No power after 4k rpm
Old 01-11-2008, 11:01 PM
Supermax95's Avatar
2000 5 speed maxima, my car feels as if it's losing power after 4k rpm it feels as if the power band is just flattening out.....could this be a knock sensor issue?? the car has no codes(or ghost codes). The car runs perfectly otherwise. Any input, fuel, spark, timing being retarded??
Thanks in advance
Supermax95 is offline
Old 01-11-2008, 11:23 PM
SuperStasiu's Avatar
bad maf = mass air flow sensor
SuperStasiu is offline
Old 01-11-2008, 11:37 PM
Drug Money
MaxBoost925's Avatar
your MAF is fouled.
You know the funny thing is, I got engine oil in my MAF housing and my sensor still works.
MaxBoost925 is offline
Old 01-12-2008, 02:15 AM
Puerto Rico-Maxima Lover
Lontar1's Avatar
MAF
Lontar1 is offline
Old 01-12-2008, 02:13 PM
jasikes's Avatar
Anything else?
If it's your MAF, simple... If it gets worse, especially hesitation early in the powerband, then probably alternator. Easier to feel in an AUTO because the transmission will knock and the shift points will be off. Battery and brake light stay off?
jasikes is offline
Old 01-12-2008, 08:22 PM
xraytedrick's Avatar
could be a clogged cat converter
xraytedrick is offline
Old 01-12-2008, 08:28 PM
nismowolfe's Avatar
watch your tempature should get hot and possible overheat if its clogged cat.
nismowolfe is offline
Old 01-13-2008, 02:23 PM
SCRIBZ85's Avatar
what if its a clogged cat converter..what should he do?...or if its the alternator?
SCRIBZ85 is offline
Old 01-13-2008, 08:57 PM
playboi21617's Avatar
does that also cause loss in throttle response
playboi21617 is offline
Old 01-13-2008, 09:29 PM
diablo9896's Avatar
diablo9896 is offline
Old 01-31-2008, 03:59 PM
AeMaxSERconcept's Avatar
playboi yes is does cause poor throttle respose.... mine would cut out at 35oo rpms mostly and would take forever to get to 4000....rough shifts and banging into gears was also something i had...
AeMaxSERconcept is offline
Old 01-31-2008, 04:13 PM
ghostridden's Avatar
mine did that about a year ago, new MAF gave it all sorts of new life
ghostridden is offline
PulsarGTS's Avatar
Had the same problem, was the MAF.
PulsarGTS is offline
aw11power
10-10-2021 04:57 AM
gigabyte
01-06-2017 06:05 PM
ef9
10-04-2015 08:43 AM
Need help
23
10-02-2015 08:56 AM
Quick Reply: No power after 4k rpm
