Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-12-2008, 03:09 PM   #1
spoiler installation
Hi all,
I wanted to install a OEM spoiler for my 00. Probably buy it off ebay or something. However, my car doesn't have the factory holes. Is it easy just to drill the holes myself install the spoiler and wirings?
-khanh
d40sithui is offline   Reply With Quote
Old 01-12-2008, 03:14 PM   #2
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
most spoilers come with a template to drill the holes
SoonerFan is offline   Reply With Quote
Old 01-12-2008, 07:18 PM   #3
hey thanks for the reply.
I dont think this is one of those spoilers you speak of. it does however, come painted. (wow!)
Old 01-12-2008, 09:56 PM   #4
$$ Ballin on a Budget $$
Orgullo's Avatar
Put the spoiler in place, mark it, drill out the holes and secure it n place. I know it's scary to do but if you want a spoiler then you'll do it. OR, you can take it to a body shop and ask them to put it on for you. For a price that is!
__________________
Orgullo is offline   Reply With Quote
Old 01-13-2008, 08:23 AM   #5
If you know some one else with same car and spoiler you could look on uder side of trunk to help you find the locations. Sometimes there maybe dimples on underside of trunk, even if yours didnt come with a spoiler where factory spoiler would go.
__________________
GroceryGetter/BabyBus/SpeedMachine
nismowolfe is offline   Reply With Quote
Old 01-13-2008, 09:53 AM   #6
I just removed a OEM spoiler from my 01 parts car and took some measurements of the hole placements. Measurements were started from drivers side front corner of trunk with a tape and located with a square held flush against trunk edge. Ignore pencil marks on square, there from other projects.
I have this wing with the snap in caps that go into the trunk if you want. PM me if you interested.
Hope this helps.
DISCLAIMER:
Use these pics as i guide, but please don't hold me responsible for any problems, etc.
__________________
01 Anniversary Edition: Stillen fstb rstb rsb, ES Poly bushings, K&N CAI, Tien S-Tech, Tokico Illumina, Brembo drilled slotted rotors with Hawk HPS pads, Trani oil cooler, HP 18x8 on Nittos, clear markers, eyelids, 35% tint.
rvamaxima is online now   Reply With Quote
Old 01-13-2008, 07:09 PM   #7
woa i didnt realize there would be so many holes for this thing. thanks for the tips. whats this "wing with the snaps in caps" you speak of?
Old 01-13-2008, 09:32 PM   #8
Snap caps fit in the holes in the trunk lid, 2 on each side and 1 in the center in addition to a 10mm nut at each contact point. 3rd hole in center wing support is for wiring. Pic here is of drivers side with caps.
__________________
Old 01-14-2008, 07:11 AM   #9
L.M.L.
i didn't drill those big holes when installed mine.
Old 01-14-2008, 12:21 PM   #10
Curb Rash Repair 100 a wheel
Maxima112's Avatar
Send a message via AIM to Maxima112
i ddint either. mine were a lot smaller more like the middle hole in the last picture. if you got it off ebay (i did as well) it should come with these tape like things you place on and then you put the spoiler on tape down the strips and BAM! you got your wholes. i'd say tape over the holes and drill a small whole. then slowly go to larger drill bit sizes i change it around 4 times till i got to the right size. good luck! its scary, but possible with a slow and controlled hand.
__________________
Maxima112 is offline   Reply With Quote
Old 01-14-2008, 01:35 PM   #11
are there not 'imprints' on the bottom of the trunks since teh factory probably used the same template trunk prior to drilling holes for the trunk?
phatboislim is offline   Reply With Quote
Old 10-29-2009, 01:03 PM   #12
I have a question on OEM Spoiler Installation.....I installed a OEM spoiler on my GLE with no problems... but the trunk slams very hard everytime if i dont help it down slowly.
Does anyone know how to fix this?
I searched but apparently this isnt a problem for many people.
acgrunt19 is offline   Reply With Quote
Old 10-29-2009, 03:10 PM   #13
Try adjusting your torsion bars that control the swing (when you open, it pops and helps you lift it and also provides the resistance to closing) of the trunk lid.
mandyfig is offline   Reply With Quote
Old 11-06-2009, 11:51 AM   #14
Quote:
I checked my trunk but no luck... there is nothing down there to adjust
Old 11-06-2009, 12:29 PM   #15
Maxima112's Avatar
install a hood strut or struts. one should do it with tension bars, if not 2 and take out the bars.
__________________
Old 11-06-2009, 01:06 PM   #16
How does a maxima trunk close when the spolier was factory installed? There has to be a simple solution for this but I just cant seem to find it.
Old 11-06-2009, 03:53 PM   #17
Quote:
There are different torsion springs for spoiler/non spoiler vehicles from the factory. You should be able to get them from a dealer or junk yard. The torsion bars are those two rods looking things going across the top of your truck area.
__________________
~Mark
2001 Maxima- Merlot, Eibach, KYB's, Debadged, GAB2, FSB, Pillar tape removed, 5% tint all around, 6k HID's.
2008 Pathfinder- VQ40DE
VQP0WER is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
