Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 04-05-2008, 11:54 PM   #1
unrealii's Avatar
Send a message via AIM to unrealii
01gle auto transmission problem - caused by bad tcm??
Hi all, here's my novel with the atx in my 2001 gle. Build date is oct 2000. IIRC, the dealer's computer says Oct 26, 2000 build date. I missed the date to be included in NTB00-039a TSB Flushed the fluid at ever 25k miles. Currently at 104100 miles.
35.5k - bought this car from my dad. Transmission shifted smoothly. It was precise. I let off the gas, it would immediately upshift in a nice and crisp way. Felt there was a direct connection with my brain, foot, gas pedal, transmission - it was pure sex.
45k - Shifts became a little sloppy - seemed almost to happen over night. There would always be a slight bump with most shifts...wasnt as precise as it was 10k miles ago. Also my car would cruise at ~2300 rpm while at 60 instead of 2100 when it was cold. Eventually it would drop down to 2100 where it should be. I wasnt able to convince the dealer anything was wrong.
59k - purchased nissan security plus warranty thinking if its going bad, it will fail within the next 3/36k - covering me through 95k miles
95k - warranty expires. Transmission is still crappy like it was at 45k...barely got any worse so I assumed thats the way it would stay.
101k - fluid flush from the dealership
103k - transmission has trouble catching 1-2 and 2-3 when on cold start and driving in neighborhood. The car repeatedly tries to catch the gears and keeps trying until it does while shaking the car - gears are not slammed. However, once the car is warmed up, if I push it hard it will slip on at least the 2-3 and slams once the rpm goes 500-1000 higher.
104k - Had an independent shop look at the car. They said all electronics are fine. Fluid is smells burnt even though color is good. Said there is mechanical issues and transmission needs to be rebuilt. They gave me a price of 2250 where they would take the trans out and sent it over to a partner shop near by. Replace all what needs replacing, then send it back. 2 year, 24k mile warranty. This shop is AAA approved ..not sure if that meant anything. Not sure how I feel about this shop since 1) They forgot to slide the rubber piece between the spring and the strut when installing my eibachs...made them redo it since I didnt want the noise of the strut hitting the spring.
2) The guy working on my car this time backed it up into a sign while parking it. No damage, but kinda stupid to do since he works at that place and should know not to back the car that far back.
Rough estimate from the dealership without looking into the computer was 3500 for a rebuild. I did not take it in yet as I do not want a record of this problem in their computer. They will get a rebuilt unit from nissan. Not sure if that is the better way. I'm pretty sure I can get it done cheaper by that dealership.
Driving habits: I push my car hard, but do not abuse it. I always let it warm up before pushing it hard. It rarely sees redline. Often gets 4.5k-5k when merging onto these california freeways. I have flushed the fluid by the dealership at 25k intervals. This car gets pushed much harder on turns and braking as that is where all of my mods are. Drivetrain is 100% stock.
I'm concerned about two things:
1) Who should I go to for the rebuild. Should I get a transgo shift kit installed too? Anyone have any experiences with the dealership installing one on a nissan rebuilt transmission.
2) Are the days of the precise shifting which my car did at 35.5k gone? If I'm dumping money for this repair, I would like it to be exactly like new. I am wondering what caused the sudden change...Is it a possibility for a bad tcm? I am not sure which part number I have in my car. I can pull my radio out and check. Can the TCM be reprogrammed. My dealer checks my ecu to make sure I have the latest software anytime I go there for any major service.
__________________
Shift_Enjoy the Ride
August 2004 free prize giveaway winner...I <3 .org
unrealii is offline   Reply With Quote
Old 04-05-2008, 11:58 PM   #2
3-Peat!!!!!
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
sounds like a bad TCM...but by now, it probably wore the tranny out and it may need a rebuild.
first, call daveb and get a new TCM (around $490) and go from there
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 04-06-2008, 12:05 AM   #3
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
If the TCM doesn't do it, then look for a low mileage used transmission first.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 04-06-2008, 12:08 AM   #4
3-Peat!!!!!
SoonerFan's Avatar
btw, my info is from experience with my old 00 GLE
tranny went out soon after i bought it and it was changed under warranty...i was still new to maximas so knew nothing about the TCM...about 1 year later i got the same symptoms on the new tranny which made me realize the TCM caused the other one to go out. replaced it and never had a problem.
Old 04-06-2008, 09:53 PM   #5
unrealii's Avatar
Just curious...what do you guys attribute the tcm to?
1) Transmission failing at 104k
2) Transmission becoming sloppy at 45k
3) Both of the above.
__________________
Old 04-06-2008, 10:34 PM   #6
3-Peat!!!!!
SoonerFan's Avatar
the problem upshifting
Old 04-11-2008, 01:09 PM   #7
unrealii's Avatar
Driving the car this week was a pain. I babied it to the bone. When starting the car, drove around in "2", then bumped to "D" once it was warmed up. Kept it out of "od" until on the freeways. Avoided all type of shifts as much as possible. I'm sure my gas mileage took a hit.
Installed the new TCM today. Took about an hour. Having an aftermarket stereo just makes things worse as there are more wires in that area to work with. I came across a black box which said shift (computer or unit..dont remember) which I thought was the tcm until I held it next to the new TCM and realized the plugs were different. TCM was underneath that shift computer. Model number of the old TCM: 31036-4Y901 - which is the unit referenced in the TSB. New replacement unit is 31036-4Y960. Good thing is that I double checked all my wires and found 3 crimps on my steering wheel audio controls to the swi-x which were loose, so I recrimped them. That explains why my steering wheel controls would randomly not work.
Went for a drive. Car was already warmed up, so did not have a chance to test the 1-2 mis-catch/shift. I was able to get it to slip on a 2-3, but the tcm/ecu knew what to do and didnt slam the gear. Upshifts are still a little sloppy, not sure if it is better than before or not. Not concluding anything at the moment until all monitors in the ECU are ready.
My trans fluid looks ok...but smells a burnt. Should I have it flushed or just leave it? I was thinking of flushing it after I do the TCM A-B test.
__________________
Old 04-11-2008, 01:55 PM   #8
One question ive always wondered, and maybe some one can enlighten me. BUT, how do you determine if the transmission fluid smells burnt.....
__________________
Tokico Illumina's 4F/5R | H&R Springs | ebay FSTB | Progress RSB (need 2 install) | ES Bushings | Goodridge SS Lines | Berk Air Intake | Cleared 2K2 Headlights | 8k D2R and 50W H3 Fogs upgrade | Cleared Sidemarkers | White LED's all around (Interior & Exterior) | Chrome Gauge Rings | 15% Tint (all around) | RTP Zinc plated Slotted Rotors | Hawk HPS pads | RPM R-505 19x8.5 wrapped in General Exclaim UHP 245-35-R19 | Optima Yellow Top | Hella Supertones | (2) 12" Alpine Type R's
hi-tek22 is online now   Reply With Quote
Old 04-11-2008, 03:29 PM   #9
unrealii's Avatar
Quote:
I have the same problem. I am going from what the mechanic is saying. I have a bottle of new atf. I'll take a whiff of that, then what's in my car and I'll know.
__________________
Old 04-11-2008, 03:45 PM   #10
3-Peat!!!!!
SoonerFan's Avatar
fresh ATF is pink
old is brown and smells different
the pink appearance is a dye that is made to go away as its used. when its brown, its time to change it
http://www.aa1car.com/library/atf.htm
__________________
06 Mazda 6
Old 04-11-2008, 06:37 PM   #11
nsnrider's Avatar
Send a message via Yahoo to nsnrider
I would assume you have to smell it?
__________________
Theses are my cars.
nsnrider is offline   Reply With Quote
Old 04-11-2008, 07:07 PM   #12
Send a message via AIM to dineth00i30
please dont think im thread jacking but my question is you said that you made sure that you always have the latest software. so does that mean our cars ecu need to updated like a computer and that the dealer just do it for free or you have to pay for it?(i did search but nothing helpfull really didnt come up, maybe i searched with the wrong words.) you symptoms kinda sounds like the symptoms of my car i hope they go away after my tranny fluid change.
a question of the op: were shifts not smooth under 2ooo rpm?(my car the shifts are hard under 2k and and smoother in higher revs)
__________________
If gas prices get any higher, rappers will start drinking it!
Tints: 35% Front/2 Layers of 20%Rear, ActiveTuning Blue Grounding Kit , 3000k Custom Yellow H.I.D Kit For Fogs, 8000k H.I.D Kit For Headlights, Licence Plate L.E.D's, Hyper White L.E.D's for City Lights, Half Roof Spoiler , Clear Corners With L.E.D's,Black Roof Vinyl, Debadged, 12" MTX JackHammer Sub, 400w 4-Channel AMP
"my motto is, just the tip, just for a second to see how it feels" quoted by Feldman
dineth00i30 is online now   Reply With Quote
Old 04-12-2008, 10:31 PM   #13
unrealii's Avatar
Quote:
Looks like its not the TCM. 1-2 has some trouble catching when cold. 2-3 & 3-4 can slip if I push the car. Looks like its a new trans for me.
Also, forgot to mention, the car jerks at approx ~37 mph while decelerating (braking). This also started happening around 45k and magically went away some time after. I seem to be noticing it again now.
My shifts were not smooth all over. Sometimes the trans shifts smoothly, sometimes not.
Nissan does not make ECU updates that often at all. My dealership just does it as a courtesy to me since I had brought my car to them for a lot of warranty work, & major maintenance items like brakes, trans flushes, etc.
__________________
Old 04-13-2008, 10:42 AM   #14
Send a message via AIM to njmaxseltd
Wasn't there an issue with valve body's on early 5th gen transmissions?
My parents had a 2000 Max that had sloppy shifts. It went in for a recall and if my memory serves me correctly a new valve body was installed in the trans. The car shifted perfectly ever since.
__________________
njmaxseltd is offline   Reply With Quote
Old 04-13-2008, 01:22 PM   #15
unrealii's Avatar
Yeah, there's a tsb for new solenoids which go into the valve body as well as a new tcm. My car doesn't fall under that tsb.
Decided I am not going to flush the fluid. No point dumping money on this trans. Still trying to decide if I want to go with a junk yard trans or a nissan rebuilt. Car drives fine and as long as I feel it wont strand me anywhere, I'm going to keep driving it.
__________________
Old 04-13-2008, 09:22 PM   #16
RR5
Send a message via AIM to RR5
This sounds like exactly what is happening in my 2002 SE.
Cold start, from Reverse into Drive, the car just crawls so slow. When accelerating off, the transmission becomes sluggish. It does not want to smoothly shift from 1 into 2, and has problems with 2 to 3.
Then when everything warms up, the problems are gone.
I am kind of lost as to what I can buy/replace to fix this before I tank another auto trans.
RR5 is offline   Reply With Quote
Old 04-22-2008, 04:54 PM   #17
unrealii's Avatar
RR5, sorry I cant help you. Not too good at these things.
Anways here's a car update.
-rough idle when waiting at signals for more than 10 secs or so. (as of this weekend)
-car has stalled a few times when I put it in park (as of this weekend)
-Sometimes still has trouble on the 1-2 while cold
-2-3 slips when driving the car hard
-slight jerk when decelerating 40-35mph
-shifts are still jerky
-replaced tcm, no change
-Fluid smells burnt, but color is ok. I found a very small metal chip in the fluid on the stick when I checked it.
Got a quote from the dealership:
$1000 labor
$1950 reman nissan trans
It was originally 3371, I haggled with them on the part since it was marked up quite a bit so I was able to get it down to $2950. Does that seem like a reasonable price. I dont have time to deal with any other shops if they dont do it right. I think the labor seems a bit on the high end What do you guys think? Quoted a full day's worth of work to r&r the trans.
Probably going to do a throttle body cleaning and fuel injector cleaning to take care of idle. It has been a while since I have done this.
__________________
Old 04-22-2008, 05:14 PM   #18
Scottwax's Avatar
$1000 is insane to install a transmission. Shouldn't be more than $400 or so. Good price for a reman though.
Old 04-22-2008, 05:33 PM   #19
unrealii's Avatar
Thanks Scott. Much appreciated for your feedback.
Anyone know how many hours the nissan book says for transmission r&r?
__________________
Old 04-22-2008, 07:57 PM   #20
unrealii's Avatar
Another dealer said 10 hours after talking to the master tech. Other one had given me an informal number of 9. Since the rate is around $100 per hour, I guess thats ok?
5 hours does see like a long time to either remove or install a transmission. I've had too many other mechanics and dealers mess simple things up. This dealer so far has an exceptional track record with my car at the moment. I'm thinking I may just go with them unless some says (with backing of a related tsb or flat rate manual) the entire job should take less than 5 hours tops.
Thanks for all of your help!!
__________________
Old 04-22-2008, 10:36 PM   #21
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
i'll do it for $800
__________________
--Jon--
Currently driving:
03 Maxima: 40k miles, Bodykit, CF hood, 20'' Chrome DUBz, Alarm, Tint, Eclipse AVN6500, Rainbow Profi Vandiums, Boston Pro60s, 2 12'' Type Rs, Suspension, Cleared 8k HIDs w/ DDE Angel Eyes, Intake, Exhaust, Timing Adv, Custom 2 Tone Interior, x drilled/slotted/zinc rotors, SS brake lines, etc.
92 Max SE: 5 speed LSD 230k Daily Driver FTW 4DSC!!!!
Retired:
97 Max modded: BURNED IN FLAMES
96 Max modded: Sold to brother
95 Max modded: Attacked By Volvo
Quote:
Originally Posted by KRRZ350 View Post
yes, she said she had plans with friends but I knew she really just didn't want to take it up the butt anymore.
Torgus is offline   Reply With Quote
Old 08-13-2008, 01:04 PM   #22
unrealii's Avatar
Forgot to give an update.
Took it to the dealer back in april, they looked at the car and said trans is ok. I'm not seeing any shavings in the fluid and fluid looks ok now. I'm guessing next time I flush the fluid these problems will occur again.
Dealer replaced maf for the rough idle issues. Car also feels better on the top end and I gained 1-2mpg back.
Shifts are still a little sloppy, but car hasn't slipped. On cold start, sometimes 1-2 takes a little long to engage, but not as bad as it was a few months back.
One thing which concerns me is while decelerating, at exactly the the 37.5mph mark, I usually get a jerk from the car. Is that the tc unlocking or what? This has been happening for the last 50k or so miles.
__________________
Old 08-13-2008, 01:27 PM   #23
Send a message via AIM to sublime258
So you're saying that you think these problems were caused by flushing your transmission fluid??
__________________
'02 GLE Mod List: Bridgestone Blizzak WS-60 Tires on GLE Wheels (Winter) | Toyo Proxes 4 Tires on Silver TSW Vortex 18x8 Wheels (Warm Weather) | H&R 15mm Spacers | Brembo Blank Rotors - Painted Black | Hawk HPS Pads | G2 Black Painted Calipers | Stillen Classic Front Lip, Side Skirts & Rear Valance | GReddy EVO2 Exhaust | Injen CAI | Tokico Illuminas | H&R Springs | Progress RSB | Stillen FSTB & Battery Tie-down | Grounding Kit | 35% Tint | Fujita Oil Cap | Blacked Out Clear Side Markers w/ Amber & Red 5-LED Bulbs | PIAA Xtreme Whites in Fogs, Dome, Doors & License Plate | AE Door Sills | AE Pedals | Momo Raptor Black Leather Shift Knob | Maglite Mount | Alpine CDA9883 HU w/ Steering Wheel Control Adapter | Pioneer 800W Amp | 2 JL 10W3V3 Subs | Damplifier on Rear Deck | Dynamat Xtreme Trunk Kit
sublime258 is offline   Reply With Quote
