possible fix to my problem. Just to clarify, there is a slight space 1-2mm between the sunroof and the roof. This is probably due to the rubber trim around the sunroof shrinking over time. I wonder if there are shims that will shift the sunroof to seat the rear slightly to make a tight seal? I should not use a hammer if a little finesse will work right?
Old 11-12-2008, 10:45 AM   #16
I'm not sure how thick the shims are, but I would definitely use them instead of a hammer. And as stated before, this is just to fix the air noise. The rubber trim does NOT keep water out of the sunroof. That's why it has the drain holes in the corners.
__________________
Old 11-12-2008, 06:56 PM   #17
My drivers side headliner is stained a little bit but it's never actually been wet as far as I can tell. I was getting a little worried, but now that I know it's covered that's a huge relief!
__________________
klemenz is offline   Reply With Quote
Old 11-17-2008, 10:10 PM   #18
...anyone?
__________________
Old 11-18-2008, 08:43 PM   #19
The sunroofs are designed to leak... into the drain lines. Depending on the angle of the car decides which hose to drain through. If one is clogged or ruptured, you will have serious problems.
To save hassle on going to the stealership, blow it out with compressed air gently without rupturing it then use a pressurized water nozzle to ensure it is draining properly.
I'm curious what is covered by warranty though. Someone post after taking their car in for it. I'll ask my Nissan service buddy.
__________________
2K Max Black
maxgen5 is offline   Reply With Quote
Old 11-24-2008, 10:43 AM   #20
I happened to open my sunroof and take a look at the channels.
And there was so much garbage and leaves in there. I cleaned it out and cleaned out the drains as well.
02nissmax is offline   Reply With Quote
Old 11-24-2008, 11:48 AM   #21
Send a message via AIM to Bjs470
yea i went to the wash the other day and high pressure water for sure came in through the sun roof...not happy
__________________
2001 GLE
It's slowly a work in progress...
Winter Setup
Stillen Intake--Flowmaster Muffler/Magnaflow Tips (Going bye-bye soon)--Front Strut Bar--Grounding Kit--Timing Advanced--6000K HID's--SE Tails--AE Key--Smoked Sidemarkers
Bjs470 is offline   Reply With Quote
Old 11-30-2008, 01:18 PM   #22
Hey new to this forum but known about it for years. Bought my baby a year ago and never had a problem with her till now! ('95 4th gen Nissan Max.) Just recently moved from Seattle to Philly and afraid the weather changes have cause some minor problems like dead battery, and small rock chip turning into a cracked windshield but today was the worst of it!!! My maxima was flooded *CRIES* not completely no seat damage or floor thank god but ther was watter pooled in the center console and change holders... There was water coming in through the interior headliner from the light fixture from around the dome lights and sunroof switches. Some water damage to the liner gunna dry it out before it gets messed up. But where to start i have no clue..... I'm afraid that it might be the sunroof but not 100% sure. i've come across a few post talkin about drains and possible clogs to the tubs. But i have a sneeky suspision that its not it.
Had it parked facing downward on a slightly hilled driveway my sunroof has a rainguard along the front of it, not sure if the water pooled up in it and caused the leak due to the angle (it had a large puddle in the rainguard). I have never really parked on hills facing downwards most if not all areas have been flat till recently. The seals around my Sunroof are in GREAT condition so i am at a totaly loss at what to do. I was told to test and see where the water is leaking in, also told it might be a shruckin gasket due to weather that will need to be replace at a local auto glass place or go to a dealership! UGH..... So i've removed the rainguard off and parked it in the same fashion it was sitting wanna see if water comes through but any ideas or suggestions might be nice just wondering if anyone has had this problem *sighs*
Just anotha Maxima LOVER!!!
~Alicia
MissMaximaExtreme is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
