advice - shocks/springs/axle replacement
looking for general advice and tips on a suspension job needed. I do a lot of highway driving so want a not so rough ride and not looking to lower the car really...so
1. Recomendation on shock/spring combo front/rear (got axles already)
2. plan on doing myself, would like some tips on replacing all these parts
such as removal tips, install, etc.
thanks!
thanks!
I've tried Eibach before the H&R and I don't like it when my upper jaw and lower jaw are fighting against each other on the freeway.
If you want to keep you stock ride, just replace the struts and call it a day. Tokico might be a good replacement but they will wear out faster than Koni. The metal that they used to contruct their piston is also not as hard as Koni. I'm telling you all these from my personal experience that I've had with Tokicos, both blue and Illumina, and the Koni that I've already sold. Toks are POS IMHO.
seriously....check the stickies and/or search. There is more than enough information on this topic out there to keep you busy reading for weeks...
you've been here long enough you should know better
jskirwin
06-08-2016 08:49 AM
