Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-19-2008, 08:38 AM   #41
Bought my 02 SE Feb 07 with 79K on it. A year and 30K later and the only problems are related to the transmission - and this is just starting. I've yet to investigate this issue further. It maybe a cheap sensor, or it maybe an expensive assembly.
Gas mileage mixed for me is 24 - 27.5mpg and I get on it often.
UKmaxima is offline   Reply With Quote
Old 03-19-2008, 09:02 AM   #42
Quote:
Originally Posted by Scottwax View Post
Oil consumption seems to be the biggest issue, the poll here shows that about 10% of the people with a 5.5 gen have problems with excessive oil consumption. Wheel bearings are also an issue, IMO because if the bearings are repacked or the rotor is removed to be turned or replaced, people cheap out and reuse the locknut or don't tighten it to factory specs (250 ftlbs).
Only issues I have had with mine since I got it about 4 months ago was the wheel bearing problem that appears to be a reassmbly issue (so it really can't be considered a design fault) and a bad thermostat, which was $22 to replace.
Huh?
I could have sworn the center lock nut did not have to be removed to replace the rotors on out cars.............
Maybe I'm just wrong.
Whitebread is offline   Reply With Quote
Old 03-19-2008, 03:23 PM   #43
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Quote:
Originally Posted by Whitebread View Post
Huh?
The lock nuts had obviously been removed at some point and the brakes on my car were nearly brand new when I got it. Just put two and two together...
Scottwax is offline   Reply With Quote
Old 03-19-2008, 03:47 PM   #44
If you have a Maixma, of any year, and you don't put a fluid cooler on the transmission you are asking for it. Thats the first thing I would do after I picked it up.
__________________
Did I mention the car is fast as hell?
maxima-junky is offline   Reply With Quote
Old 03-19-2008, 04:09 PM   #45
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
Quote:
and why do you say that? i'd love to know. as i have had many with 0 tranny problems and no external oil coolers...
sorry to hijack.
give your car a good tune up if it hasn't had one in a while: plugs, fuel filter, pcv valve, air filter, check what is rattling it's probably a heat shield, i don't know if 5th gens throw a code for a bad knock sensor 4th's don't so check that with a dmm, other then that they don't need much in terms of routine maintenance.
in all honesty they don't get amazing gas mileage.
good luck
Torgus is offline   Reply With Quote
Old 03-19-2008, 07:15 PM   #46
O, because I was gonna say
Old 03-19-2008, 07:44 PM   #47
Send a message via AIM to 00MaximaGXE
I dont know about you guys but I get about 420 to a tank highway and about 315 on city roads. I drive it hard too
I too have a dash rattle not rattling all the time just when cold and going over bumps sounds metallic metal against metal real quick. Doesnt bother me..I also have NOISY tires.. sounds like an airplane taking off
P1320 SES CODE and the wonderful P0430 are the only ones Ive had to worry about still havent found the p1320 Bad coil yet, Just keep clearing it until Spring gets here when I can work outside and not freeze to death
00MaximaGXE is offline   Reply With Quote
Old 03-19-2008, 09:15 PM   #48
Send a message via AIM to MADE
Quote:
WTF am I doing wrong, any one else getting anything close? Problems I occured thus far
$ Bad O2 Sensor(blue one can't think of the more descriptive name)
$ Passenger wheel bearing and hub assy
*Radiator (road hazard It had nothing to do with Nissan quality)
Bose 6 Disc (POS honestly the main reason I don't drive much) Annoying
Some random bogging problem which went away after Nissan raped me for a diagonistic and told me I had a bad coil and they couldn't troubleshoot or test coils and recommed all 6 be replaced total cost 700 dollars. I told them they are full of **** and drove the car until the problem arose again 2 years later still hasn't come back.Thank god I'm not a woman or ignorant.
$= Removed and Replaced
All in all I'm happy with my Maxima and will only trade it for a G3?,M?5 or something German.
MADE is offline   Reply With Quote
Old 03-22-2008, 09:30 PM   #49
Looking at an 01' Maxima tomorrow, couple problems..
Well, only one problem that I know of. The AC/heat doesn't work indicating a blower motor from what I could tell from talking to the owner. Is this an expensive problem and how hard is it to fix myself? I typically do all work myself.
Car has 160,000 miles, auto and leather. What are problems I need to be aware of or are there specific areas to check out? I had a 96' I30 a few years ago and it was bulletproof. I'm assuming these 5th gen Maxima's are fairly solid as well?
Thank you for your advice.
USRacer900 is offline   Reply With Quote
Old 03-22-2008, 09:32 PM   #50
Go BUCKS!!!
SEmy2K2go's Avatar
The blower motors are common problems. You can rebuild the one in the car, or look for a replacement at a junkyard.
__________________
Maxima Cardomain
SEmy2K2go is offline   Reply With Quote
Old 03-23-2008, 10:06 AM   #51
nsnrider's Avatar
Send a message via Yahoo to nsnrider
blower motor resistor maybee the culprit? Anyways, these are good cars, as long as the previous owner was on top of the maintanace, you should be fine, look at the shocks, maf, coil packs, o2 sensors, make sure all have been replaced by now, personally I wouldn't buy a car with 160k miles but thats just me. I hope you're getting it for a good price...
__________________
Sold my 2k3 Max.
nsnrider is offline   Reply With Quote
Old 03-23-2008, 10:43 AM   #52
Quote:
Thanks for the info. Believe it or not, apparently he's selling it for $1500. Supposed to look at it today.
Old 03-23-2008, 02:26 PM   #53
Correction, just found out it's a 2000 model. Would that change the blower situation?
(have yet to look at the car so I don't know what condition it's in)
Old 04-01-2008, 09:41 AM   #54
Send a message via AIM to pavelsmax
Looking at 2003 Se Te 6spd Today
Hey guys,
I'm going to look at the car mentioned in the title. It is a one owner vehicle black w/ black leather, heated. The car has 50,000 miles on it and the seller is asking $13,999. Is that a reasonable price. I've seen its under Kbb value for the car.
I don't know much about 5th gens but have driven my 4th gen since 2002. Is there any thing I should look for specific on the car? To my knowledge it has never been modified.
Thanks for your help and if I'm lucky I'll be posting much more often in this part of the forum!
__________________
Heated black leather | I30 headrests | I30 auto dimming mirror | I30 door handles | LED interior | OEM fogs | OEM wood trim | Custom Sirius | SE wheels | 99 Headlights | Clear corners | Red Rear Turn signals | Optima Battery | Roof Rack | OEM FTW!
pavelsmax is offline   Reply With Quote
Old 04-01-2008, 10:06 AM   #55
MacGarnicle's Avatar
Send a message via MSN to MacGarnicle
indeed, read the stickies because there ARE a few things you should be looking out for.
At the end of the day, this forum could tell you the car isn't worth more than $10,000, but how does that help with your negotiations? The dealer doesn't care. You should always try to get the car for less than it's posted but whether we say its worth $11,000 or $12,000 won't really impact on how things play out
__________________
MacGarnicle is offline   Reply With Quote
Old 04-01-2008, 10:15 AM   #56
nsnrider's Avatar
before you begin negotiating for a price, make sure it doesn't have major problems, have your mechanic put it on the lift and go through it thoroughly. Price is always negotiable.
__________________
Sold my 2k3 Max.
Old 04-01-2008, 02:17 PM   #57
Send a message via AIM to wyche89
if it is indeed in good condition, 14,000 is a good price for the car... mine was stickered at 15 with 49k on it
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Custom 3" Magnaflow Cat-back Exhaust
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
"I feel the need... the need for speed!"
wyche89 is offline   Reply With Quote
Old 04-01-2008, 06:29 PM   #58
the kelly blue book values is always overpriced, because it is what dealers use to determine what to charge, thus resulting in inflated prices...a better site is www.edmunds.com, they're values are more reasonable...on kelly my 2000 GLE fully loaded in fair condition with 83,000+ miles was listed in the high nines, while edmunds said it was closer to $8500...got the car, completely registered with new brakes for $8800....however that is a very good price for a 2003 titanium edition with that mileage...i would try to lower the price, but if they are unwilling to budge, i would shell out the extra coin and get it anyway
__________________
'00 Nissan Maxima GLE
Engine-VQ30DE-K
Audio-Subwoofers: 2x 12" Kenwood 4-Ohm Single Voice Coil Subs (KFC-W3011) Amp: Kenwood 1000 watt Class D Amp (KAC-8104D) Headunit: Alpine Headunit (CDA-9884), Front: Stock Bose Speakers Rear: 2x 6 1/2" Kenwood Excelon 4-Ohm Speakers
Exterior-Silverstar 4100K UltraVision Headlights, Bosch Icon Wiper Blades, Chrome Exhaust Tips
Performance-Bosch Fusion (Platinum/Iridium) Spark Plugs, K&N Filter, Bridgestone Potenza GO19 Grids
maxdriver10 is offline   Reply With Quote
Old 04-01-2008, 08:07 PM   #59
Mauja He Mauja
ZIPPIN's Avatar
If it doesn't burn oil, bose works, no accidents, no grinding of gears, I say 12.5 would be a good offer for her. How are tires/brakes etc?
ZIPPIN is offline   Reply With Quote
Old 04-01-2008, 08:24 PM   #60
Send a message via AIM to Griller07
Quote:
Pretty much what ^^^ said. Don't wait too long though, make a decision cuz theres always gona be someone else wanting it
__________________
***~Written By Kasozi~***
- Remember the Name -
While your maxing out in 5th, Just Keep in mind that i have that extra gear in that 02 max!!! VQ Power all day
Griller07 is offline   Reply With Quote
Old 04-02-2008, 12:11 AM   #61
Scottwax's Avatar
Quote:
One of the Dallas area members picked up a grey lustre '03 Anniversary edition (automatic) with just over 40k miles for $8900!
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Old 04-02-2008, 06:35 AM   #62
sparks03max's Avatar
yeah those 02/03 black/black TE 6spd's sell very quickly, too bad you didn't get it.
__________________
2003 SE 6MT Titanium Edition - Sterling Mist
Power mods: SRI, VIAS Delete, NWP spacers, Cattman Headers, Custom exhaust, TurboXS UTEC + Tuner
12-second 5.5 gen track vid: http://www.youtube.com/watch?v=HDz_fIHZgig
sparks03max is offline   Reply With Quote
Old 04-03-2008, 02:54 PM   #63
What can I get ya?
Cutler's Avatar
2001 was the Anniversary edition...
Cutler is offline   Reply With Quote
Old 04-03-2008, 06:42 PM   #64
Quote:
maybe he meant TE.. that's basically the "anniversary edition" of the 5.5 gens minus the body kit
__________________
2003 6 speed TE
Old 04-03-2008, 06:45 PM   #65
I'll sell you my 02 6 spd for $ 9000
__________________
no maxima at the moment, i want my 02 6-spd back.
pl_silverado is offline   Reply With Quote
Old 04-03-2008, 07:17 PM   #66
Mauja He Mauja
ZIPPIN's Avatar
Depending on who you ask, TE are hard to buy. Not too hard to find. But you fuq around and low ball, someone will beat you to it. Happened to me at least 3 times, bfr I bought mine.
__________________
Old 04-03-2008, 10:27 PM   #67
Scottwax's Avatar
Quote:
Originally Posted by MacGarnicle View Post
03 anniversary edition eh?
Brain fart. Titanium edition.
Old 04-04-2008, 03:07 PM   #68
boondoxmax's Avatar
I was lucky to find my 03 6 speed TE. Didn't even know it was one until I got to the Nissan dealer. The description online was so vague.....But I knew the car wouldn't last long so I brought it right on the spot.....
boondoxmax is offline   Reply With Quote
Old 04-12-2008, 04:06 PM   #69
Send a message via Yahoo to n1_saxman
Do I really want a 5.5 gen max??
Hey guys~
I spent the last few weeks studying the 4th, 5th and 5.5th generation maxima, trying to figure out which would be the best for me. I settled on the 5.5 for the sweet VQ35 motor and set up a test drive. Today, I went to drive a 2k3 SE with 110k miles on it that was for sale. I know that is a bit high, but I with all the praise that the motor gets, I should be fine for another 100k, right? The engine was veeeerrry nice and so was the ride down the road, BUT there was a check engine light that came on a day before I drove it. The owner had taken the car to a shop and they read the code as a malfunctioning lifter. The owner said it would be about a $1000 job to get it fixed. You've got to be kidding me!!! Are there many problems with the motor? Is this a serious problem?
Help me keep interest in the VQ35!
n1_saxman is offline   Reply With Quote
Old 04-12-2008, 04:07 PM   #70
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
@ malfunctioning lifter. Get the code, post it here, and we'll take it from there.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 04-12-2008, 04:40 PM   #71
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Like he said... get the codes pulled and post it here for proper feedback on the issue.
Puppetmaster is offline   Reply With Quote
Old 04-12-2008, 05:55 PM   #72
how do the 3.0 and 3.5 compare with respect to reliability?
PS- I don't really want that guy's car becuase it had scratches all over it and he admitted to being a leadfoot. I'm sure he didn't take very good care of it.
Old 04-12-2008, 06:14 PM   #73
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
Quote:
all the info is available on here....
SoonerFan is offline   Reply With Quote
Old 04-12-2008, 07:00 PM   #74
Super Moderator
Thinking of buying a 5th or 5.5 Gen? Please step in....
This is a thread for all those interested in buying a 5th or 5.5 Gen and are trying to do some research, so please lok through this thread and/or post all questions you have in here.
I've merged a handful of the most recent discussions on this to kick start this and hope that ALL questions regarding potential purchases can be kept to this thread. If you have some information you'd like to share with potential buyers, please feel free as well.
Consequently, all other new threads on buying 5th/5.5 Gens will be locked or merged into this one.
Old 04-12-2008, 07:55 PM   #75
Mauja He Mauja
ZIPPIN's Avatar
Why don't you take it to AUTOZONE, get the codes pulled and figure out the issue? You may be able to fix it yourself, and offer lower than he's asking..I have yet to read about lifter issues with this motor. Not saying that others may not have had similar issues.
__________________
Old 04-13-2008, 08:30 AM   #76
Deciding between 02 or 03..
Since ive been outta the maxima world for few years now, ive lacked on all info. Im looking to get me another maxima as soon as im able, and ive narrowed it down to wanting only a 02 or 03... Now from what im reading I am understanding that there are a few differences? If you guys wouldn't mind bringing me up to date as to what these differences are so that i can either narrow it to an 03 only or still possibly both... Thanks in advanced guy, I'm looking forward to getting back into a max.
P.S. I just noticed there is a somewhat of a thread about 5gen/5.5 gen that might have my answer... Ill read through it, but if anyone still knows specifics I would appreciate it.
__________________
I Miss Her
MoMax00 is offline   Reply With Quote
Old 04-13-2008, 09:45 AM   #77
I believe the only real difference is that the 03 was available with curtain airbags. that a a few color changes. But i believe that is the extent of it.
6SPD02SE is offline   Reply With Quote
Old 04-13-2008, 10:04 AM   #78
Quote:
Not really worried much about cosmetics or interior things like that... I'm interested in knowing differences in engine or tranny.
__________________
I Miss Her
Old 04-13-2008, 10:10 AM   #79
Send a message via AIM to bossman427111
4th gen or 5th gen
i have a 4th gen and totaled it and it seems to b fast but im looking at a 5th gen an 01 . just want an easy answer. witch one better for preformance? and why. thanks
bossman427111 is offline   Reply With Quote
Old 04-13-2008, 10:11 AM   #80
tru story
SoonerFan's Avatar
do you need the Titanium Edition?
if not, they are are exactly the same
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
