Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-11-2008, 10:30 AM   #41
Quote:
Originally Posted by duderiffic View Post
CMax, I've been away on business and I haven't been able to deal with this recently. It is still horrendously noisy- even moreso after in my last bout I didn't replace the brake quiet spray (since it hadn't worked previously)
Where can I get these shims? Should they have come with my brakes? Do you know where I can find pictures? (I didn't seen them on the Hawk webpage) Do you agree that I shouldn't have groves on my disc, but rather a cross hatched pattern?
Thanks for your help CMax.
Were your rotors brand new and freshly turned? Are you using Hawk HPS's? Are the rotors aftermarket?
Those shims are nissan products and can be purchased from the dealer, Pep boys, Abc Nissan, Courtesy nissan; but it's called a hardware kit and it's less than $20 I believe. The Hawk pads have some smaller noise dampering shims bonded to the back of the pad backing plate, but they need the other pieces to work properly (quietly). Go to Courtesy parts online and they offer an exploded view of the front brake assy in thier IPC(illustrated Parts catalog).
Once you gather all your necessary parts, remove your pads and clean the backs with brake cleaner, Mek, mineral spirits or acetone. Then apply the brake quiet spray evenly (don't be shy) and I normally let it dry to a touch and install the Nissan shim, then I spray the backs of the shims and let dry and then high temp grease the edges of the pad backing plate and install! good luck!
CMax03 is offline   Reply With Quote
Old 05-14-2008, 08:57 AM   #42
Send a message via Yahoo to duderiffic
CMax,
Cool- I'll give that a shot- I had new (unturned) Brembo rotors I purchased at the same time as the Hawk's - I don't have a Courtesy auto parts- but maybe I'll just bend over and walk in backwards at the dealer. As I said before- I'm getting pretty desperate. :P
duderiffic is offline   Reply With Quote
Old 05-20-2008, 06:48 PM   #43
Send a message via AIM to wyche89
I was just thinking the same thing, as I had to use a shim from one of my stock pads on the back of my akebono pad because of a clearance issue, and I thought... why didn't I do that for my noisy @$$ hawk pads? Has anybody else seen success in using stock nissan brake shims in making hawk pads quieter?
p.s... i also had grooves in my rotors from hawk hps pads.. they were brand new brembo rotors
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Custom 3" Magnaflow Cat-back Exhaust
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
"I feel the need... the need for speed!"
wyche89 is offline   Reply With Quote
Old 05-20-2008, 09:25 PM   #44
hey cmax, is this the kit you're talking about?
http://www.courtesyparts.com/Merchan...Category_Code=
It just says "front brake hardware kit," and doesn't have any pictures.. maybe i'll give hawk a second chance with this shim kit... could i just use the shims from my old stock pads and see the same results?
__________________
2003 6 speed TE
Old 06-18-2008, 09:55 AM   #45
Here is an image of the front assembly I found- I'm guessing he is recommending to buy those two parts- 5 & 6. I suppose I'll go down to my Nissan dealer and see if they sell those. Courtesy doesn't have adequate pictures or descriptions.
Somehow I'm concerned that this will still squeal since I've tried a few other things.
On a really disappointing note- Hawk did not e-mail me back when I asked them about the problems- they could have at least given me a stock answer and told me to go away instead of saying nothing. Honestly that is no way to do business.
Old 06-30-2008, 08:41 PM   #46
So I bought all the stuff you suggested CMax- installed it the way you suggested as well- bought the full hardware kit (I guess that is how the shims are sold) which included new clips (top & bottom) for both corners. The I put on the 3 shims according to the instructions (two on the outside- one on the inside). I used squeal inhibiting paste as well as high-temp grease according to your description (and the pictures above in the service manual).
I'm really hoping this fixes me up.
I'll report soon.
Old 06-30-2008, 10:29 PM   #47
I'll report soon.
interested in hearing the results
__________________
2003 6 speed TE
Old 07-02-2008, 10:36 PM   #48
Day 2 and it is still quiet- this is a first- I'm really hoping this noise and hatred of my car are behind me now.
Old 07-05-2008, 03:36 PM   #49
Day 6 - heard my first squeal after some hard braking (two hard stops from ~40mph) - after taking a break it was quiet again.
Old 08-18-2008, 10:35 PM   #50
Back to normal- (horrendous squealing and embarrassing looks from random people)
Any other ideas? Others things I should grease? Should I turn the rotors?
Old 08-19-2008, 08:04 AM   #51
Send a message via AIM to MintVQ35
I just replaced all 4 corners with the Brembo blanks and Hawk HPS pads last weekend, I reused all stock Nissan pad shims and I have had zero noise/squeals from the start. I also used a generous amount of the red goo that came with the Hawk pads, been very satisfied with the results and how quiet they are.
__________________
Sterling Mist 2002 3.5SE 6MT -
|Clears|Debadged|AE Pedals|Resonator Delete|Magnaflow 3.5" DTM|Berk Intake|STS|ES Shifter Bushings|Generic FSTB|
MintVQ35 is offline   Reply With Quote
Old 08-20-2008, 12:35 AM   #52
Hey remove those pads and clean their backing plates and buy the spray on "Brake Quiet" or "Quiet Brake" and also spray some brake cleaner on the piston and caliper's fingers. Let dry to the touch and all your squealing is gone! By the way are you using the Oem brake shims? The only place you should be using hi-temp grease on is where the pads set on the adapter spring clips/pad retainers. Do not put grease on the back of the pads, spray the "brake quiet" spray on the back of the pads, install the shims and spray some more on top of that and let dry to touch and install the pads into the pad retainers on the torque member/adapter! don't be shy with the spray either. If you have a squeal/squeak something is loose and vibrating. The spray keeps everything cushioned /isolated...check your PM
Old 08-20-2008, 09:34 AM   #53
Quote:
Originally Posted by SoonerFan View Post
from Hawk's website
Bed-in Instructions
1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
5. After step 4 your new pads are ready for use.
Yep, i had hawk hps pads on my car for like 3 weeks and the braking was inconsistent to the max... til i did a couple of 100 to 0 hard braking off an empty highway exit ramps at like 2 in the morning.. Now braking is decent when cold, and extremely good when warm
__________________
2001 Nissan Maxima 20th Anniversary Edition w/ only 65k on it
Suspension-
Eibach Springs on Illuminas set to 4F/5R
I want a Stage 2 LTB, and a RSB
Audio-
JLAudio 12W7 in a 2.3cuF Ported to 29hz
JLAudio 500/1
Rainbow SLC 255 Comps
Alpine V12 MRV-F407
Optima Bluetop D35 (I really need to do a Grounding Kit..)
FlipCpt45 is offline   Reply With Quote
Old 08-31-2008, 09:39 PM   #54
CMax,
Thanks for all your help- sincerely appreciate your offer to help directly- what you're describing sounds exactly like what I did last time.
I-
1) Replaced the clips and put high-temp grease on the side that faces the pads as well as side the mounts to the torque member
2) Cleaned the back of the pads with Pyroil brake cleaner
3) Cleaned the piston with Pyroil brake cleaner
4) Applied Permatex Disc Brake Quiet to the inbound and outbound brake pads, waiting until dry, then placing the newly purchased OE shims on the pads and applying the Brake Quiet on the outside of the shims.
5) Applied high temperature grease to the top and bottom of the pads (inbound and outbound) that slide on the clips.
Do you see anything that I missed there that would still be causing me to have problems- it looks like the only thing I didn't spray clean is the caliper fingers- should I clean and Brake Quiet those fingers too?
This last install I was silent for almost 2 weeks which was the best. The new thing from the last time I've done this (I've tried doing this five times) was the addition of the OE hardware kit which included the new clips and 3 shim plates per side- 2 for the outbound pad and 1 for the inbound pad.
Old 12-03-2008, 11:44 AM   #55
Send a message via AIM to StillenMax80x20
I was about to purchase this EXACT combo. having some doubts now. I despise ANY brake noise.
How is the noise now? Still Present
__________________
DOWN_shift
StillenMax80x20 is offline   Reply With Quote
Old 04-01-2009, 08:53 PM   #56
I've still got noise- just today I switched to some cheapass Pep Boys $16 pads to see if I had the same noise/problems and I did- so maybe there are other problems.
I'm thinking I need to go find a cliff to roll my Maxima down.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
