How Many Times Do You Shift?
Old 12-12-2007, 04:08 PM
  #41
dot dot dot ...
NmexMAX's Avatar
So, who is it? I'm curious to see who ahs a 2000-2001 w/7200. 7100 is standard from TS unless you tell them otherwise, and even then it takes some persuading.
NmexMAX is offline
Old 12-12-2007, 07:30 PM
  #42
NiSmOVQ35's Avatar
Looks gOOd mike, sO when you ganna do your buddy a favor and do his LED's ?? lloll
NiSmOVQ35 is offline
Old 12-12-2007, 08:40 PM
  #43
telmohd's Avatar
How did you get the red glow on the inside? looks hot
telmohd is offline
Old 12-12-2007, 08:48 PM
  #44
dot dot dot ...
NmexMAX's Avatar
The guy does something really rare, reputable, probably difficult, and very high on the cool factor, and all anyone cares about are his damn gauges.
NmexMAX is offline
Old 12-12-2007, 11:39 PM
  #45
6spd Swapped
OHH NOES's Avatar
The truth. Tomorrow I'll post some pics of my LED interior, I knew LEDs > 6speed Swaps.
OHH NOES is offline
Old 12-12-2007, 11:56 PM
  #46
I R The Law
The Law's Avatar
LMAO!!!!!!!
The Law is offline
Old 12-13-2007, 10:25 AM
  #47
burnurass's Avatar
That's cause you are the LED *****!
again...congrats on the 6speed HLSD! ABOUT TIME!
burnurass is offline
Old 12-18-2007, 11:31 PM
  #48
6spd Swapped
OHH NOES's Avatar
Here's an update on how everything is going. I definatly need the ES motor mount inserts, the auto tranny motor mounts are way too soft. My new passenger side raxle came in, so my teeth chattering vibrations will stop. Im also having a problem with the clutch slipping after the car has been driven 10miles or so. Got so bad the clutch stopped grabbing completely, had to have the car towed back to my garage. The engagement point is scary close to the top. Tried bleeding the lines, absolutly no air in them at all. Tried adjusting the pedal, but couldnt really get anything to adjust since there is really no writeup and the one thread that did give any idea was filled with bickering about whether or not it was good or bad. So Im thinking it's rather the slave or master cylinder or the pressure plate. Either way the clutch is probably pissed off from all this slipping during its breakin period. So it might be time for the 350z cluth and pressure plate anyway. Tonight I took the car out again, drove it for about an hour and a half and no problem at all, not even a little slipping. So I'll post another update when this is resolved.
OHH NOES is offline
Old 09-20-2009, 02:53 PM
  #49
pro23's Avatar
happy for u and ur 6mt swap hope u get that problem solved so u can fully enjoy ya car.....
pro23 is offline
Old 09-20-2009, 03:33 PM
  #50
Grand_hustle17's Avatar
^^^ check the date bro, check the date
Grand_hustle17 is offline
Old 09-21-2009, 05:20 AM
  #51
Merxima's Avatar
Very nice transmission swap! I'm sure it took alot of time and effort. Keep us informed how everything goes, especially with the issue of your clutch slipping. Nice interior lights as well
Frank
Merxima is offline
Old 09-21-2009, 07:54 AM
  #52
nzelinsky's Avatar
LOL this happens all the time...
However, If the op is still kickin around in here it would be interesting to see how this all worked out 2 years later.
nzelinsky is offline
Old 09-21-2009, 08:23 AM
  #53
bigpopaj369's Avatar
bigpopaj369 is offline
Old 10-06-2009, 10:50 AM
  #54
6spd Swapped
OHH NOES's Avatar
Just came across this thread again. All the issues with the swap were resolved, car drives like it should from the factory. The swap is also holding up with the turbo install also.
OHH NOES is offline
Old 10-06-2009, 04:47 PM
  #55
e-subliminal-2's Avatar
Congrats, you now own the more powerful, rarer of the maximas
But I won't lie, we all (who own one) know the power of a 6mt, but those lights are kick a$$
e-subliminal-2 is offline
Old 11-26-2009, 08:03 PM
  #56
DMAXXX's Avatar
FINDING a good 6 is hard enough but congrads on the swap.
hope to do the same this winter
DMAXXX is offline
CorollaULEV
30
08-09-2021 08:11 PM
Matt93SE
05-24-2019 02:58 PM
SmokinMax02
18
09-11-2015 12:25 AM
Trin1j23
08-12-2015 08:31 PM
Quick Reply: How Many Times Do You Shift?
