Pics of my OSCAI
That's Mr. Detail to you
Pics of my OSCAI
Since most of the links are broken in the OSCAI thread, I thought I'd post up the pictures I took of my install. Cost me a total of $11 for 4" dryer duct and a 4" work clamp at Lowe's. No huge gains or anything but it does feel a bit stronger according to the butt dyno from 3500 rpm and up, most noticable from 5000 rpm to redline.
Yeah, the front lip is pretty scuffed up but I can't see it unless I get down there so no biggie.
Still debating whether or not to do the GAB too. I've seen the ones with the drilled out tops in the filter holder but can't find any pics of the ones with the hanger to hold the filter in place-rather do that than drill because it would be easier to switch back. Anyone have pics? Can't find any in the threads I did a search on.
Nice work Scott! I think you should do the GAB, it's a fun experiment and you can just use a coat hanger instead of hacking up your filter holder. Are you getting an intake in the future?
OT: I need to pm you about some detailing products!
I'll probably stick with the one I made. I did a similar mod with the Accord I used to have and the AEM CAI I got to replace it didn't make much improvement except for the odd 4000 rpm bump that is typical of that style intake. The noise definitely increased though, louder than the exhaust. I'd rather keep my car quiet than pick another couple of horsepower and a lot more noise.
NmexMAX-a lot of the links are cardomain sites that aren't there anymore.
Link to your intake?
Which setup is that NMexMax? Stock air box with 3" midpipe (LRMAF) How is the sound compared to GAB or Berk?
I'll try to link you to the coat hanger, but it's pretty simple. The metal coat hanger is molded/bending around the air filter and sticks our at the top to hold it in place (wow, bad description).
could you show a picture zoomed out... of the engine bay... preferbly on the right hand side (the intake side)
and yea... almost all the links for the OSCAI are non existant car domain links ... or threads where the pictures are no longer active.
Once you cut off the end of the 3.5" tip on the underside of the intake tract and attach the dryer hose, it is pretty obvious where to route it.
Sounds really good. Smooth/quiet. Like I've always said, if done correctly, throttle response is dramatically improved.
Originally Posted by skidz88
pros/cons of that Nmex?
GAB thread:
http://forums.maxima.org/showthread.php?t=194391
GAB thread:
I did this as well I will try to take pictures tomorrow. I really felt a good gain all across the board with this. What I did is only drill 4 because irish drilled 8 and ended up plugging up 4 of them when I followed the thread. Also, engine note was improved as well. Also, if you use a boring bit (not sure if this is the right name) it looks like it is meant to be on the airbox.
Hanger Gab mod is better than cutting up your intake IMO, plus it makes it sound sooooooooooooooooooo sexy between 2500 and 5000 rpm, no lie my friend who has a 5.7L Z28 asked me if i swapped a v8 in for the VQ30DE-K
I don't know if this thread is FTW or FTL
FTL due to posting in a 6 month old thread
FTW ... "p.s. i just noticed i'm posting in a six month old thread....it's one of those days "
It might prevent large debris (like paper) from being sucked up, but the air filter will still block it from getting into the engine. I do find I have to pull out my filter about once a month and tap out the dirt that gets sucked up.
Second reresurection...that's exactly what I meant lol, your gonna want to keep the RPM in that range which equals more gas
Not if you leave the upper part of the intake intact (the part that goes to the radiator support), plus I also have since done the GAB. Basicallly, the intake tract and GAB act like a hole in the side of a straw. You can't suck up anything once the hole in the side of the straw is no longer in the liquid. I'm safe as long as I stay out of water that goes up as high as my radiator. Besides, if I get into water that deep, I have a lot more than hydrolock to worry about.
04-16-2020 05:15 AM
bigfrank
10-01-2015 12:51 PM
