Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-19-2008, 09:21 AM   #1
Got a how to on CV/Axle replacement
Any have a how to for replacing the CV boot or entire axle for a 5th gen?
__________________
SHIFT_Infinitely
Mods:
-Retrofitted Maxima HIDs
-20% tints including sunroof
-White climate control and stereo displays
-Painted grill with silver graphite paint, left infiniti symbol chrome (looks hott)
-Clear front signal markers and headlights.
-791XV with r/s and trunk pop
LOOKING FOR SIDE SKIRTS AND I35 GRILLE!!!
Nakulbhatt87 is offline   Reply With Quote
Old 01-19-2008, 10:06 AM   #2
Quote:
which side?
__________________
AlpineGt66 is offline   Reply With Quote
Old 01-19-2008, 11:03 AM   #3
I've got a rip for sure in the boot on the driver's side...but im not sure about the passenger side. I caught a glimpse of the rip when i was replacing my fog bulb. Im getting a subtle click as we speak from the driver side. Would you suggest doing the cv boot or just the entire axle at this point?
__________________
SHIFT_Infinitely
Mods:
Old 01-19-2008, 11:11 AM   #4
'Trynna' is not a word
mtrai760's Avatar
Replace the axle.
Get a Chiltons or Haynes manual, or download the FSM for free
Loosen lugnuts
Jack up the car
Drain the transmission
Remove axle nut - Better have a big breaker bar and man up! 250+ ft/lbs tq
Disconnect tie-rod
Remove lower strut bolts
Remove the axle
Replace seal on transmission
Install in reverse order
Make sure to grease threads on the axle shaft
Torque everything to spec.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 01-19-2008, 03:05 PM   #5
Quote:
Originally Posted by mtrai760 View Post
Replace the axle.
Loosen lugnuts
Jack up the car
Disconnect tie-rod
Remove the axle
yup, get a raxle call it a day.
__________________
Old 01-19-2008, 03:22 PM   #6
is this for the right side axel
__________________
Signature too large - refer to signature guidelines.
EASTER WILL SOON BE HERE CHECK OUT THIS SITE!!
No linking to private for sale sites allowed.
BLACKKILA.GTR is offline   Reply With Quote
Old 01-19-2008, 05:50 PM   #7
LA02MAX's Avatar
Send a message via AIM to LA02MAX Send a message via MSN to LA02MAX
http://www.motorvate.ca/mvp.php/401
__________________
LTB, RSB, FSTB, H-techs and Illuminas, 6.5 gen wheels, 6th gen front brakes
PB: 14.338 @ 98.27 with a 2.300 60' stock.
LA02MAX is offline   Reply With Quote
Old 01-19-2008, 09:30 PM   #8
mtrai760's Avatar
Quote:
NO! He said, and I quote... "I've got a rip for sure in the boot on the driver's side..."
Last time I checked, that was on the left...
__________________
98 SE - VQ35
Old 01-19-2008, 10:53 PM   #9
wat
AceofSpds's Avatar
Send a message via AIM to AceofSpds
Indeed
Make sure you DO NOT mess with the circlip ring on the ends of the cv axles.
__________________
00' Maxima
95' 240sx
AceofSpds is offline   Reply With Quote
Old 01-19-2008, 11:01 PM   #10
Send a message via AIM to Drockb418
i dont think you have to drain the fluid at least for the driver side
__________________
1998 318 ti,s50 swap, m3 brakes, green house control arm bushings,H&R race springs with bilstein struts,ASA wheels,Magnaflow catback ,sparco seats,two 10” JL audio subs,3.73 rear end,euro headlights and more to come![/center]
Drockb418 is offline   Reply With Quote
Old 01-20-2008, 07:25 AM   #11
HEY SMART GUY
i was asking about the directions someone put out in the thread, they didnt state weather it was foR the left or right side SMART GUY!
THANK YOU
__________________
Old 01-20-2008, 07:28 AM   #12
Quote:
yeah i was thinking the same thing , i didnt drain mine..
__________________
Old 01-20-2008, 01:54 PM   #13
mtrai760's Avatar
HEY SMART GUY
THANK YOU
Hey DUMB GUY, he said the drivers side, and I was the one that posted the directions, for the DRIVERS SIDE like he requested, DUMB GUY! Why would I post directions for the RIGHT SIDE when he CLEARLY stated DRIVERS SIDE DUMB GUY. LAST I CHECKED, HERE IN THE GOOD OLD US OF A, THE DRIVERS SIDE IS ALWAYS ON THE LEFT, DUMB GUY.
You contributed NOTHING but attitude to this thread. I suggest you bring something USEFUL to the table other than name calling, or don't post any further. If you can't control yourself, I'll do it for you. How do you like them apples? Check out the color of your user name before you run your mouth with smart guy comments any further.
__________________
98 SE - VQ35
Old 08-05-2008, 07:47 PM   #14
Does anyone know the part number for the passenger side axle seal? Also I pulled the axle out and the dust shield that is normally up against the seal came off (with the axle). Do I need to reuse this dust shield or is that part of a new seal?
I assume I need to get this part from Nissan - Autozone couldn't get me one.
ando is offline   Reply With Quote
Old 08-05-2008, 08:44 PM   #15
one more question please. how do you remove the old axle seal? It's so far back I can't see how this can be done.
Thanks in advance.
Ando
Old 09-23-2008, 08:20 PM   #16
Just wanted to see if you replaced your CV axles and if so did you have any other problems after replacing? Thanks
Dave
imported_dave_a is offline   Reply With Quote
Old 12-26-2008, 07:27 PM   #17
Need help!! I'm having a hard time getting the pass side drive shaft out...i removed the bracket from the block...and finally got the 3 bolts that attach the axle to the bracket...but its rusted together....I can pull the axle and bracket through the small opening...i also smashed my oil pressure switch....what are my options....I've done a search and found the http://www.motorvate.ca/mvp.php/401 site and looked at http://boredmder.com/FSM/Infiniti/I30/2000/ but WTF theres no exact instructions as to removing the bracket...any help would be appreciated. Thanks
BLacKMax69 is offline   Reply With Quote
Old 10-21-2009, 11:15 AM   #18
Replace the axle.
Loosen lugnuts
Jack up the car
Disconnect tie-rod
Remove the axle
FSM= Factory Service Manual
Found it and downloaded. The Maintenance section is corrupted and I can not download.
Trying to find this section right now. I downloaded a European version which is not exactly right for the US.
Thanks to VQPOWER.
mandyfig is offline   Reply With Quote
Old 10-21-2009, 11:22 AM   #19
Send a message via MSN to Professor Send a message via Yahoo to Professor
Its very easy just time consuming, i did both mine 2 weeks ago, i jacked up and out her on jack stands, removed the wheel, caliber, rotor, brake pads, abs sensor, Use a breaker bar with a large pipe if the bolt is stubborn, 32mm socket, should do this with the brakes still on, have someone hold the brake pedal so the wheel wont turn when you break the axle nut loose, the fun part, use a 12mm gear wrench to get the 3 bolts off on the carrier bearing, you may need a air hammer to push the cv axle bearing out , i had too. then it just slides right out, the gear wrench is the best tool to get them 3 carrier bearing bolts out.
__________________
Eibach Springs|HIDs|20% Tint|Custom Stereo|Custom LED Interior|GAB|Brembo Sport Drilled Rotors|Hawk Hps pads |SE Tails|AE Headlight Coversion
SHIFT_auto rolling
Professor is offline   Reply With Quote
Old 10-22-2009, 10:37 AM   #20
The FSM details this repair. Good that we have the FSM to refer to.
Old 11-04-2009, 11:27 AM   #21
Now it is my time to do this axle replacement, my boot is busted on the pass side.
32 mm for the axle nut, right?
Old 11-04-2009, 11:49 AM   #22
Yep 32 MM, once you get the car secured on jack stands have someone apply the brakes and hold them, get your 32mm socket and a Breaker bar, you might have to use a pipe on the breaker bar like i did to break them loose.
__________________
SHIFT_auto rolling
Old 11-04-2009, 01:29 PM   #23
PB blaster will help, right? Need to get a 32mm socket!
Old 11-04-2009, 01:31 PM   #24
If I attempt to do this, I will certainly take my time and do a DIY. But I must admit this would be the biggest thing I will attempt to do mechanically. What scraes me is the discussion about...is it in...or is it still out?
Old 11-05-2009, 05:10 PM   #25
Quote:
It's better to loosen the axle bolt before you jack it up. That's what the FSM recommends as well.
__________________
'03 SE 6-spd
'01 SE auto
jvienneau is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
