Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 01-17-2008, 08:42 PM   #1
Send a message via AIM to stronium_95se
How to cover holes in trunk?
I debadged my maxima not knowing the Nissan emblem had holes behind it, how did you guys cover up the holes? and theres still residue from the glue, any suggestions on how to take it off? I tried using googone, wd40 and heating it!
stronium_95se is offline   Reply With Quote
Old 01-17-2008, 08:49 PM   #2
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
Heating it and scraping it with your thumbnail will get most of it, use a light polish for the rest. It may take a while, even with a buffer it took me a couple minutes to completely remove the residue. I left the "Nissan" emblem because I knew it would leave holes. If you don't want to have them filled and painted at a body shop, I'd just put it back.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is offline   Reply With Quote
Old 01-17-2008, 09:33 PM   #3
Maximized2000's Avatar
Send a message via AIM to Maximized2000
Painters tape on the outside of the trunk to cover the holes. Pop your trunk, mix some bondo up and apply some to cover up the holes from behind (make sure you put enough). Give it some time to dry up and slowly remove the painters tape to reveal the covered up holes. Now use touch up paint to cover up and your all done. If you have a system in your trunk...the bondo might fall off after a while so be careful.
I read this somewhere and I know there is a thread with pictures but I can't find it anywhere.
__________________
Check us out!!!
www.teamalloutnissan.com
Maximized2000 is offline   Reply With Quote
Old 01-17-2008, 09:36 PM   #4
Waiting...
Merlyn's Avatar
Send a message via AIM to Merlyn
That is really the only way to go about it, the other way that I have heard about is similar, but a bit more in depth
get a dowel rod that will fit the hole snug, from there you want to cut it to fit within the hole (to the point where it is snug from the outside, and hopefully the inside, you then put a small layer of bondo on each side, sand and paint...
Merlyn is online now   Reply With Quote
Old 01-17-2008, 09:40 PM   #5
yea thats another way too but a little more risky. "sand and paint"....someone that has no idea what they are doing might mess up their trunk.
__________________
Check us out!!!
Old 01-17-2008, 09:48 PM   #6
Waiting...
Merlyn's Avatar
That is true.... that is why I said it is a bit more complicated, but a way I personally would take (though I probably would go with some form of metal rod myself...
Old 01-17-2008, 11:07 PM   #7
3-Peat!!!!!
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
bondo
touchup paint
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is offline   Reply With Quote
Old 01-18-2008, 12:19 AM   #8
Is it just me or does anybody else look at where the Nissan emblem should be and still sort of see it there ...
__________________
Czerkas is offline   Reply With Quote
Old 01-18-2008, 01:07 AM   #9
you can use bug and tare remover got my double side tape off real clean
__________________
2003 Nissan Maxima SE
Injen CAI/SRI-custom test pipe-custom 2.5 exhaust with cherry bomb turbo muffler-eibach pro kit springs-auto meter air fuel guage-apc volt meter -custom automatic shift boot-custom ebrake boot-alpine deck-front strut bar-2001 GLE rear lights-custom red high beams-custom rear red blinkers-JDM yellow fog lights-smoked out bumper lenses
impact'sa33 is offline   Reply With Quote
Old 01-18-2008, 01:21 AM   #10
Send a message via AIM to 00SEMAX19 Send a message via Yahoo to 00SEMAX19
Quote:
Originally Posted by soonerfan View Post
bondo
touchup paint
That came out clean. I might have to remove the burger finally.
__________________
I'd rather spoonfeed than Flame and Postwhore.
YA THERE HEAVY 20'S FROM A FX45
My 02 6-speed SE Mods = intake, headers, full custom exhaust with no cats, 75 nx wet shot nitrous,denso iridium 1 step colder plugs, ssim, slotted/drilled brakes, ce front strut bar, heavy arse wheels, tein s-tech, In need of a/f tuner and tune badly, Plus some other randoms
00SEMAX19 is offline   Reply With Quote
Old 01-18-2008, 01:35 AM   #11
3-Peat!!!!!
SoonerFan's Avatar
that was my 00 and i decided that i didnt like the look with nothing there.
but i wanted something smaller....and different...so i got one off a pathfinder. its smaller and flush. it was on my 00 and now my 02.
stock 02 rear
now (smaller hamburger, SE removed, and MAXIMA replaced with A33)
__________________
06 Mazda 6
Old 01-18-2008, 01:48 AM   #12
BTW Where did you get the A33 badge? Or did you just put that together yourself?
__________________
Old 01-18-2008, 02:02 AM   #13
3-Peat!!!!!
SoonerFan's Avatar
Quote:
put it together myself. weeks of research with different companies to find letters that were the same size and font as the stock MAXIMA
__________________
06 Mazda 6
Old 01-18-2008, 02:08 AM   #14
And? Whats it going t tak to get some of that research info?
__________________
Old 01-18-2008, 02:30 AM   #15
3-Peat!!!!!
SoonerFan's Avatar
right now, its own of a kind. i thought of it and did the research. i should trademark it.
if people do it, thats fine. i dont really want to give all the info. pictures should be enough.
__________________
06 Mazda 6
Old 01-18-2008, 11:10 AM   #16
I like the blacked out keyhole too
Armon is offline   Reply With Quote
Old 01-28-2008, 07:51 PM   #17
2003 Nisan Maxima
Send a message via AIM to Teaner Send a message via Yahoo to Teaner
Ditto Sooner i do like the key hole as well.
Teaner is online now   Reply With Quote
Old 01-28-2008, 08:15 PM   #18
3-Peat!!!!!
SoonerFan's Avatar
Quote:
that was a must when i blacked everything else.
Old 01-28-2008, 09:05 PM   #19
Send a message via AIM to Drockb418
i feel stupid for asking but what is A33?
__________________
Drockb418 is offline   Reply With Quote
Old 01-28-2008, 09:26 PM   #20
3-Peat!!!!!
SoonerFan's Avatar
Quote:
nissan chassis code for 00-03 maxima
Old 01-28-2008, 09:33 PM   #21
ah now i know
__________________
Old 11-18-2008, 01:06 PM   #22
I used a buffer and some light rubbing compound to get the stubborn glue off after I de-badged and used goo-gone. Worked great.
As for hiding the holes... I used blue tape on the inside and then applied Black RTV sealant and used a wet finger to smooth it until it was flush, then used touch-up paint.
I tried the tape on the outside and did not like the results.. too many air bubbles and the texture did not work. I wanted something flexible because it needed to endure what JL Audio can do to it.
I agree, I like the black key hole when there is not a backup camera mounted in it. I think I'll do that to my door key holes, since I always use keyless and won't have to worry about scratches.
__________________
2K Max Black
maxgen5 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us!
