Violent shaking on the highway
I've experienced this recently and my wife also stated she felt it to (though I doubted it at the time since she was a piece of road that is usually rough). Basically once I hit 100km's (60mph) on the highway yesterday the car was shaking so much I had to get off. It seemed like it was all front end and I can see the hood going crazy as well. I'm taking the car in this weekend, but can anyone give a pre-determined idea on the issue? I'm guessing engine mounts. But this does not happen all the time as this morning was fine.
I think I will have other suspension work to do as this winter has been horrible on lowered cars.
It is possible as I know I'm in need of an alignment but I am waiting until I replace ball joints etc.
Its is pretty extreme however. More then I've ever witnessed and having the VB mod with the hard first gear I can see an engine mount failure. Generally speaking from what I know with a bad alignment the car is still driveable. Just wondering if anyone has had this exterme shaking before.
The cause of the shaking could be a number of things:
- Bad tire(s) (separated tread or another problem)
- Improper tire inflation
- Improper tire balance (caused by missing weights or snow in the wheel)
- Misalignment
- Bad tie rod(s)
- Bad steering rack
- Bad wheel(s)
I Say you threw a weight on one or both of your front tires. You can try rotating the front tires to the back and see if it goes away. that of course assumes the rear tires didnt throw any weights. Easy way to tell My guess by the looks of the nice rims is they used stick on wieghts so look for a spot on the inside of the rim where weights have been glued on if you see a spot that looks like there was something there before DING DING DING you found your problem. Stick on weights are know for coming off.
Good luck
Good luck
Good luck
Good luck
My car was doing this (just last week) and it was my front tires. One of them was actually close to "blowing". There was actually an indentation in the tire. The uneven wear came from bad struts (Tokico) that need replacing.
The other cause could be a CV joint, but you'd tend to have a lot of noise with that one as well.
Like the others, I bet it is your alignment and one or both tires are shot (in front) because of it. Who knows though, maybe it is something as simple as getting the tires balanced (like someone mentioned)
you guys are stretching. Violent vibration only at those higher speeds is clearly indicative of really one of three things:
1. tire is out of balance
2. tire or wheel is out of round
3. lug nuts are loose.
The vibration described seems VERY unlikely to be CV-joing, balljoint, tie rod, tire inflation, alignment, or anything other than what I mentioned above.
There is a really easy way to rule out all three of those things: put your other set of wheels on!!! If it stops, you know it is wheel/tire-related. If not, you know it's something else.
I had the same problem with the shaking... only i had it at all speeds. This is what i did.
New rotors and pads all around
New tires all around
Front and rear allignment
Im not sure what solved the problem (i needed everything); however i did all of the above and there is no vibration if im going 20 or 120.
Peace,
Blindoufit
Peace,
Blindoufit
I had a violent shaking like this in my Probe and it ended up the bolt had backed out that bolted the Pilot bearing for the passenger half-shaft to the block, and the shaft was vibrating, but idk if these cars have the same kinda deal with a pilot bearing and such..just a thought..
For the last 3 days I was having horrible vibrations as well in one of my front wheels/tires. It was due to a ton of snow having built up on the backside of the wheel thanks to our two day blizzard. Once it melted, smooth as silk once again.
If u are driving in snow, take the advice previously given and look for the least expensive cause - ice and/or snow on the rims. This is very common and also very surprising that even a relatively small amount of snow/ice will cause very violent shaking at speed. It happens to me a few times every winter.
If you can't get the car somewhere to completely thaw, then a drive thru car wash is the best solution. If that doesn't solve the problem, then look to the other (more expensive) issues noted.
Hey all, I got the vibration too.. It happened after parking my car in some fairly high snow one evening, car ride home was violent to say the least. I park indoors so it thawed overnight and then was fine the next day.
A while after, noticed the steering wheel was off alignment (but didnt hit any thing.. I was thinking) Anyhow turned out the ball joint was messed up.. Just my two cents.
I'm a newbie, love this forum!!
So far I haven't had the shaking since Sunday. Hopefully it was snow/ice. Stupid snow. We are breaking records amounts of snow here and it's killing lowered cars as the amount of snow and constant clean-ups are causing HUGE potholes. So many that at times you can't avoid it. Anywho if there are some repaires needed the city will be getting the bill
I agree my i just took my car in this week for the same problem and he said rack and pinion is leaking and same with the CV joint. My car also pulls to the left and right really hard to after i lowered it. But he said those to problem will cause the car to shake on the freeway and also when slowing down. It going to cost about $1500 for parts and labor. But My car is just bearly under warranty so i just have to pay a small deductable for everthing. Hope this helps
Same problem here as well...
i got stuck because the plows plowed me in, i rocked the car back and forth spun the tires alot.
car was fine, i get on the highway shifting fine, i get to 55-60 on and the car shakes so bad i got off kicked the snow off and still shakes.
tires are inflated properly i dont know what else to think any one have an idea?
2002 SE 6Spd stock rims
been there done that, time for a new axle. I'm about to change mine again. the last one i got was used and at the time raxles didnt have any for my car. so i got one used. its been a year so it was good while it lasted (thats what she said)
When I had this happen on my first sentra one of the strut to knuckle bolts was coming loose. I would get under there and tighten everything done and give it at least a quick look over before taking it in, but get it checked out too.
Need help
23
10-02-2015 08:56 AM
