Those who have had oil leaks
I noticed a small puddle of oil on my garage floor where I park my car. After researching, it appears that the most common problem may be associated with the oil pan. For those that have had oil leaks, can you tell me if this is one of the most common problems and if so, can you give me a ball park figure of what it is going to cost to get it fixed. I have an 02 SE with 104K. I want to take it somewhere this weekend, but I do not want to get beat.
I've heard about problems with the rear valve (rocker) cover leaking too. The fix is to replace it with an '04 and newer valve cover. Check the easy stuff first though, loose oil pan bolts, etc.
check the axle seals on the tranny, the rear main seal along with the front main seal. how is you valve cover gaskets holding up? rusty oil pan perhaps? get the car on the lift and look under it, i usually clean the dirty spots with brake cleaner, air dry with air gun and start uop the engine to see for any leaks (for major ones that is), this will also help later on to see if gaskets are leaking, check after a few days of driving.
Thanks All. I will jack it up tommorow to check some of these things. I hope it is something as simple as a leaking oil filter. I want to get me some new rims for Christmas. I would hate to have to spend my money on a repair.
I have a 2002 SE....had an oil leak as well....took it to the dealer who claimed it was the oil pan....they removed the pan and re-sealed it.....leak still there....went back to dealer....they said, "Oh, the tech missed a little section of sealer....we'll fix it".....still leaked.....back to dealer.....they then claimed the oil pan needed to be replaced.....but they would give me the pan for cost and install it for free.....that was about $100.....still leaked.....took it back.....they then determined it was the oil cooler (before someone jumps on here denying the presence of an oil cooler, 2002's do have them....it's between the oil filter and the engine block).....dealer wanted $550 to replace it....I told them no thanks....went on line and bought the part for about $180 (I think) and a buddy of mine and I installed it ourselves....THAT was the ticket....no more leaks. The job was pretty easy to do actually....the fact that the dealer wanted $550 was a joke. Hope this helps.
Really pathetic how dealers can't seem to fix cars right or try to take shortcuts.
Good info about the oil cooler, I didn't know my car had one. Now I do.
it could be something simple... or something complex... u gotta get underneath and check it out first... .
i once had it leak cause i didnt tighten the filter up properly ... when i changed my oil... er leaked again...
just take a look... and post pics iif you want and someone might be able to fix it for you.. .
and another time it leaked because my oil pan lost its seal with the block.... i did a temp fix of using jb weld all around it... and nev
I have an 02 SE 6spd that had an oil leak which appeared to be at the rim of the oil pan - after cleaning up the area, I saw that the leak was actually coming from the oil cooler.
I replaced the oil cooler gasket part#B1304-43U00 and the leak is gone.
Well this week i had same problem OIL Leak only while engine running. After i lift the car up in my shop i notice that header that is close to the firewall had some spots of oil so i tear apart intake and replaced Valve cover gaskets made a huge mistake by buying them from Napa. The material they made them from is very stiff. I did install as it says in Nissan manual applying rtv gasket maker to corners and still it leaked then i called Nissan dealer and got OEM gaskets they was awesome nice and soft and no more leaks in that area but after about 15 minutes of idling time new leak appeared and it was oil pressure switch again got it from Nissan very good quality also replaced at the same time my spark plugs got NGK laser IRIDIUM, knock sensor, PCV Valve and Fuel Filter. over all very happy with a result runs smoother and getting better MPG this car is in my family since it was brand new she has 255k and runs like new
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
